Hi everyone,
I am trying to set the pin 26 (PL08) on orange pi as Input but sometimes it is flashing.
I did  put a 10K external pull up resistor and it is exported as input pin.
I did the same thing with the pin 22 (PD21) and this one is steady, no problems until now.
I did not add anything on overlays for these pins.
Any idea what I am doing wrong?
Thanks
On 5/23/2020 at 8:47 AM, MX_Master said:
Pull up or pull down the pin using built-in 50k resistors. And compare the results.
Is it possible to have an example of how I can do that with an overlay maybe?
I tried with gpio mode *pin number* up and also down but it doesn't seem to work. I tried using sunxi-pio but no changes are made.
Thank you
