Attempted Jessie to Stretch, failed, likely dead on reboot.
Hello!
I tried to update jessie dismally, here:
https://forum.armbian.com/topic/9984-apt-get-update-pointing-to-404-not-found-ip-151101240204-80/?do=findComment&comment=79685
Since then, I have been attempting to update to strech, I feel like I got close, but it's failed and I strongly suspect, my next reboot will hose it.
(I will not reboot it, linux is wondeful!!)
I updated my sources.list file to have the following 4 values.
deb http://httpredir.debian.org/debian stretch main contrib non-free
deb http://httpredir.debian.org/debian stretch-updates main contrib non-free
deb http://httpredir.debian.org/debian stretch-backports main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
the apt-get update and apt-get upgrade (appear) to be working fine.
apt-get dist-upgrade will spit out the following:
Errors were encountered while processing:
 network-manager
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Upon further investigation I have done the following tips in this post precisely
http://forums.debian.net/viewtopic.php?p=122113#p122113
These have failed, it outright refuses to get network-manager on there.
Job for NetworkManager.service failed because the control process exited with error code.
See "systemctl status NetworkManager.service" and "journalctl -xe" for details.
journalctl -xe will produce the following:
May 25 15:33:28 orangepizero systemd[17220]: NetworkManager.service: Failed at step NAMESPACE spawning /usr/sbin/NetworkManager: Bad file descriptor
-- Subject: Process /usr/sbin/NetworkManager could not be executed
When I begin to google that information I start reaching even less google hits and possibly even a bug?
https://www.google.com/search?rlz=1C1GCEA_enAU767AU767&ei=K9ToXI64A6LYz7sPvr2qwAE&q="NetworkManager.service"+"bad+file+descripor"&oq="NetworkManager.service"+"bad+file+descripor"&gs_l=psy-ab.3..33i160l2.9570.14812..14992...3.0..0.276.4626.0j13j10......0....1..gws-wiz.......0j0i22i30j33i21.bL0kzS4p6yg
Finally, when I log in to the system remotely it even says :
"ARMBIAN 5.73 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i"
"Kernel was updated, please reboot "
However, I feel this is very unwise, until I can be certain that the update and upgrades and clean and autoremove and all the commands to maintain the system at least spit back results indicating success.
One last reply:  here's the full output of the 2 main large errors, sorry quite large:
invoke-rc.d: initscript network-manager, action "start" failed.
● NetworkManager.service - Network Manager
   Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Sat 2019-05-25 15:40:43 AEST; 27ms ago
     Docs: man:NetworkManager(8)
  Process: 18510 ExecStart=/usr/sbin/NetworkManager --no-daemon (code=exited, status=226/NAMESPACE)
 Main PID: 18510 (code=exited, status=226/NAMESPACE)
May 25 15:40:43 orangepizero systemd[1]: Failed to start Network Manager.
May 25 15:40:43 orangepizero systemd[1]: NetworkManager.service: Unit entered failed state.
May 25 15:40:43 orangepizero systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
dpkg: error processing package network-manager (--configure):
 subprocess installed post-installation script returned error exit status 1
Processing triggers for initramfs-tools (0.130) ...
update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i
E: busybox or busybox-static, version 1:1.22.0-17~ or later, is required but not installed
update-initramfs: failed for /boot/initrd.img-3.4.113-sun8i with 1.
dpkg: error processing package initramfs-tools (--configure):
 network-manager
 initramfs-tools
And this one from journal
May 25 15:40:44 orangepizero systemd[18536]: NetworkManager.service: Failed at step NAMESPACE spawning /usr/sbin/NetworkManager: Bad file
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The process /usr/sbin/NetworkManager could not be executed and failed.
-- The error number returned by this process is 9.
May 25 15:40:44 orangepizero systemd[1]: NetworkManager.service: Main process exited, code=exited, status=226/NAMESPACE
May 25 15:40:44 orangepizero systemd[1]: Failed to start Network Manager.
-- Subject: Unit NetworkManager.service has failed
-- Unit NetworkManager.service has failed.
-- The result is failed.
May 25 15:40:44 orangepizero systemd[1]: NetworkManager.service: Unit entered failed state.
May 25 15:40:44 orangepizero systemd[1]: NetworkManager.service: Failed with result 'exit-code'.
May 25 15:40:44 orangepizero systemd[1]: NetworkManager.service: Service hold-off time over, scheduling restart.
May 25 15:40:44 orangepizero systemd[1]: Stopped Network Manager.
-- Subject: Unit NetworkManager.service has finished shutting down
-- Unit NetworkManager.service has finished shutting down.
May 25 15:40:44 orangepizero systemd[1]: NetworkManager.service: Start request repeated too quickly.
As much as I wish i was a lot smarter and had more time - I will not attempt "takeover.sh" which sounds like a super cool way of rescuing a hosed system.   - Complicated and powerful but not something even close to my skillset, super cool though!
Also this after running
apt-get remove --purge network-manager
Processing triggers for systemd (232-25+deb9u11) ...
Processing triggers for dbus (1.10.26-0+deb9u1) ...
 initramfs-tools
Thanks to all those on this forum, across multiple threads helping me.
End of the day, sadly, the best solution was a wiped SDCard (fill 0s) test SDcard (h2testw, full) and re-flash to the latest stretch.
3'rd SDCard a charm, it's booted, I've updated aptupd/upg and installed pihole and it appears to be working fine.
Let's hope she stays that way.
One thing, in order to avoid this problem in the future, since the jessie library /repository was moved (??) shouidl I make a habit of doing an apt-update / upgrade say once every 2 or 3 months to stay on top of things?
