Hi everybody and thanks the armbian team for your work.
I'm owning a SOPine module (SOPine-A64-Rev C) with a SOPine Baseboard (Model A Rev B), with the 16Go eMMC module sold by Pine64.
I tried these builds with the same issue:
  • Armbian_20.02.1_Pine64so_buster_current_5.4.20.img   (All the provided logs are from this build)
  • Armbian_20.02.1_Pine64so_bionic_current_5.4.20.img
  • Armbian_19.11.6_Pine64so_buster_current_5.4.7.img
I tried at first to write the image direclty to the eMMC  before noticing it wasn't the right way to do => I removed all the partitions from the eMMC.
When writing the image to the microSD card:
  • If I insert microSD card only => System boots properly
  • If I insert microSD card + eMMC module => Boot hangs after U-boot at :
Loading, please wait...
starting version 241
Begin: Loading root file system ... Begin: Running /scripts/local-top ... done.
I also tried the image Armbian_20.05.0-trunk.117_Pine64so_focal_dev_5.6.5_minimal.img.
This image however hangs  1 or 2 minutes at:
starting version 245.4-4ubuntu3
But ends by booting!
I have 2 relevant devices under /dev/:
  • mmcblk0:
    • mmcblk0p1
  • mmcblk2:
    • mmcblk2boot0
    • mmcblk2boot1
I would like to use if possible the Debian base, than the Ubuntu dev..
 While in U-boot console (with eMMC inserted):
  • With Armbian_20.02.1_Pine64so_buster_current_5.4.20.img:
=> version
U-Boot 2019.10-armbian (Feb 17 2020 - 09:28:03 +0100) Allwiner Tchnology
aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0
GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321
=> mmc dev
switch to patitions #0, OK
mmc0 is current device
=> mmc list
mmc@1c0f000: 0 (SD)
mmc@1c11000: 1
=> mmc dev 1
mmc1 (part 0) is current device
=> mmc list
mmc@1c0f000: 0 (SD)
mmc@1c11000: 1 (eMMC)
                   => I have to change device  for eMMC to be recognised ?
  • With Armbian_20.05.0-trunk.117_Pine64so_focal_dev_5.6.5_minimal.img:
=> version
U-Boot 2020.04-armbian (Apr 26 2020 - 09:12:13 +0200) Allwiner Tchnology
=> mmc dev
=> mmc list
mmc@1c0f000: 0 (SD)
=> eMMC recognised automatically.
Similar issues:
Edited by SecT0uch
