pakos96
  1. Unfortunately the 6.6.39 (Armbian 24.5.3 current) version seems to be the last version. After update I've the boot issue. I've rollbacked to 6.6.32 kernel version... Who can we report it to?
  2. @jock thank you. I've tried the 6.6.41 kernel but this version didn't fix the boot issues... is there a more up-to-date version?
  3. Sorry.. so has the kernel bug been fixed? can i update?
  4. I updated the armbian kernel without reading the thread and now I have my TV box down. How can I revert the kernel to the previous version without losing data? is that possible? thanks in advance EDIT: OK I used .deb packages to force the old kernel version, everything is now OK. How can I upgrade the kernel to the pre-bug version? What is the appropriate version?
  5. Hello, I would like to ask you something. Preliminary remark: I am not experiencing any particular malfunctions at the moment. Launching the command 'dmesg | grep mmc' I notice some errors at the end of the log: [ 2.503983] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode. [ 2.504032] dwmmc_rockchip ff500000.mmc: Using internal DMA controller. [ 2.504053] dwmmc_rockchip ff500000.mmc: Version ID is 270a [ 2.504148] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo [ 2.504182] dwmmc_rockchip ff510000.mmc: IDMAC supports 32-bit address mode. [ 2.504224] dwmmc_rockchip ff510000.mmc: Using internal DMA controller. [ 2.504243] dwmmc_rockchip ff510000.mmc: Version ID is 270a [ 2.504328] dwmmc_rockchip ff510000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo [ 2.504705] dwmmc_rockchip ff500000.mmc: Got CD GPIO [ 2.504748] dwmmc_rockchip ff510000.mmc: allocated mmc-pwrseq [ 2.504768] mmc_host mmc1: card is non-removable. [ 2.505873] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode. [ 2.505932] dwmmc_rockchip ff520000.mmc: Using internal DMA controller. [ 2.505953] dwmmc_rockchip ff520000.mmc: Version ID is 270a [ 2.506046] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo [ 2.506584] dwmmc_rockchip ff5f0000.dwmmc: IDMAC supports 32-bit address mode. [ 2.506657] dwmmc_rockchip ff5f0000.dwmmc: Using internal DMA controller. [ 2.506679] dwmmc_rockchip ff5f0000.dwmmc: Version ID is 270a [ 2.506784] dwmmc_rockchip ff5f0000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo [ 2.507066] mmc_host mmc2: card is non-removable. [ 2.507330] dwmmc_rockchip ff5f0000.dwmmc: Got CD GPIO [ 2.517666] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.517738] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.518163] mmc_host mmc3: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.518260] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.664219] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 2.919494] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0) [ 2.919602] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0) [ 3.142700] dwmmc_rockchip ff510000.mmc: Successfully tuned phase to 155 [ 3.146775] mmc1: new ultra high speed SDR50 SDIO card at address 0001 [ 3.202282] dwmmc_rockchip ff520000.mmc: Successfully tuned phase to 145 [ 3.203725] mmc2: new HS200 MMC card at address 0001 [ 3.210480] mmcblk2: mmc2:0001 DF4064 58.2 GiB [ 3.217802] mmcblk2: p1 [ 3.221230] mmcblk2boot0: mmc2:0001 DF4064 4.00 MiB [ 3.228213] mmcblk2boot1: mmc2:0001 DF4064 4.00 MiB [ 3.235001] mmcblk2rpmb: mmc2:0001 DF4064 4.00 MiB, chardev (242:0) [ 4.407228] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Quota mode: none. [ 6.724310] EXT4-fs (mmcblk2p1): re-mounted. Quota mode: none. [ 8.973626] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2 [ 8.980814] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2 while when I launch "dmesg | grep error" I see this log: [ 8.870879] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 8.973626] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin failed with error -2 [ 8.980814] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2 What can this indicate? Are these 'normal' errors? Thank you
  6. No problem! I was intentionally being ironic thanks again
  7. @jock I just used the script to change the DDR frequency and everything works perfectly at 660mhz. As per your advice I don't go any further to avoid bricking everything. Thanks! P.S. no crying (yet)
  8. Ok thank you. let me know if you have any news.
  9. Hello, everyone, I've been reading the thread a bit because I wanted to increase the speed of DDR memories to 667mhz. I saw that they are currently set at 333mhz for a compatibility issue. I found the bin in the "rkbin" archive but I don't know now how I can make the change. Could you give me some suggestions? Thanks
