goodwinsis Posted June 19, 2020 Posted June 19, 2020 HI, guys. i need help, with my orange pi zero + mpc2515. My connect, is the same as this image. Int connect to PA7. mcp-2515.dtbo: /dts-v1/; /plugin/; / { compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target-path = "/clocks"; __overlay__ { #address-cells = <1>; #size-cells = <1>; can0_osc_fixed: can0_osc_fixed { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <8000000>; }; }; }; fragment@1 { target = <&pio>; __overlay__ { can0_pin_irq: can0_pin_irq { pins = "PA7"; function = "irq"; bias-pull-up; }; }; }; fragment@2 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; mcp2515 { reg = <0>; compatible = "microchip,mcp2515"; pinctrl-names = "default"; pinctrl-0 = <&can0_pin_irq>; spi-max-frequency = <10000000>; interrupt-parent = <&pio>; interrupts = <0 7 2>; /* PA7 IRQ_TYPE_EDGE_FALLING */ clocks = <&can0_osc_fixed>; status = "okay"; }; }; }; }; dmesg | grep spi [ 3.311923] sun6i-spi 1c68000.spi: chipselect 0 already in use [ 3.311943] spi_master spi0: spi_device register error /soc/spi@1c68000/flash@0 [ 3.311964] spi_master spi0: Failed to create SPI device for /soc/spi@1c68000/flash@0 [ 12.137229] mcp251x spi0.0: MCP251x didn't enter in conf mode after reset [ 12.139207] mcp251x spi0.0: Probe failed, err=16 [ 12.139292] mcp251x: probe of spi0.0 failed with error -16 I try change Quote target = <&spi0>; ----> target = <&spi1>; this is solution not work. Thank you in advance for your help.
