hello.
first i want to say thank you to every armbian supporter and the hole team. thanks for providing this nice project and your work.
i did some work for adding an external sound card - the audioinjector pi stereo, which is based on a wm8731.
i used the radxa rockpi4(b)  board based on the rk3399. i choose this board because of pinout header is nearly the same as the one you find on raspberrys. so adding/ using raspberry Hats won´t be too hart in this case.
this will also work with radxa kernel https://github.com/verplant23/kernel
so there shouldn´t be any troubles porting it to armbian legacy.
i´m not a coder and i don´t know about linux that much.  for most things this was try and error of code snippets + lot´s of time.
i tried diffrent ways and there are diffrent ways how thing can be get to work - for sure you guys could make things work better because there are still errors while dmesg.
i used 20.05 dev kernel but basicly this also work on master or current.
please post what you think of or how to improve.
install debs or build your own by adding userpatch from
https://github.com/verplant23/armbian_patch.git
after installing / compiling follow up the armbian docs and add i2c7 by adding
overlays=i2c7
to your /boot/armbianEnv.txt
i wasn´t able to use armbian-add-overlay. because error told me that i don´t use the correct device...
you can use the dtbo inside repo. it was build with the radxa kernel repo (link above). you can find dts inside.
add the folder /boot/overlay-user/  and copy audioinjector-wm8731-audio.dtbo inside
user_overlays=audioinjector-wm8731-audio
after reboot
cat /proc/asound/cards should show up the card
dmesg will show some error:
audioinjector-stereo sound-ext-card: snd_soc_register_card failed (-517)
but since dmesg | grep i2s will show
audioinjector-stereo sound-ext-card: wm8731-hifi <-> ff890000.i2s mapping ok
the device should work.
when getting no sound go to alsamixer and check the mute cases especially  Item: Output Mixer HiFi is not muted
you can make it sound-card-0 by default
sudo nano /etc/modprobe.d/alsa.conf
should be something like
alias snd-card-0 wm8731-hifi
alias snd-card-0 snd_soc_audioinjector_pi_soundcard
alias snd-card-0 snd_soc_simple_card
options snd slots=,hdmisound,rockchiprk3399,snd_soc_audio_graph_card
make sound-card-0 default device
sudo nano /etc/asound.conf
defaults.pcm.card 0
defaults.ctl.card 0
have fun and keep healthy
Edited by verplant23
