Hey folks,
I know I should rather post in the OMV forums, but those are in maintenance until next week, maybe someone here uses OMV on a HCx. I flashed the Armbian minimal image, booted, SSHd into it, ran updates, ran the OMV install script and rebooted. Now I still can SSH into the HC1, but the there is no OMV interface running for the browser. During the OMV installation it complained something about something like openmediavault-flashmedia or something but apart from that finished successfully as far as I can tell. Here's the output in the console windows as far as I can scroll back:
-   directory mask = 0700
                  -# By default, \\server\username shares can be connected to by anyone
                  -# with access to the samba server.
                  -# The following parameter makes sure that only "username" can connect
                  -# to \\server\username
                  -# This might need tweaking when using external authentication schemes
                  -   valid users = %S
                  -# Un-comment the following and create the netlogon directory for Domain Logons
                  -# (you need to configure Samba to act as a domain controller too.)
                  -;[netlogon]
                  -;   comment = Network Logon Service
                  -;   path = /home/samba/netlogon
                  -;   guest ok = yes
                  -;   read only = yes
                  -# Un-comment the following and create the profiles directory to store
                  -# users profiles (see the "logon path" option above)
                  -# The path below should be writable by all users so that their
                  -# profile directory may be created the first time they log on
                  -;[profiles]
                  -;   comment = Users profiles
                  -;   path = /home/samba/profiles
                  -;   guest ok = no
                  -;   browseable = no
                  -;   create mask = 0600
                  -;   directory mask = 0700
                  -[printers]
                  -   comment = All Printers
                  -   browseable = no
                  -   path = /var/spool/samba
                  -   printable = yes
                  -   guest ok = no
                  -   read only = yes
                  -   create mask = 0700
                  -# Windows clients look for this share name as a source of downloadable
                  -# printer drivers
                  -[print$]
                  -   comment = Printer Drivers
                  -   path = /var/lib/samba/printers
                  -   browseable = yes
                  -   read only = yes
                  -   guest ok = no
                  -# Uncomment to allow remote administration of Windows print drivers.
                  -# You may need to replace 'lpadmin' with the name of the group your
                  -# admin users are members of.
                  -# Please note that you also need to set appropriate Unix permissions
                  -# to the drivers directory for these users to have write rights in it
                  -;   write list = root, @lpadmin
                  +workgroup = WORKGROUP
                  +server string = %h server
                  +dns proxy = no
                  +log level = 0
                  +log file = /var/log/samba/log.%m
                  +max log size = 1000
                  +logging = syslog
                  +panic action = /usr/share/samba/panic-action %d
                  +encrypt passwords = true
                  +passdb backend = tdbsam
                  +obey pam restrictions = no
                  +unix password sync = no
                  +passwd program = /usr/bin/passwd %u
                  +passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
                  +pam password change = yes
                  +socket options = TCP_NODELAY IPTOS_LOWDELAY
                  +guest account = nobody
                  +load printers = no
                  +disable spoolss = yes
                  +printing = bsd
                  +printcap name = /dev/null
                  +unix extensions = yes
                  +wide links = no
                  +create mask = 0777
                  +directory mask = 0777
                  +use sendfile = yes
                  +aio read size = 16384
                  +aio write size = 16384
                  +time server = no
                  +wins support = no
                  +multicast dns register = no
                  +# Special configuration for Apple's Time Machine
                  +fruit:aapl = yes
                  +# Extra options
                  +min receivefile size = 16384
                  +write cache size = 524288
                  +getwd cache = yes
    Function: file.append
      Result: True
     Comment: Appended 1 lines
     Started: 20:24:36.558285
    Duration: 160.719 ms
     Changes:
              diff:
                  @@ -40,3 +40,4 @@
                   getwd cache = yes
                  +#======================= Share Definitions =======================
    Function: file.managed
      Result: True
     Comment: File /etc/cron.daily/openmediavault-samba-recycle updated
     Started: 20:24:36.719541
    Duration: 8.379 ms
     Changes:
              diff:
                  New file
              mode:
                  0750
    Function: module.run
      Result: True
     Comment: file.find: []
     Started: 20:24:36.730402
    Duration: 2.677 ms
     Changes:
              file.find:
      Result: True
     Comment: File /etc/default/wsdd updated
     Started: 20:24:36.733428
    Duration: 8.093 ms
     Changes:
              diff:
                  @@ -1 +1,3 @@
                  -WSDD_OPTIONS="--shortlog"
                  +# This file is auto-generated by openmediavault (https://www.openmediavault.org)
                  +# WARNING: Do not edit this file, your changes will get lost.
