ChrisO Posted May 20, 2020 Posted May 20, 2020 Hi I'm trying to use OpiZero with a relais module. I noticed, during the boot the pins I tried (12 and 11, physical 3 resp 5) go high, which makes impossible to manage the relais module. Is it a HW/SW bug or limitation or something what can be configured somehow. I would expect the level to be "nothing" ;-) Thanks Chris
ChrisO Posted May 22, 2020 Author Posted May 22, 2020 Replying to my own question, just for reference. I found the reason for the high level here: http://linux-sunxi.org/images/4/ ... _Datasheet_V1.2.pdf There are four pins pulled-up at startup, I obviously must have choosen one of them. With GPIO6 pin it works as I expected it to.
