Kimberly Posted May 12, 2016 Posted May 12, 2016 Hello, I'm currently working on embedded and now I need to connect my banana pi A20 with lemake LCD. Because of chromium issues and bugs for lower kernel, I want to use vanilla kernel. What I want to do is to run a server suing asp.net and start a kiosk mode chromium and check in the LCD. I've checked you posted this link http://github.com/igorpecovnik/lib/blob/master/patch/kernel/sunxi-next/bananapipro_lemaker_lcd.patch.disabled ​I also heard that I might deal with this problem by kernel compile, but I'm pretty new to Linux, and actually a little bit overwhelmed about the sources and information. ​Can you give me any suggestion about kernel compile, where to start or useful information? ​Thanks
Guest SkilsiMet Posted June 3, 2016 Posted June 3, 2016 Hello Mikumiku747, add a symbol at the very end of your linker file that denotes the end of your kernel. For example: Code:
