Rock Pi 4, NVME SSD and kernel 5.4.49 boots 20 Minutes
Any guesses whats wrong? The bootup stucks at [  311.991668] random: crng init done for such a long time with 5.4.49...
That happend on two different ROCK PI 4B 4GB v1.3 with SPI and  NVME SSD boot without SD/eMMC. (fdtfile=rockchip/rk3399-rock-pi-4.dtb).
It is only happening if I disconnect power and boot up. It seems working fine if I just restart the board.
No problems with 4.4.213 Kernel (fdtfile=rockchip/rk3399-rockpi4b.dtb).
It was also working fine with an older version of 5.4.xxx...
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x82
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2018-06-26, version: 1.14
CPUId = 0x0
ChipType = 0x10, 221
Spi_ChipId = b4018
SpiBootInit:0
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 21728
SecureMode = 0
SecureInit ret = 0, SecureMode = 0
GPT vendor signature is wrong
LoadTrust Addr:0x1800
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 1000
Load OK, addr=0x200000, size=0xf162c
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):0e7a845
NOTICE:  BL31: Built : 16:13:46, Apr 17 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-2694-g04d66f4b45 (Jun 28 2020 - 15:00:24 +0000), Build: jenkins-linux-build-release-255
Model: Radxa ROCK Pi 4B
PreSerial: 2
DRAM:  3.9 GiB
Relocation Offset is: f5bde000
Sysmem: init
I2c speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
## Error: "rkimg_bootdev" not defined
Bootdev: mmc 1
MMC: no card present
mmc_init: -123, time 0
rockchip_get_bootdev: can't find dev_desc!
[Vendor ERROR]:Invalid boot device type(0)
mmc_init: -123, time 1
rockchip_get_boot_mode: dev_desc is NULL!
init_resource_list: dev_desc is NULL!
Can't find file:logo.bmp
failed to display uboot logo
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
  aplll 816000 KHz
  apllb 24000 KHz
  dpll 800000 KHz
  cpll 24000 KHz
  gpll 800000 KHz
  npll 600000 KHz
  vpll 24000 KHz
  aclk_perihp 133333 KHz
  hclk_perihp 66666 KHz
  pclk_perihp 33333 KHz
  aclk_perilp0 266666 KHz
  hclk_perilp0 88888 KHz
  pclk_perilp0 44444 KHz
  hclk_perilp1 100000 KHz
  pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
Device 0: RKPARM: Invalid parameter part table
Vendor: 0x126f Rev: S1111B0L Prod: F791931811
            Type: Hard Disk
            Capacity: 122104.3 MB = 119.2 GB (250069680 x 512)
... is now current device
Scanning nvme 0:1...
2940 bytes read in 5 ms (574.2 KiB/s)
## Executing script at 00500000
Boot script loaded from nvme 0
201 bytes read in 4 ms (48.8 KiB/s)
12570575 bytes read in 109 ms (110 MiB/s)
21914112 bytes read in 184 ms (113.6 MiB/s)
73510 bytes read in 16 ms (4.4 MiB/s)
2698 bytes read in 8 ms (329.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 39000000
## Loading init Ramdisk from Legacy Image at 0a200000 ...
   Image Name:   uInitrd
   Data Size:    12570511 Bytes = 12 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 08300000
   Booting using the fdt blob at 0x8300000
   reserving fdt memory region: addr=8300000 size=78000
   Loading Ramdisk to e91c8000, end e9dc4f8f ... OK
   Loading Device Tree to 00000000e914d000, end 00000000e91c7fff ... OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 8997.936 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.49-rockchip64 (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.05.7 SMP PREEMPT Sun Jun 28 18:17:52 UTC 2020
[    0.000000] Machine model: Radxa ROCK Pi 4
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x00000000f0000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xef7e3800-0xef7e4fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s92184 r8192 d30696 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=34234662-7d64-436a-addd-b1765e45b23b rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart= usb-storage.quirks=0x2537:0x106
6:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 3814536K/4061184K available (13052K kernel code, 1880K rwdata, 5164K rodata, 1216K init, 557K bss, 115576K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @ea900000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000ea8a0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000ea8b0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x358/0x4e4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001193] Console: colour dummy device 80x25
[    0.001923] printk: console [tty1] enabled
[    0.002025] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002056] pid_max: default: 32768 minimum: 301
[    0.002177] LSM: Security Framework initializing
[    0.002223] Yama: becoming mindful.
