armbian bionic NANOPI T4 overclocked little cores by default
I must say that im suprised. I installed Armbian 5.59 Bionic on Nanopi T4 and found little cores A53 overclocked 1.80GHZ and big A72 cores clocked 1.90GHZ.
Im using double radiator 3.5 cm x 3.5 cm. It is not very hot. I was not expecting such good job from Nanopi. On Firefly RK3399 i must to use third 3.5x 3.5radiator and it is getting hot at clock speed 1.4ghz a53 and 1.81ghz a72.
