JeremyA Posted July 14, 2020 Posted July 14, 2020 (edited) I've downloaded this but there are a few issues. The verification procedures: Verify GPG signature: gpg --verify Armbian_20.05.2_Nanopi-r2s_buster_current_5.4.43.img.asc Verify image file integrity: sha256sum --check Armbian_20.05.2_Nanopi-r2s_buster_current_5.4.43.img.sha should include the .xz Verify GPG signature: gpg --verify Armbian_20.05.2_Nanopi-r2s_buster_current_5.4.43.img.xz.asc Verify image file integrity: sha256sum --check Armbian_20.05.2_Nanopi-r2s_buster_current_5.4.43.img.xz.sha However with the gpg gpg --verify Armbian_20.05.2_Nanopi-r2s_buster_current_5.4.43.img.xz.asc gpg: assuming signed data in 'Armbian_20.05.2_Nanopi-r2s_buster_current_5.4.43.img.xz' gpg: Signature made Wed 03 Jun 2020 06:20:26 AWST gpg: using RSA key DF00FAF1C577104B50BF1D0093D6889F9F0E78D5 gpg: Can't check signature: No public key When installed it performs as expected but doing an apt update apt upgrade shutdown -r 0 results in it wedging. It seems to be updating the firmware amongst other items. I've also run into a problem (not always) that when you enter the mandatory new root password it simply drops the connection. As I said, it doesn't always do this but It's happened at least once so far. Edit: I have had some errors that indicate disk failure. That may explain some of the effects. Tomorrow it's a new flash card to eliminate that possibility. Regards Jeremy Edited July 14, 2020 by JeremyA More information