[    0.002363] AppArmor: AppArmor initialized
[    0.002440] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002479] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002544] *** VALIDATE tmpfs ***
[    0.003108] *** VALIDATE proc ***
[    0.003381] *** VALIDATE cgroup1 ***
[    0.003400] *** VALIDATE cgroup2 ***
[    0.027785] ASID allocator initialised with 32768 entries
[    0.035778] rcu: Hierarchical SRCU implementation.
[    0.045567] Platform MSI: interrupt-controller@fee20000 domain created
[    0.045942] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.047460] EFI services will not be available.
[    0.055867] smp: Bringing up secondary CPUs ...
[    0.088091] Detected VIPT I-cache on CPU1
[    0.088122] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.088138] GICv3: CPU1: using allocated LPI pending table @0x00000000ea8c0000
[    0.088179] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.120148] Detected VIPT I-cache on CPU2
[    0.120172] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.120184] GICv3: CPU2: using allocated LPI pending table @0x00000000ea8d0000
[    0.120211] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.152232] Detected VIPT I-cache on CPU3
[    0.152254] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.152266] GICv3: CPU3: using allocated LPI pending table @0x00000000ea8e0000
[    0.152291] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.187098] CPU features: detected: EL2 vector hardening
[    0.187508] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.187922] Detected PIPT I-cache on CPU4
[    0.189139] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.189598] GICv3: CPU4: using allocated LPI pending table @0x00000000ea8f0000
[    0.190831] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.230823] Detected PIPT I-cache on CPU5
[    0.232018] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.232458] GICv3: CPU5: using allocated LPI pending table @0x00000000ea980000
[    0.233583] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.239628] smp: Brought up 1 node, 6 CPUs
[    0.239983] SMP: Total of 6 processors activated.
[    0.240012] CPU features: detected: 32-bit EL0 Support
[    0.240043] CPU features: detected: CRC32 instructions
[    0.251052] CPU: All CPU(s) started at EL2
[    0.251653] alternatives: patching kernel code
[    0.256333] devtmpfs: initialized
[    0.273730] Registered cp15_barrier emulation handler
[    0.274005] Registered setend emulation handler
[    0.274726] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.274813] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.280468] xor: measuring software checksum speed
[    0.318576]    8regs     :  1619.000 MB/sec
[    0.357891]    32regs    :    53.000 MB/sec
[    0.398068]    arm64_neon:    44.000 MB/sec
[    0.398821] xor: using function: 8regs (1619.000 MB/sec)
[    0.404884] pinctrl core: initialized pinctrl subsystem
[    0.450302] DMI not present or invalid.
[    0.470959] NET: Registered protocol family 16
[    0.585711] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.586988] audit: initializing netlink subsys (disabled)
[    0.594801] audit: type=2000 audit(0.588:1): state=initialized audit_enabled=0 res=1
[    0.663830] cpuidle: using governor menu
[    0.680886] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.743730] Serial: AMBA PL011 UART driver
[    2.989471] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    2.990642] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    2.991498] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    2.992844] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    3.124641] cryptd: max_cpu_qlen set to 1000
[    3.354203] raid6: neonx8   gen()    24 MB/s
[    3.421676] raid6: neonx8   xor()    21 MB/s
[    3.490130] raid6: neonx4   gen()    18 MB/s
[    3.559655] raid6: neonx4   xor()    18 MB/s
[    3.629044] raid6: neonx2   gen()    17 MB/s
[    3.695890] raid6: neonx2   xor()    19 MB/s
[    3.767991] raid6: neonx1   gen()    13 MB/s
[    3.837767] raid6: neonx1   xor()    15 MB/s
[    3.906156] raid6: int64x8  gen()    12 MB/s
[    3.975135] raid6: int64x8  xor()     9 MB/s
[    4.041128] raid6: int64x4  gen()    11 MB/s
[    4.109736] raid6: int64x4  xor()     9 MB/s
[    4.178374] raid6: int64x2  gen()     8 MB/s
[    4.246514] raid6: int64x2  xor()     8 MB/s
[    4.320989] raid6: int64x1  gen()     6 MB/s
[    4.389755] raid6: int64x1  xor()     6 MB/s
[    4.390434] raid6: using algorithm neonx8 gen() 24 MB/s
[    4.391086] raid6: .... xor() 21 MB/s, rmw enabled
[    4.392177] raid6: using neon recovery algorithm
[    4.451117] vcc5v0_sys: supplied by vcc12v_dcin
[    4.474120] vcc3v3_pcie: supplied by vcc5v0_sys
[    4.493285] vcc3v3_sys: supplied by vcc5v0_sys
[    4.516559] vcc5v0_host: supplied by vcc5v0_sys
[    4.538694] vcc5v0_typec: supplied by vcc5v0_sys
