vanst Posted September 2, 2019 Share Posted September 2, 2019 Dear all, My Orange Pi plus 2E was working fine before. I was able to install both the desktop / server version to the eMMC. However, one day I try to run a benchmarch & speedtest script from tocdo.net, the Pi freeze and unable to boot from eMMC ever since. I've tried to boot the Pi with an SD, it's working fine. I tried to format the eMMC - no problem at all, but when I tried to install the OS to the eMMC, it's always stuck at around 55% (for the server version) and 10% (for the desktop version). I try to run the command from URAT, SSH and the local PC itself but not working. Can you advise on this case? Below is the log from URAT: https://drive.google.com/file/d/1GG_O7dpw-xwJmwQyuo3Pw3VqNQQ4VeSX/view?usp=sharing And this is the information of fdisk: van@orangepiplus2e:~$ sudo fdisk -l [sudo] password for van: Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk0: 29.3 GiB, 31440502784 bytes, 61407232 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xcf01fb0f Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 8192 60793151 60784960 29G 83 Linux Disk /dev/mmcblk1: 14.6 GiB, 15634268160 bytes, 30535680 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x40866ac2 Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 8192 30230303 30222112 14.4G 83 Linux Disk /dev/zram0: 50 MiB, 52428800 bytes, 12800 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/zram1: 990.7 MiB, 1038815232 bytes, 253617 sectors Units: sectors of 1 * 4096 = 4096 bytes Sector size (logical/physical): 4096 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes van@orangepiplus2e:~$ Link to comment Share on other sites More sharing options...
