Avtar Singh Posted August 25, 2019 Posted August 25, 2019 I use orange pi zero with armbian xenial 5.38 with update kernal via apt-get upgrade the issue is that sometime the device get hang at boot before the start of the kernal, and then we have to unplug it and plug it again i want to start watchdog at boot itselft, so if this happen the device reboot automatically i already sold 1000 devices, but now the sales stop due to this issue please help Thanks Board: Orangepi Zero
Avtar Singh Posted August 28, 2019 Author Posted August 28, 2019 please someone provide the solution to this problem
qstaq Posted August 28, 2019 Posted August 28, 2019 Watchdog is part of the kernel and will not help you in this situation if, as you say, the device is hanging BEFORE the start of kernel loading You need to provide the serial debug output from the u-boot phase of the boot process AND the output of armbianmonitor -u if you want some help, your question doesnt really provide any technical info that can be used to troubleshoot
Avtar Singh Posted August 28, 2019 Author Posted August 28, 2019 U-Boot SPL 2017.11-armbian (Jan 25 2018 - 08:04:30) DRAM: 256 MiB Trying to boot from MMC1 U-Boot 2017.11-armbian (Jan 25 2018 - 08:04:30 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 204 ms (17.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 191 bytes read in 165 ms (1000 Bytes/s) 5837326 bytes read in 658 ms (8.5 MiB/s) 7497384 bytes read in 9204 ms (794.9 KiB/s) Found mainline kernel configuration 29807 bytes read in 1269 ms (22.5 KiB/s) 504 bytes read in 1850 ms (0 Bytes/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 1859 ms (0 Bytes/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 4155 bytes read in 1727 ms (2 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5837262 Bytes = 5.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 49a6e000, end 49fff1ce ... OK reserving fdt memory region: addr=43000000 size=6d000 Loading Device Tree to 499fe000, end 49a6dfff ... OK Starting kernel ...
Avtar Singh Posted September 18, 2019 Author Posted September 18, 2019 someone please help to trigger watchdog at boot what should i put in boot.scr file to trigger watch dog or in /boot/armbianEnv.txt i put "echo 1 > /dev/watchdog" in /usr/share/initramfs-tools/init to trigger watchdog at kernal start please help me to solve this
Bongho Lee Posted August 22, 2020 Posted August 22, 2020 @Avtar Singh Did you find the solution? I'm in the same situation.
