Dear all,
I recently perched a SINA33 from SINLINX after a week of test i download the Armbian source code that is very interesting and started to create an Armbian image for this board.
I created a csc file to start the building.
The csc file code:
# A33 quad core 1Gb SoC
BOARD_NAME="Sina33"
BOARDFAMILY="sun8i"
BOOTCONFIG="Sinlinx_SinA33_defconfig"
MODULES="hci_uart gpio_sunxi rfcomm hidp bonding spi_sun7i 8021q a20_tp"
MODULES_NEXT="brcmfmac"
OVERLAY_PREFIX="sun8i-a33"
KERNEL_TARGET="default,next,dev"
The compile is done and the image is created. I flash the image with the mainline kernel and worked.
If there is any interesting on this topic i will create another with the more details.
Now the problem is that i can't port the AP6210 wifi module that this board came with.
Here is the dts file sun8i-a33-sinlinx-sina33.dts with the wifi modifications
 * Copyright 2015 Chen-Yu Tsai
 * Chen-Yu Tsai <wens@csie.org>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
#include "sun8i-a33.dtsi"
#include "sunxi-common-regulators.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
    model = "Sinlinx SinA33";
    compatible = "sinlinx,sina33", "allwinner,sun8i-a33";
    aliases {
        serial0 = &uart3;
    chosen {
        stdout-path = "serial0:115200n8";
    panel {
        compatible = "netron-dy,e231732";
        #address-cells = <1>;
        #size-cells = <0>;
        port@0 {
            reg = <0>;
            #size-cells = <0>;
            panel_input: endpoint@0 {
                reg = <0>;
                remote-endpoint = <&tcon0_out_panel>;
    wifi_pwrseq: wifi_pwrseq {
        compatible = "mmc-pwrseq-simple";
        pinctrl-names = "default";
        reset-gpios = <&r_pio 0 6 GPIO_ACTIVE_LOW>; /* PL6 or GPIO-358 */
        clocks = <&rtc 1>;
        clock-names = "ext_clock";
&codec {
    status = "okay";
&cpu0 {
    cpu-supply = <&reg_dcdc3>;
&cpu0_opp_table {
    opp-1104000000 {
        opp-hz = /bits/ 64 <1104000000>;
        opp-microvolt = <1320000>;
        clock-latency-ns = <244144>; /* 8 32k periods */
    opp-1200000000 {
        opp-hz = /bits/ 64 <1200000000>;
&de {
    status = "okay";
&dai {
    status = "okay";
&ehci0 {
    status = "okay";
&lradc {
    vref-supply = <&reg_dcdc1>;
    status = "okay";
    button@200 {
        label = "Volume Up";
        linux,code = <KEY_VOLUMEUP>;
        channel = <0>;
        voltage = <191011>;
    button@400 {
        label = "Volume Down";
        linux,code = <KEY_VOLUMEDOWN>;
        channel = <0>;
        voltage = <391304>;
    button@600 {
        label = "Home";
        linux,code = <KEY_HOME>;
        channel = <0>;
        voltage = <600000>;
&mmc0 {
    pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_sina33>;
    vmmc-supply = <&reg_dcdc1>;
    bus-width = <4>;
    cd-gpios = <&pio 1 4 GPIO_ACTIVE_LOW>; /* PB4 */
    status = "okay";
&mmc1 {
    /*vmmc-supply = <&reg_vcc3v3>;
    vqmmc-supply = <&reg_vcc3v3>;
    pinctrl-0 = <&mmc1_pins_a>;
    mmc-pwrseq = <&wifi_pwrseq>;
    bus-width = <4>;
    non-removable;
    status = "okay"; */
    vqmmc-supply = <&reg_dcdc1>;
    bus-width = <4>;
    non-removable;
    status = "okay";
    brcmf: wifi@1 {
        reg = <1>;
        compatible = "brcm,bcm4329-fmac";
        /*interrupt-parent = <&r_pio>;
        interrupts = <0 7 IRQ_TYPE_LEVEL_LOW>;  PL7 or GPIO-359 EINT7
        interrupt-names = "host-wake"; */
&mmc1_pins_a {
    /* AP6210 requires pull-up */
    bias-pull-up;
&mmc2 {
    pinctrl-0 = <&mmc2_8bit_pins>;
    bus-width = <4>;
    non-removable;
    cap-mmc-hw-reset;
    status = "okay";
&mmc2_8bit_pins {
    /* Increase drive strength for DDR modes */
    drive-strength = <40>;
    /* eMMC is missing pull-ups */
    bias-pull-up;
&ohci0 {
    status = "okay";
&pio {
    mmc0_cd_pin_sina33: mmc0_cd_pin@0 {
        pins = "PB4";
        function = "gpio_in";
        bias-pull-up;
&r_rsb {
    status = "okay";
    axp22x: pmic@3a3 {
        compatible = "x-powers,axp223";
        reg = <0x3a3>;
        interrupt-parent = <&nmi_intc>;
        interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
        eldoin-supply = <&reg_dcdc1>;
#include "axp223.dtsi"
&ac_power_supply {
    status = "okay";
&battery_power_supply {
    status = "okay";
&reg_aldo1 {
    regulator-always-on;
    regulator-min-microvolt = <3000000>;
    regulator-max-microvolt = <3000000>;
    regulator-name = "vcc-io";
&reg_aldo2 {
    regulator-min-microvolt = <2350000>;
    regulator-max-microvolt = <2650000>;
    regulator-name = "vdd-dll";