[    4.578273] iommu: Default domain type: Translated
[    4.696268] vgaarb: loaded
[    4.722650] SCSI subsystem initialized
[    4.743883] usbcore: registered new interface driver usbfs
[    4.747547] usbcore: registered new interface driver hub
[    4.753355] usbcore: registered new device driver usb
[    4.784041] pps_core: LinuxPPS API ver. 1 registered
[    4.784842] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    4.786358] PTP clock support registered
[    4.800296] EDAC MC: Ver: 3.0.0
[    4.848498] NetLabel: Initializing
[    4.849869] NetLabel:  domain hash size = 128
[    4.850499] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    4.854977] NetLabel:  unlabeled traffic allowed by default
[    4.875973] clocksource: Switched to clocksource arch_sys_counter
[    9.888143] *** VALIDATE bpf ***
[    9.901227] VFS: Disk quotas dquot_6.6.0
[    9.905927] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    9.911582] *** VALIDATE ramfs ***
[    9.912886] *** VALIDATE hugetlbfs ***
[    9.952638] AppArmor: AppArmor Filesystem Enabled
[   10.308245] thermal_sys: Registered thermal governor 'fair_share'
[   10.308456] thermal_sys: Registered thermal governor 'bang_bang'
[   10.309445] thermal_sys: Registered thermal governor 'step_wise'
[   10.310162] thermal_sys: Registered thermal governor 'user_space'
[   10.310874] thermal_sys: Registered thermal governor 'power_allocator'
[   10.342870] NET: Registered protocol family 2
[   10.386850] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[   10.397799] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[   10.426586] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[   10.466106] TCP: Hash tables configured (established 32768 bind 32768)
[   10.475088] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   10.485062] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   10.504959] NET: Registered protocol family 1
[   10.506783] NET: Registered protocol family 44
[   10.508561] PCI: CLS 0 bytes, default 64
[   10.521363] Trying to unpack rootfs image as initramfs...
[   63.050757] Freeing initrd memory: 12272K
[   63.096051] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[   63.114259] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[   63.136468] kvm [1]: IPA Size Limit: 40bits
[   63.173300] kvm [1]: vgic-v2@fff20000
[   63.175981] kvm [1]: GIC system register CPU interface enabled
[   63.185519] kvm [1]: vgic interrupt IRQ10
[   63.198128] kvm [1]: Hyp mode initialized successfully
[   63.459818] Initialise system trusted keyrings
[   63.462162] Key type blacklist registered
[   63.468970] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[   63.822719] zbud: loaded
[   63.933971] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   63.976756] fuse: init (API version 7.31)
[   63.982670] *** VALIDATE fuse ***
[   63.984293] *** VALIDATE fuse ***
[   64.056256] Platform Keyring initialized
[   65.341995] Key type asymmetric registered
[   65.342809] Asymmetric key parser 'x509' registered
[   65.345832] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[   65.354254] io scheduler mq-deadline registered
[   65.356083] io scheduler kyber registered
[   65.364900] io scheduler bfq registered
[   66.166690] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[   66.169375] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[   66.181242] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[   66.184207] rockchip-pcie f8000000.pcie:   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[   66.186222] rockchip-pcie f8000000.pcie:    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[   66.200785] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[   66.201901] pci_bus 0000:00: root bus resource [bus 00-1f]
[   66.202833] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[   66.204600] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[   66.206842] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[   66.213316] pci 0000:00:00.0: supports D1
[   66.214193] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[   66.468824] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   66.477041] pci 0000:01:00.0: [126f:2263] type 00 class 0x010802
[   66.480383] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[   66.484150] pci 0000:01:00.0: Upstream bridge's Max Payload Size set to 128 (was 256, max 256)
[   66.485409] pci 0000:01:00.0: Max Payload Size set to 128 (was 128, max 128)
[   66.494007] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x4 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8 GT/s x4 link)
[   66.745204] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[   66.746863] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[   66.748844] pci 0000:01:00.0: BAR 0: assigned [mem 0xfa000000-0xfa003fff 64bit]
[   66.750343] pci 0000:00:00.0: PCI bridge to [bus 01]
