quangha Posted May 4, 2020 Posted May 4, 2020 Armbianmonitor: http://ix.io/2g5I I recently started playing around with OrangePi Zero with the Allwinner H2+ CPU. I want to test out the internal audio DAC. To do so I enabled "analog-coded" in armbian-config. After rebooting I saw a new audio device in the output of "pacmd list-cards", but it says that only mono is available. How can I configure stereo sound? I haven't played around with "/etc/asound.conf" much as I don't understand it. Also, I don't have anything plugged into the audio pins on the GPIO.