                  +WSDD_OPTIONS="--shortlog --workgroup='WORKGROUP'"
    Function: test.nop
      Result: True
     Comment: Success!
     Started: 20:24:36.743339
    Duration: 0.857 ms
     Changes:
    Function: service.dead
      Result: True
     Comment: The service smbd is already dead
     Started: 20:24:36.768075
    Duration: 281.343 ms
     Changes:
      Result: True
     Comment: The service nmbd is already dead
     Started: 20:24:37.050913
    Duration: 223.86 ms
     Changes:
      Result: True
     Comment: The service wsdd is already dead
     Started: 20:24:37.276014
    Duration: 236.986 ms
     Changes:
Summary for odroidxu4
Succeeded: 9 (changed=5)
Failed:    0
Total states run:     9
Total run time:   1.098 s
/usr/lib/python3/dist-packages/salt/utils/path.py:265: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated, and in 3.8 it will stop working
  if not isinstance(exes, collections.Iterable):
odroidxu4:
    Function: file.directory
      Result: True
     Comment: The directory /var/lib/openmediavault/rrd is in the correct state
     Started: 20:24:49.541540
    Duration: 20.863 ms
     Changes:
      Result: True
     Comment: The directory /var/cache/samba is in the correct state
     Started: 20:24:49.562923
    Duration: 2.128 ms
     Changes:
      Result: True
     Comment: The directory /etc/folder2ram is in the correct state
     Started: 20:24:49.565324
    Duration: 1.639 ms
     Changes:
      Result: True
     Comment: File /etc/folder2ram/folder2ram.conf is in the correct state
     Started: 20:24:49.567206
    Duration: 71.473 ms
     Changes:
    Function: file.absent
      Result: True
     Comment: File /etc/cron-apt/action.d/3-download is not present
     Started: 20:24:49.639161
    Duration: 1.123 ms
     Changes:
    Function: cmd.run
        Name: /usr/sbin/folder2ram -enablesystemd
      Result: False
     Comment: Command "/usr/sbin/folder2ram -enablesystemd" run
     Started: 20:24:49.642618
    Duration: 51.201 ms
     Changes:
              pid:
                  30121
              retcode:
                  127
              stderr:
                  /bin/bash: /usr/sbin/folder2ram: No such file or directory
              stdout:
    Function: cmd.run
        Name: /usr/sbin/folder2ram -mountall
      Result: False
     Comment: Command "/usr/sbin/folder2ram -mountall" run
     Started: 20:24:49.695149
    Duration: 45.158 ms
     Changes:
              pid:
                  30122
              retcode:
                  127
              stderr:
              stdout:
Succeeded: 5 (changed=2)
Failed:    2
Total states run:     7
Total run time: 193.585 ms
/usr/lib/python3/dist-packages/salt/utils/decorators/signature.py:31: DeprecationWarning: `formatargspec` is deprecated since Python 3.5. Use `signature` and the `Signature` object directly
  *salt.utils.args.get_function_argspec(original_function)
odroidxu4:
      Result: True
     Comment: The directory /var/lib/openmediavault/ssh/authorized_keys is in the correct state
     Started: 20:25:02.008066
    Duration: 4.086 ms
     Changes:
      Result: True
     Comment: File /etc/ssh/sshd_config is in the correct state
     Started: 20:25:02.012602
    Duration: 141.404 ms
     Changes:
    Function: service.running
      Result: True
     Comment: The service ssh is already running
     Started: 20:25:02.178750
    Duration: 245.197 ms
     Changes:
Succeeded: 3
Failed:    0
Total states run:     3
Total run time: 390.687 ms
odroidxu4:
      Result: True
     Comment: File /etc/chrony/chrony.conf updated
     Started: 20:25:14.730004
    Duration: 142.204 ms
     Changes:
              diff:
                  @@ -1,6 +1,7 @@
                  -# Welcome to the chrony configuration file. See chrony.conf(5) for more
                  -# information about usuable directives.