[   66.751941] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[   66.760710] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[   66.776636] pcieport 0000:00:00.0: PME: Signaling with IRQ 227
[   66.789896] pcieport 0000:00:00.0: AER: enabled with IRQ 227
[   67.124470] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[   67.125769] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[   67.206629] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[   67.208621] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[   67.378760] pwm-regulator: supplied by regulator-dummy
[   67.448441] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[   67.601580] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[   67.611737] serial serial0: tty port ttyS0 registered
[   67.642446] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[   67.929000] printk: console [ttyS2] enabled
[   67.986289] Serial: AMBA driver
[   68.054313] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   68.677156] loop: module loaded
[   68.774003] nvme nvme0: pci function 0000:01:00.0
[   68.781339] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[   68.927867] libphy: Fixed MDIO Bus: probed
[   68.952512] tun: Universal TUN/TAP device driver, 1.6
[   69.008450] thunder_xcv, ver 1.0
[   69.013754] thunder_bgx, ver 1.0
[   69.017889] nicpf, ver 1.0
[   69.077073] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[   69.078864] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[   69.085607] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[   69.088167] igb: Copyright (c) 2007-2014 Intel Corporation.
[   69.092523] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[   69.094537] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[   69.112546] sky2: driver version 1.30
[   69.153780] VFIO - User Level meta-driver version: 0.3
[   69.444482] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   69.447935] ehci-pci: EHCI PCI platform driver
[   69.452139] ehci-platform: EHCI generic platform driver
[   69.469467] ehci-platform fe380000.usb: EHCI Host Controller
[   69.476188] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[   69.486445] ehci-platform fe380000.usb: irq 31, io mem 0xfe380000
[   69.505034] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   69.520040] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   69.522479] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   69.525010] usb usb1: Product: EHCI Host Controller
[   69.526555] usb usb1: Manufacturer: Linux 5.4.49-rockchip64 ehci_hcd
[   69.528774] usb usb1: SerialNumber: fe380000.usb
[   69.553668] hub 1-0:1.0: USB hub found
[   69.557438] hub 1-0:1.0: 1 port detected
[   69.595863] ehci-platform fe3c0000.usb: EHCI Host Controller
[   69.598381] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[   69.606803] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
[   69.625024] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[   69.638490] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   69.641449] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   69.643945] usb usb2: Product: EHCI Host Controller
[   69.645472] usb usb2: Manufacturer: Linux 5.4.49-rockchip64 ehci_hcd
[   69.647581] usb usb2: SerialNumber: fe3c0000.usb
[   69.677157] hub 2-0:1.0: USB hub found
[   69.681099] hub 2-0:1.0: 1 port detected
[   69.717145] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   69.721446] ohci-pci: OHCI PCI platform driver
[   69.729087] ohci-platform: OHCI generic platform driver
[   69.744302] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   69.747878] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[   69.756795] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
[   69.828331] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[   69.829525] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   69.830178] usb usb3: Product: Generic Platform OHCI controller
[   69.830712] usb usb3: Manufacturer: Linux 5.4.49-rockchip64 ohci_hcd
[   69.831356] usb usb3: SerialNumber: fe3a0000.usb
[   69.846324] hub 3-0:1.0: USB hub found
[   69.850108] hub 3-0:1.0: 1 port detected
[   69.882346] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[   69.886160] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[   69.895851] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
[   69.964062] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
[   69.965118] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   69.965872] usb usb4: Product: Generic Platform OHCI controller
[   69.966413] usb usb4: Manufacturer: Linux 5.4.49-rockchip64 ohci_hcd
[   69.967343] usb usb4: SerialNumber: fe3e0000.usb
[   69.988912] hub 4-0:1.0: USB hub found
[   69.992737] hub 4-0:1.0: 1 port detected
[   70.062344] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   70.066028] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[   70.072517] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[   70.074190] xhci-hcd xhci-hcd.0.auto: irq 229, io mem 0xfe800000
