DTS overlay to activate I2S DAC 5102a on Armbian Buster 5.4.43
armbian-add-overlay sun50i-h5-i2s0-out.dts
If you don't have headers armbian-config (software->headers)
Manual install whithout headers
mkdir /boot/overlay-user/
dtc -I dts -O dtb sun50i-h5-i2s0-out-no-header.dts -o /boot/overlay-user/sun50i-h5-i2s0-out.dtbo
add user_overlays=sun50i-h5-i2s0-out to /boot/armbianEnv.txt
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun50i-h5";
 	fragment@0 {
 		target-path = "/";
 		__overlay__ {
			pcm5102a: pcm5102a {
				#sound-dai-cells = < 0x00 >;
				compatible = "ti,pcm5102a";
				status = "okay";
				linux,phandle = < 0x26 >;
				phandle = < 0x26 >;
				pcm510x,format = "i2s";
	fragment@1 {
		target-path = "/aliases";
		__overlay__ {
			i2s0 = "/soc/i2s@1c22000";
	fragment@2 {
		target = <&i2s0>;
		__overlay__ {
			status = "okay";
			pinctrl-0 = <&i2s0_pins>;
			sound-dai = <&pcm5102a>;
			pinctrl-names = "default";
	fragment@3 {
		target-path = "/";
		__overlay__ {
			sound_i2s {
				compatible = "simple-audio-card";
				simple-audio-card,name = "I2S-master";
				simple-audio-card,mclk-fs = <256>;
				simple-audio-card,format = "i2s";
		                status = "okay";
				simple-audio-card,cpu {
					sound-dai = <&i2s0>;
				simple-audio-card,codec {
/dts-v1/;
	fragment@0 {
		target-path = [ 2f 00 ];
		__overlay__ {
			pcm5102a {
				status = "okay";
				phandle = < 0x26 >;
	fragment@1 {
		__overlay__ {
	fragment@2 {
		target = < 0xffffffff >;
		__overlay__ {
			status = "okay";
			pinctrl-0 = < 0xffffffff >;
			sound-dai = < 0x26 >;
	fragment@3 {
		__overlay__ {
			sound_i2s {
				simple-audio-card,mclk-fs = < 0x100 >;
				status = "okay";
					sound-dai = < 0xffffffff >;
	__symbols__ {
		pcm5102a = "/fragment@0/__overlay__/pcm5102a";
	__fixups__ {
		i2s0 = "/fragment@2:target:0\0/fragment@3/__overlay__/sound_i2s/simple-audio-card,cpu:sound-dai:0";
		i2s0_pins = "/fragment@2/__overlay__:pinctrl-0:0";
	__local_fixups__ {
		fragment@2 {
			__overlay__ {
				sound-dai = < 0x00 >;
		fragment@3 {
			__overlay__ {
				sound_i2s {
Christian2607 Thanks for manual!
after  aplay -c 2 -D plughw -f S24_LE -r 48000 /dev/urandom
I see only format: S32_LE (not 24 bit) it is normal?
I can't set 24bit mode.
Sorry, all right. aplay convert 24b to 32b, mpd working is normal, output = 24b!
