In order to review the Tinker Board boot logs via serial console, I set up armbianEnv.txt to get the logs.
But Armbian didn't output anything. Can anyone tell me what is wrong?
As long as I reviewed boot.cmd, the serial port was assigned to /dev/ttyS2. So I used UART2 GPIO pins (GP7C7 for TX, GP7C6 for RX) to interact.
(snip)
if test "${console}" = "serial" || test "${console}" = "both"; then setenv consoleargs "console=ttyS2,115200n8 ${consoleargs}"; fi
(snip)
The barudrate is 115200.
Of course, I re-checked my connection between USB-UART serial cable and UART2 GPIO pins (USB-UART RX to GP7C7TX, USB-UART TX to GP7C6 RX).
Any information is helpful and appreciated.
Thanks.
Referenced Doc:
https://docs.armbian.com/User-Guide_Allwinner_overlays/#example-bootarmbianenvtxt-contents
my armbianEnv.txt:
I added console=serial.
verbosity=1
console=serial
overlay_prefix=rockchip
overlays=i2c1 i2c4 spi2 spidev2 uart1 uart2
rootdev=UUID=(stripped)
rootfstype=ext4
USB UART Cable:
FTDI TTL-232R-3V3
Board Product:
ASUS Tinker Board (Power supply via GPIO, 5V4A)
Armbian Image File:
Armbian_20.05.2_Tinkerboard_buster_current_5.4.44_minimal.img.xz
OS Info:
root@tinkerboard:/boot# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=tinkerboard
BOARD_NAME="Tinkerboard"
BOARDFAMILY=rockchip
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=2efd215a
DISTRIBUTION_CODENAME=buster
DISTRIBUTION_STATUS=supported
VERSION=20.05.2
LINUXFAMILY=rockchip
BRANCH=current
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
root@tinkerboard:/boot# uname -a
Linux tinkerboard 5.4.44-rockchip #20.05.2 SMP PREEMPT Wed Jun 3 10:43:15 CEST 2020 armv7l GNU/Linux
Unplugged the Tinker Board, took a break for several hours, established a serial port session to FTDI serial port from my laptop, then plug in TB again.
And I can see the serial port output.
Not sure what mattered. But now everything works.