[   70.100209] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   70.102052] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   70.107835] usb usb5: Product: xHCI Host Controller
[   70.108565] usb usb5: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   70.109144] usb usb5: SerialNumber: xhci-hcd.0.auto
[   70.125307] hub 5-0:1.0: USB hub found
[   70.129840] hub 5-0:1.0: 1 port detected
[   70.153513] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   70.156410] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[   70.160051] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[   70.164254] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   70.171903] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   70.173786] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   70.176825] usb usb6: Product: xHCI Host Controller
[   70.178407] usb usb6: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   70.180671] usb usb6: SerialNumber: xhci-hcd.0.auto
[   70.210356] hub 6-0:1.0: USB hub found
[   70.214075] hub 6-0:1.0: 1 port detected
[   70.246062] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   70.253013] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[   70.264261] usb 3-1: new low-speed USB device number 2 using ohci-platform
[   70.264600] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[   70.267006] xhci-hcd xhci-hcd.1.auto: irq 230, io mem 0xfe900000
[   70.291966] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   70.294397] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   70.297019] usb usb7: Product: xHCI Host Controller
[   70.298572] usb usb7: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   70.300923] usb usb7: SerialNumber: xhci-hcd.1.auto
[   70.324889] hub 7-0:1.0: USB hub found
[   70.328965] nvme nvme0: allocated 64 MiB host memory buffer.
[   70.331433] hub 7-0:1.0: 1 port detected
[   70.336461] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[   70.337039] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[   70.342806] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[   70.349505] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[   70.359909] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   70.362313] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   70.365852] usb usb8: Product: xHCI Host Controller
[   70.368613] usb usb8: Manufacturer: Linux 5.4.49-rockchip64 xhci-hcd
[   70.370430] usb usb8: SerialNumber: xhci-hcd.1.auto
[   70.405454] hub 8-0:1.0: USB hub found
[   70.409386] hub 8-0:1.0: 1 port detected
[   70.441769] usbcore: registered new interface driver usb-storage
[   70.529698] usb 3-1: New USB device found, idVendor=04f2, idProduct=0420, bcdDevice= 1.50
[   70.533156] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   70.536307] usb 3-1: Product: USB Wireless HID Receiver
[   70.537527] mousedev: PS/2 mouse device common for all mice
[   70.537937] usb 3-1: Manufacturer: Chicony
[   70.551611] i2c /dev entries driver
[   70.568026] rk808 0-001b: chip id: 0x0
[   70.578792] rk808-regulator rk808-regulator: there is no dvs0 gpio
[   70.579764] rk808-regulator rk808-regulator: there is no dvs1 gpio
[   70.580474] DCDC_REG1: supplied by vcc5v0_sys
[   70.586390] DCDC_REG2: supplied by vcc5v0_sys
[   70.587755] DCDC_REG3: supplied by vcc5v0_sys
[   70.588560] DCDC_REG4: supplied by vcc5v0_sys
[   70.589830] LDO_REG1: supplied by vcc5v0_sys
[   70.590139] nvme nvme0: 6/0/0 default/read/poll queues
[   70.592537] LDO_REG2: supplied by vcc5v0_sys
[   70.594117] LDO_REG3: supplied by vcc5v0_sys
[   70.596594] LDO_REG4: supplied by vcc5v0_sys
[   70.599167] LDO_REG5: supplied by vcc5v0_sys
[   70.600784] LDO_REG6: supplied by vcc5v0_sys
[   70.602512] LDO_REG7: supplied by vcc5v0_sys
[   70.607938] LDO_REG8: supplied by vcc5v0_sys
[   70.616698] SWITCH_REG1: supplied by vcc3v3_sys
[   70.617994] SWITCH_REG2: supplied by vcc3v3_sys
[   70.623533] random: fast init done
[   70.625180] rk808-rtc rk808-rtc: registered as rtc0
[   70.626951] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[   70.627678] fan53555-reg: supplied by vcc5v0_sys
[   70.672034] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[   70.675979] fan53555-reg: supplied by vcc5v0_sys
[   70.686179]  nvme0n1: p1
[   71.055981] sdhci: Secure Digital Host Controller Interface driver
[   71.057883] sdhci: Copyright(c) Pierre Ossman
[   71.060786] Synopsys Designware Multimedia Card Interface Driver
[   71.135634] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[   71.139666] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[   71.141769] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[   71.146096] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[   71.157992] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[   71.160556] mmc_host mmc0: card is non-removable.
