mirko
  1. Hello, Bluetooth stopped working in kernel 5.19.17-meson64 #22.11.1 root@nextcloudpi:~# hciconfig hci0: Type: Primary Bus: USB BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0 DOWN RX bytes:14 acl:0 sco:0 events:1 errors:0 TX bytes:3 acl:0 sco:0 commands:3 errors:2 root@nextcloudpi:~# hcitool dev Devices: root@nextcloudpi:~# dmesg | grep Bluetooth [ 10.005353] Bluetooth: Core ver 2.22 [ 10.010561] Bluetooth: HCI device and connection manager initialized [ 10.010582] Bluetooth: HCI socket layer initialized [ 10.010589] Bluetooth: L2CAP socket layer initialized [ 10.010621] Bluetooth: SCO socket layer initialized [ 10.273422] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once... [ 11.647454] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 11.647474] Bluetooth: BNEP filters: protocol multicast [ 11.647489] Bluetooth: BNEP socket layer initialized [ 15.326913] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround [ 15.327136] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported. [ 15.327149] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported. [ 15.327153] Bluetooth: hci0: HCI Set Event Filter command not supported. [ 17.341929] Bluetooth: hci0: Opcode 0x c03 failed: -110 [42900.593231] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once... [42900.922097] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround [42900.923021] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported. [42900.923040] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported. [42900.923044] Bluetooth: hci0: HCI Set Event Filter command not supported. [42902.934227] Bluetooth: hci0: Opcode 0x c03 failed: -110 [42905.073243] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once... [42905.661928] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround [42905.662099] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported. [42905.662108] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported. [42905.662112] Bluetooth: hci0: HCI Set Event Filter command not supported.