                  -pool 2.debian.pool.ntp.org iburst
                  +server pool.ntp.org iburst
                   # This directive specify the location of the file containing ID/key pairs for
                   # NTP authentication.
                  @@ -19,8 +20,12 @@
                   # Stop bad estimates upsetting machine clock.
                   maxupdateskew 100.0
                  +# This directive tells 'chronyd' to parse the 'adjtime' file to find out if the
                  +# real-time clock keeps local time or UTC. It overrides the 'rtconutc' directive.
                  +hwclockfile /etc/adjtime
                   # This directive enables kernel synchronisation (every 11 minutes) of the
                  -# real-time clock. Note that it can’t be used along with the 'rtcfile' directive.
                  +# real-time clock. Note that it can't be used along with the 'rtcfile' directive.
                   rtcsync
                   # Step the system clock instead of slewing it if the adjustment is larger than
      Result: True
     Comment: Service chrony has been enabled, and is running
     Started: 20:25:14.897864
    Duration: 5495.646 ms
     Changes:
              chrony:
                  True
Succeeded: 2 (changed=2)
Failed:    0
Total states run:     2
Total run time:   5.638 s
odroidxu4:
      Result: True
     Comment: File /etc/timezone is in the correct state
     Started: 20:25:32.407335
    Duration: 87.891 ms
     Changes:
    Function: timezone.system
      Result: True
     Comment: Timezone Etc/UTC already set, UTC already set to Etc/UTC
     Started: 20:25:32.499235
    Duration: 303.637 ms
     Changes:
Succeeded: 2
Failed:    0
Total states run:     2
Total run time: 391.528 ms
odroidxu4:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-collectd.conf is not present
     Started: 20:25:45.914858
    Duration: 1.511 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-filesystem.conf is in the correct state
     Started: 20:25:45.916753
    Duration: 95.287 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-nginx.conf is in the correct state
     Started: 20:25:46.012583
    Duration: 19.828 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-engined.conf is in the correct state
     Started: 20:25:46.032844
    Duration: 19.283 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-phpfpm.conf is in the correct state
     Started: 20:25:46.052559
    Duration: 17.344 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-proftpd.conf is not present
     Started: 20:25:46.070307
    Duration: 1.074 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-rrdcached.conf is not present
     Started: 20:25:46.071638
    Duration: 0.684 ms
     Changes:
      Result: True
     Comment: File /etc/monit/conf.d/openmediavault-system.conf is in the correct state
     Started: 20:25:46.072557
    Duration: 40.255 ms
     Changes:
      Result: True
     Comment: File /etc/default/monit is in the correct state
     Started: 20:25:46.113262
    Duration: 4.637 ms
     Changes:
      Result: True
     Comment: File /etc/monit/monitrc is in the correct state
     Started: 20:25:46.118194
    Duration: 42.538 ms
     Changes:
    Function: cmd.run
      Result: True
     Comment: Command "monit -t" run
     Started: 20:25:46.163578
    Duration: 72.995 ms
     Changes:
              pid:
                  30438
              retcode:
                  0
              stderr:
              stdout:
                  Control file syntax OK
      Result: True
     Comment: The service monit is already running
     Started: 20:25:46.273586
    Duration: 251.817 ms
     Changes:
Succeeded: 12 (changed=1)
Failed:     0
Total states run:     12
Total run time:  567.253 ms
odroidxu4:
    Function: salt.state
      Result: True
     Comment: States ran successfully. Updating odroidxu4.
