I would like to enable SPI on RockPi4, but I don't know how. Further I did a list of I2C devices, also I can't figure out where those I2C devices are suppposed to be:
pi@rockpi:~$ sudo sudo i2cdetect -l
i2c-0   i2c             rk3x-i2c                                I2C adapter
i2c-1   i2c             rk3x-i2c                                I2C adapter
i2c-2   i2c             rk3x-i2c                                I2C adapter
i2c-4   i2c             rk3x-i2c                                I2C adapter
i2c-7   i2c             rk3x-i2c                                I2C adapter
i2c-9   i2c             DesignWare HDMI                         I2C adapter
This is I2C map from schematics:
Note, the listing is different: 0, 1, 2, 4, 7, 9     VS.      0, 1, 2, 3, 4, 6, 7 from schematics.
Now probing:
pi@rockpi:~$ sudo i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: UU UU -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
This one is correct 0x40, 0x41, 0x1b shall be used by system
pi@rockpi:~$ sudo i2cdetect -y 1
10: -- UU -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
0x11 Not in the map, possibly audio IC from schematics - ES8316?
pi@rockpi:~$ sudo i2cdetect -y 9
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: 30 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
0x30 is not in the map.
FUSB302B chip in the map 0x44, 0x46 doesn't exist?
I would like to use I2C_7 GPIO2_A7/VOP_D7/CIF_D7/I2C7_SDA  and GPIO2_B0/VOP_CLK/CIF_VSYNC/I2C7_SCL these are located on RPI header pin 3,5 ; which I2C device is this?
How to enable SPI device? I wold like to connect a SPI slave on RPI header - same SPI channel as SPI flash which is not mounted.
EDIT:
pi@rockpi:~$ sudo i2cdetect -y 7
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
OK, these are devices connected on RPI header I2C7.