[   71.193474] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[   71.245806] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[   71.249612] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[   71.252324] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[   71.256851] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[   71.268696] dwmmc_rockchip fe320000.dwmmc: Got CD GPIO
[   71.289036] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[   71.296901] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[   71.301188] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[   71.305042] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[   71.318147] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[   71.335759] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[   71.338116] sdhci-pltfm: SDHCI platform and OF driver helper
[   71.419852] mmc2: CQHCI version 5.10
[   71.473820] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[   71.522216] ledtrig-cpu: registered to indicate activity on CPUs
[   71.557819] hidraw: raw HID events driver (C) Jiri Kosina
[   71.564256] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[   71.669637] input: Chicony USB Wireless HID Receiver as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:04F2:0420.0001/input/input0
[   71.761393] hid-generic 0003:04F2:0420.0001: input,hidraw0: USB HID v1.11 Keyboard [Chicony USB Wireless HID Receiver] on usb-fe3a0000.usb-1/input0
[   71.885926] input: Chicony USB Wireless HID Receiver Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:04F2:0420.0002/input/input1
[   71.964216] input: Chicony USB Wireless HID Receiver System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:04F2:0420.0002/input/input2
[   71.990739] hid-generic 0003:04F2:0420.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Chicony USB Wireless HID Receiver] on usb-fe3a0000.usb-1/input1
[   72.060382] input: Chicony USB Wireless HID Receiver as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.2/0003:04F2:0420.0003/input/input4
[   72.080004] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 217
[   72.086237] hid-generic 0003:04F2:0420.0003: input,hidraw2: USB HID v1.11 Mouse [Chicony USB Wireless HID Receiver] on usb-fe3a0000.usb-1/input2
[   72.097021] usbcore: registered new interface driver usbhid
[   72.098681] usbhid: USB HID core driver
[   72.262175] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[   72.296829] drop_monitor: Initializing network drop monitor service
[   72.344947] NET: Registered protocol family 10
[   74.236361] Segment Routing with IPv6
[   74.243932] NET: Registered protocol family 17
[   74.248518] 8021q: 802.1Q VLAN Support v1.8
[   74.252914] Key type dns_resolver registered
[   74.282371] registered taskstats version 1
[   74.284426] Loading compiled-in X.509 certificates
[   74.464768] Loaded X.509 cert 'Build time autogenerated kernel key: 2565b613495ac291b85be09f25a86121f1587c31'
[   74.478215] zswap: loaded using pool lzo/zbud
[   74.490329] Key type ._fscrypt registered
[   74.492530] Key type .fscrypt registered
[   74.642765] Btrfs loaded, crc32c=crc32c-generic
[   74.650116] Key type big_key registered
[   75.504124] Key type encrypted registered
[   75.508177] AppArmor: AppArmor sha1 policy hashing enabled
[   78.034472] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:51:31 UTC (1358499091)
[   78.037833] of_cfs_init
[   78.040540] of_cfs_init: OK
[   78.129404] Freeing unused kernel memory: 1216K
[   78.136410] Run /init as init process
[  105.946689] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[  105.947383] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[  105.948116] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[  105.949127] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[  105.949769] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[  105.950292] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[  105.950850] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[  105.951500] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[  105.952125] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[  105.957687] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[  105.959657] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[  105.960316] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[  105.960790] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[  105.961462] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[  105.962133] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[  105.962604] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[  105.963287] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[  105.963940] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[  105.964473] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[  105.964999] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  106.111005] libphy: stmmac: probed
[  106.111394] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[  106.112513] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1324.404128] EXT4-fs (nvme0n1p1): mounted filesystem with writeback data mode. Opts: (null)
[ 1335.562211] systemd[1]: System time before build time, advancing clock.