&reg_aldo3 {
    regulator-min-microvolt = <2700000>;
    regulator-max-microvolt = <3300000>;
    regulator-name = "vcc-pll-avcc";
&reg_dc5ldo {
    regulator-min-microvolt = <900000>;
    regulator-max-microvolt = <1400000>;
    regulator-name = "vdd-cpus";
&reg_dcdc1 {
    regulator-name = "vcc-3v0";
&reg_dcdc2 {
    regulator-name = "vdd-sys";
&reg_dcdc3 {
    regulator-name = "vdd-cpu";
&reg_dcdc5 {
    regulator-min-microvolt = <1500000>;
    regulator-max-microvolt = <1500000>;
    regulator-name = "vcc-dram";
&reg_rtc_ldo {
    regulator-name = "vcc-rtc";
&sound {
    status = "okay";
&tcon0 {
    pinctrl-0 = <&lcd_rgb666_pins>;
    status = "okay";
&tcon0_out {
    tcon0_out_panel: endpoint@0 {
        reg = <0>;
        remote-endpoint = <&panel_input>;
&uart0 {
    pinctrl-0 = <&uart0_pins_b>;
    status = "okay";
&uart3 {
        pinctrl-0 = <&uart3_pins_b>;
    status = "okay";
&usb_otg {
    dr_mode = "peripheral";
    status = "okay";
&usbphy {
    status = "okay";
    usb1_vbus-supply = <&reg_vcc5v0>; /* USB1 VBUS is always on */
/*&wifi_pwrseq {
        clocks = <&rtc 1>;
I'm not sure about the clock on dts file
clocks = <&rtc 1>;
the error that i take
root@sinlinx:~# dmesg | grep brcm
[    5.750408] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1
[    6.822224] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[    7.826234] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
also this
dmesg | grep 1c10000.mmc
[    2.162351] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.4
[    2.664498] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    2.690138] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
root@sinlinx:/lib/firmware/brcm# lsmod
Module                  Size  Used by
brcmfmac              159744  1
fuse                   73728  3
zstd                   16384  4
zram                   24576  2
snd_soc_simple_card    16384  2
snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
cdc_ether              16384  0
usbnet                 24576  1 cdc_ether
evdev                  20480  3
r8152                  49152  0
axp20x_battery         16384  0
axp20x_usb_power       16384  0
axp20x_adc             16384  0
sun8i_codec_analog     24576  1
lima                   40960  0
sun8i_adda_pr_regmap    16384  1 sun8i_codec_analog
gpu_sched              20480  1 lima
sun8i_codec            20480  1
sun4i_i2s              20480  2
ttm                    57344  1 lima
snd_soc_core          114688  5 sun4i_i2s,sun8i_codec_analog,sun8i_codec,snd_soc_simple_card_utils,snd_soc_simple_card
snd_pcm_dmaengine      16384  1 snd_soc_core
sun4i_gpadc_iio        16384  0
snd_pcm                69632  4 sun4i_i2s,snd_pcm_dmaengine,sun8i_codec,snd_soc_core
snd_timer              24576  1 snd_pcm
industrialio           49152  4 axp20x_usb_power,axp20x_battery,sun4i_gpadc_iio,axp20x_adc
snd                    45056  7 snd_timer,snd_soc_core,snd_pcm
soundcore              16384  1 snd
sun4i_lradc_keys       16384  0
sun4i_ss               24576  0
cpufreq_dt             16384  0
panel_simple           53248  0
uio_pdrv_genirq        16384  0
uio                    16384  1 uio_pdrv_genirq
thermal_sys            57344  2 cpufreq_dt,sun4i_gpadc_iio
sch_fq_codel           20480  2
brcmutil               16384  1 brcmfmac
cfg80211              393216  1 brcmfmac
ip_tables              20480  0
x_tables               20480  1 ip_tables
uas                    20480  0
pwrseq_simple          16384  1
Using a oscilloscope i saw that the clock at SDIO_DATA_CLK of the module is at 50Mhz and that correct.
The blob exist in the /lib/firmware/brcm
BCM4330B1.hcd              brcmfmac43430-sdio.bin
BCM4345C5.hcd              brcmfmac43430-sdio.txt
bcm4329.hcd                brcmfmac43430a0-sdio.bin
bcm4330.hcd                brcmfmac43430a0-sdio.txt
bcm43438-sdio.hcd          brcmfmac43455-sdio.bin
brcmfmac-ap6330-sdio.bin   brcmfmac43455-sdio.clm_blob
brcmfmac-ap6330-sdio.txt   brcmfmac43455-sdio.txt
brcmfmac4329-sdio.bin      brcmfmac43456-sdio.bin
brcmfmac4329-sdio.txt      brcmfmac43456-sdio.txt
brcmfmac4330-sdio.bin      brcmfmac4356-sdio-nanopi-m4v2.bin
brcmfmac4330-sdio.txt      brcmfmac4356-sdio-nanopi-m4v2.txt
brcmfmac43362-sdio.bin     brcmfmac4356-sdio.bin
brcmfmac43362-sdio.txt     brcmfmac4356-sdio.txt
brcmfmac4339-sdio.1CK.txt  brcmfmac4359-sdio.bin
brcmfmac4339-sdio.ZP.txt   brcmfmac4359-sdio.txt
brcmfmac4339-sdio.bin      config.txt
brcmfmac4339-sdio.txt
Attached phones from Inside the AP6210 module
Any ideas are thought are really appreciated.
