I don't really know if this is related to Armbian, but I have a USB disk that is not recognised when plugged into USB 3 (blue port) but it works in USB2.0 port. I have also tried SanDisk Ultra USB3.0 and it works. Shouldn't the USB3.1 also support USB3.0 if it supports USB2.0 ?
SOLVED:
I does work in kernel 5.4.38.
[ 2921.666286] usb 6-1: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[ 2921.687193] usb 6-1: New USB device found, idVendor=0781, idProduct=5583, bcdDevice= 1.00
[ 2921.687208] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2921.687219] usb 6-1: Product: Ultra Fit
[ 2921.687228] usb 6-1: Manufacturer: SanDisk
[ 2921.687240] usb 6-1: SerialNumber: 0501634ed22050222bcbb18b9662cf60a71d58eb3accd361176c490dac57c439b94200000000000000000000f62b26dbff9d0f108355810778267974
[ 2921.688502] usb-storage 6-1:1.0: USB Mass Storage device detected
[ 2921.689030] scsi host1: usb-storage 6-1:1.0
[ 2922.691087] scsi 1:0:0:0: Direct-Access     SanDisk  Ultra Fit        1.00 PQ: 0 ANSI: 6
[ 2922.691920] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 2922.692134] sd 1:0:0:0: [sdb] 60088320 512-byte logical blocks: (30.8 GB/28.7 GiB)
[ 2922.692987] sd 1:0:0:0: [sdb] Write Protect is off
[ 2922.693002] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 2922.694608] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2922.724780]  sdb: sdb1
[ 2922.728106] sd 1:0:0:0: [sdb] Attached SCSI removable disk