[ 1336.050455] systemd[1]: Inserted module 'autofs4'
[ 1337.290643] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN
-PCRE2 default-hierarchy=hybrid)
[ 1337.348340] systemd[1]: Detected architecture arm64.
[ 1337.773198] systemd[1]: Set hostname to <rockpi-4b>.
[ 1339.004963] ttyS2 - failed to request DMA
[ 1348.962846] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:10: Support for option SysVStartPriority= has been removed and it is ignored
[ 1353.830305] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1353.889823] systemd[1]: Listening on udev Control Socket.
[ 1353.928466] systemd[1]: Listening on udev Kernel Socket.
[ 1354.168987] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 1354.221931] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1354.268367] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 1354.304754] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1354.325939] systemd[1]: Reached target Local Encrypted Volumes.
[ 1354.345313] systemd[1]: Reached target Paths.
[ 1354.369302] systemd[1]: Reached target System Time Synchronized.
[ 1354.389100] systemd[1]: Reached target Remote File Systems.
[ 1354.485061] systemd[1]: Created slice User and Session Slice.
[ 1354.506683] systemd[1]: Reached target Slices.
[ 1357.845108] EXT4-fs (nvme0n1p1): re-mounted. Opts: commit=600,errors=remount-ro
[ 1359.215846] systemd[1]: Starting Load/Save Random Seed...
[ 1359.249182] systemd[1]: Starting Create System Users...
[ 1359.278133] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 1359.572871] systemd[1]: Mounting FUSE Control File System...
[ 1359.837876] systemd[1]: Mounting Kernel Configuration File System...
[ 1360.082351] systemd[1]: Starting Apply Kernel Variables...
[ 1360.156022] systemd[1]: Started Load/Save Random Seed.
[ 1360.168267] systemd[1]: Started Create System Users.
[ 1360.174046] systemd[1]: Mounted FUSE Control File System.
[ 1360.177977] systemd[1]: Mounted Kernel Configuration File System.
[ 1367.934819] zram: Added device: zram0
[ 1367.970633] zram: Added device: zram1
[ 1368.006772] zram: Added device: zram2
[ 1369.159053] zram1: detected capacity change from 0 to 1073741824
[ 1369.628750] Adding 1048572k swap on /dev/zram1.  Priority:5 extents:1 across:1048572k SSFS
[ 1372.029571] cpufreq: cpufreq_online: CPU4: Running at unlisted freq: 12000 KHz
[ 1372.036362] cpufreq: cpufreq_online: CPU4: Unlisted initial frequency changed to: 408000 KHz
[ 1372.057822] systemd[1]: Started udev Coldplug all Devices.
[ 1372.063074] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[ 1372.073361] zram0: detected capacity change from 0 to 52428800
[ 1372.080467] systemd[1]: Started Helper to synchronize boot up for ifupdown.
[ 1372.085974] systemd[1]: Starting Raise network interfaces...
[ 1372.125676] systemd[1]: Started Armbian ZRAM config.
[ 1372.132140] systemd[1]: Found device /dev/ttyS2.
[ 1372.148211] rockchip-vop ff8f0000.vop: Adding to iommu group 1
[ 1372.151003] rockchip-vop ff900000.vop: Adding to iommu group 2
[ 1372.159296] systemd[1]: Starting Armbian memory supported logging...
