Armbianmonitor:
Hello,
i had a problem withe an Orange Pi Lite and the Cheap RPI Display.
The Display Backlight is on.
I had used this tut:
https://forum.armbian.com/topic/6737-orange-pi-zero-35-tft-touchscreen/
https://forum.armbian.com/topic/4837-guide-how-to-use-touchscreen-lcd-on-h3-devices/
2) Create a makefile (Take note that it is TABS instead of spaces before the $(MAKE))
nano Makefile Insert the below in without the ----- -------------------------------- obj-m := ads7846.o KDIR := /lib/modules/$(shell uname -r)/build PWD := $(shell pwd) all: $(MAKE) -C $(KDIR) M=$(PWD) modules clean: $(MAKE) -C $(KDIR) M=$(PWD) clean install: $(MAKE) -C $(KDIR) M=$(PWD) modules_install --------------------------------
3) Exit nano and run the following
sudo make
root@orangepilite:~# sudo make
make -C /lib/modules/4.19.25-sunxi/build  M=/root  modules
make[1]: *** /lib/modules/4.19.25-sunxi/build: No such file or directory.  Stop.
Makefile:5: recipe for target 'all' failed
make: *** [all] Error 2
What can i make?
I need help.
Thanks
Install kernel header using armbian-config or these command.
sudo apt-get update
sudo apt-get -y install linux-headers-$(uname -r)
