Installing Armbian on Beelink X2 just to play with.  Installs but don't know answer to  privateuser@beelinkx2:~"$ __________?  What's the answer.  I had Arm on this a few years ago and removed it.  But stuck on install.
The line says...   The command could not be located because 'usr/sbin' is not included in the PATH environment variable.  This is most likely caused by the lack of administrative privileges associated with your user account.  ???????
Board: Not on the list
Edited by Dash Riprock
