Armbianmonitor:
Hello, I recently installed Armbian 5.85 legacy on my new Orange Pi Lite in order to try out my new Orange Pi camera, but it's not being recognized at all, even after following the instructions in this topic:
I already tried doing the following (as root) unsuccessfully (no errors returned, but still can't detect camera):
sunxi-pio -m "PG11<1><0><1><1>" #DOVDD
sunxi-pio -m "PE15<1><0><1><0>" #Power_Down
sunxi-pio -m "PE14<1><0><1><1>" #reset
modprobe gc2035
modprobe vfe_v4l2
Here's the output of lsusb:
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Unfortunately, Armbian 5.20 is no longer available, so I can't try that unless I can compile it from source.
Edited by GRBaset
OK, I solved the problem by installing an Armbian 5.20 image I found searching for "armbian_5.20_orangepilite_debian_jessie_3.4.112.7z" on Google. However, it's not an optimal solution, because I have to be careful when updating, and Debian Jessie will no longer be supported on June 30, 2020. In order to keep it working, I have to put the following packages on hold:
# apt-mark hold armbian-firmware armbian-tools-jessie linux-headers-sun8i linux-image-sun8i linux-jessie-root-orangepilite linux-u-boot-orangepilite-default sunxi-tools