     Started: 20:25:58.580166
    Duration: 1689.897 ms
     Changes:
              odroidxu4:
                    Result: True
                   Started: 20:25:59.647722
                  Duration: 1.492 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.649536
                  Duration: 96.455 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.746444
                  Duration: 20.402 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.767221
                  Duration: 17.634 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.785205
                  Duration: 17.368 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.802906
                  Duration: 0.928 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.804045
                  Duration: 0.686 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.804933
                  Duration: 41.545 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.846863
                  Duration: 4.909 ms
                   Changes:
                    Result: True
                   Started: 20:25:59.852034
                  Duration: 41.943 ms
                   Changes:
                  Function: cmd.run
                    Result: True
                   Started: 20:25:59.896735
                  Duration: 74.451 ms
                   Changes:
                            pid:
                                30501
                            retcode:
                                0
                            stderr:
                            stdout:
                    Result: True
                   Started: 20:26:00.008272
                  Duration: 246.725 ms
                   Changes:
              Failed:     0
              Total run time:  564.538 ms
      Result: True
     Comment: File /etc/default/rrdcached is in the correct state
     Started: 20:26:00.279954
    Duration: 19.957 ms
     Changes:
      Result: True
     Comment:
     Started: 20:26:00.302569
    Duration: 1.159 ms
     Changes:
      Result: True
     Comment: The service rrdcached is already dead
     Started: 20:26:00.325575
    Duration: 281.205 ms
     Changes:
Succeeded: 4 (changed=1)
Failed:    0
Total states run:     4
Total run time:   1.992 s
odroidxu4:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/cpu.conf is in the correct state
     Started: 20:26:12.802373
    Duration: 71.794 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/df.conf is in the correct state
     Started: 20:26:12.874647
    Duration: 17.7 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/interface.conf is in the correct state
     Started: 20:26:12.892809
    Duration: 15.357 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/load.conf is in the correct state
     Started: 20:26:12.908545
    Duration: 3.915 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/memory.conf is in the correct state
     Started: 20:26:12.912745
    Duration: 3.316 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/rrdcached.conf is in the correct state
     Started: 20:26:12.916319
    Duration: 3.167 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/syslog.conf is in the correct state
     Started: 20:26:12.919735
    Duration: 3.287 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/unixsock.conf is in the correct state
     Started: 20:26:12.923267
    Duration: 3.151 ms
     Changes:
      Result: True
     Comment: File /etc/collectd/collectd.conf.d/uptime.conf is in the correct state
     Started: 20:26:12.926658
    Duration: 3.106 ms
     Changes:
      Result: True
     Started: 20:26:12.934925
    Duration: 1620.5 ms
     Changes:
              odroidxu4:
                    Result: True
                   Started: 20:26:13.994751
                  Duration: 1.452 ms
                   Changes:
                    Result: True
                   Started: 20:26:13.996511
                  Duration: 33.455 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.030399
                  Duration: 20.122 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.050997
                  Duration: 17.594 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.068922
                  Duration: 17.026 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.086251
                  Duration: 0.931 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.087395
                  Duration: 0.68 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.088276
                  Duration: 41.183 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.129842
                  Duration: 4.943 ms
                   Changes:
                    Result: True
                   Started: 20:26:14.135049
                  Duration: 42.126 ms
                   Changes:
                  Function: cmd.run
                    Result: True
                   Started: 20:26:14.179892
                  Duration: 72.881 ms
                   Changes:
                            pid:
                                30578
                            retcode:
                                0
                            stderr:
                            stdout:
                    Result: True
                   Started: 20:26:14.290144
                  Duration: 250.113 ms
                   Changes:
              Failed:     0
              Total run time:  502.506 ms
      Result: True
     Comment: File /etc/collectd/collectd.conf is in the correct state
     Started: 20:26:14.556107
    Duration: 29.707 ms
     Changes:
      Result: True
     Comment: File /etc/cron.d/openmediavault-mkrrdgraph is not present
     Started: 20:26:14.586305
    Duration: 1.135 ms
     Changes:
      Result: True
     Comment:
     Started: 20:26:14.590143
    Duration: 1.18 ms
     Changes:
      Result: True
     Comment: The service collectd is already dead
     Started: 20:26:14.614791
    Duration: 237.741 ms
     Changes:
Succeeded: 14 (changed=1)
Failed:     0
Total states run:     14
Total run time:    2.015 s
odroidxu4:
      Result: True
     Comment: File /etc/default/cpufrequtils is in the correct state
     Started: 20:26:26.824237
    Duration: 114.283 ms
     Changes:
      Result: True
     Comment: File /etc/default/loadcpufreq is in the correct state
     Started: 20:26:26.939077
    Duration: 16.318 ms
     Changes:
      Result: True
     Comment: The service cpufrequtils is already running
     Started: 20:26:26.981327
    Duration: 253.366 ms
     Changes:
      Result: True
     Comment: The service loadcpufreq is already running
     Started: 20:26:27.238030
    Duration: 204.384 ms
     Changes:
Succeeded: 4
Failed:    0
Total states run:     4
Total run time: 588.351 ms
root@odroidxu4:~#
What can I do about it?
Thanks!
Björn
I have a HC2 and still could not install OMV on it. Tried both images (stretch and buster) but could not even install it. In the middle of the installation I get some errors trying to install openmediavault-omvextrasorg.
Which is this install script you ran ? Could you send it to me ? I cannot access the guide on their forum. Dou you have it and could send to me, please ?
Thanks