[ 1372.163676] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[ 1372.164456] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1372.167253] Bluetooth: Core ver 2.22
[ 1372.167613] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[ 1372.167853] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1372.170378] NET: Registered protocol family 31
[ 1372.171885] Bluetooth: HCI device and connection manager initialized
[ 1372.172934] Bluetooth: HCI socket layer initialized
[ 1372.173031] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1372.173398] Bluetooth: L2CAP socket layer initialized
[ 1372.173464] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[ 1372.173468] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1372.173469] [drm] No driver support for vblank timestamp query.
[ 1372.174969] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1372.175287] Bluetooth: SCO socket layer initialized
[ 1372.175826] cfg80211: failed to load regulatory.db
[ 1372.198392] Bluetooth: HCI UART driver ver 2.3
[ 1372.198864] Bluetooth: HCI UART protocol H4 registered
[ 1372.199317] Bluetooth: HCI UART protocol BCSP registered
[ 1372.199852] Bluetooth: HCI UART protocol LL registered
[ 1372.200307] Bluetooth: HCI UART protocol ATH3K registered
[ 1372.201181] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1372.203054] Bluetooth: HCI UART protocol Intel registered
[ 1372.204914] Bluetooth: HCI UART protocol Broadcom registered
[ 1372.205384] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
[ 1372.205452] Bluetooth: HCI UART protocol QCA registered
[ 1372.206269] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
[ 1372.206616] Bluetooth: HCI UART protocol AG6XX registered
[ 1372.212412] Bluetooth: HCI UART protocol Marvell registered
[ 1372.222226] es8316 1-0011: Failed to get IRQ 0: -22
[ 1372.224571] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[ 1372.225235] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[ 1372.231056] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[ 1372.233174] usbcore: registered new interface driver brcmfmac
[ 1372.234875] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,rockpi4.txt failed with error -2
[ 1372.241328] mc: Linux media interface: v0.10
[ 1372.256052] videodev: Linux video capture interface: v2.00
[ 1372.268214] Console: switching to colour frame buffer device 240x67
[ 1372.295955] rockchip-rga ff680000.rga: HW Version: 0x03.02
[ 1372.296171] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[ 1372.296977] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[ 1372.300783] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[ 1372.302939] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[ 1372.303074] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[ 1372.322437] rockchip-drm display-subsystem: fb0: rockchipdrmfb frame buffer device
[ 1372.327054] ttyS0 - failed to request DMA
[ 1372.344425] panfrost ff9a0000.gpu: clock rate = 500000000
[ 1372.345263] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[ 1372.352659] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[ 1372.353860] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[ 1372.357811] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[ 1372.363783] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[ 1372.372905] systemd[1]: Started Raise network interfaces.
[ 1372.389619] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[ 1372.510445] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 1372.515319] systemd[1]: Starting Load/Save RF Kill Switch Status...
[ 1372.519001] asoc-audio-graph-card sound: ES8316 HiFi <-> ff880000.i2s mapping ok
[ 1372.519862] asoc-audio-graph-card sound: ASoC: no DMI vendor name!
[ 1372.534620] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 1372.534648] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name!
[ 1372.576960] Bluetooth: hci1: BCM: chip id 130
[ 1372.579165] Bluetooth: hci1: BCM: features 0x0f
[ 1372.605826] Bluetooth: hci1: BCM4345C5
[ 1372.605837] Bluetooth: hci1: BCM4345C5 (003.006.006) build 0000
[ 1374.026828] systemd-journald[677]: Received request to flush runtime journal from PID 1
[ 1374.347971] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
[ 1374.359193] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 1374.370900] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Jun 16 2017 12:38:26 version 7.45.96.2 (66c4e21@sh-git) (r) FWID 01-1813af84
[ 1374.405561] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1374.411754] Bluetooth: BNEP filters: protocol multicast
[ 1374.411774] Bluetooth: BNEP socket layer initialized
[ 1374.903479] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet]
[ 1374.907746] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[ 1374.916742] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[ 1374.916758] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[ 1376.141309] Bluetooth: hci1: BCM4345C5 (003.006.006) build 0038
[ 1376.148703] Bluetooth: hci1: BCM: Using default device address (43:45:c5:00:1f:ac)
[ 1379.003280] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 1379.015427] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Armbian 20.05.3 Buster ttyS2
rockpi-4b login:
Edited by eg0lf
new information
