MattCostamagna Posted August 13, 2020 Posted August 13, 2020 Armbianmonitor: http://ix.io/2u3r Hi, I'm facing a problem with my Orange Pi Zero with the latest Armbian version. I noticed that when I provide an internet connection type that is not valid (wrong psk, ethernet but no cable plugged in, etc.) and I reboot the system, it hangs just before asking the username and password. Sometimes it takes up to 10 minutes before keeping going. These are the last boot logs that I see: [ 11.209226] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 11.219428] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped. [ 11.244988] systemd[1]: Started Nameserver information manager. [ 11.254315] systemd[1]: Reached target Network (Pre). [ 11.264815] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 11.274833] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 11.293312] systemd[1]: Starting Load Kernel Modules... [ 11.317312] systemd[1]: Starting Remount Root and Kernel File Systems... [ 11.343632] systemd[1]: Starting udev Coldplug all Devices... [ 11.376556] systemd[1]: Mounted POSIX Message Queue File System. [ 11.386689] systemd[1]: Mounted Kernel Debug File System. [ 11.396501] systemd[1]: Mounted Kernel Trace File System. [ 11.413706] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 11.416094] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 11.458472] systemd[1]: Finished Remount Root and Kernel File Systems. [ 11.472062] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 11.481213] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.505488] systemd[1]: Starting Load/Save Random Seed... [ 11.514898] systemd[1]: Condition check resulted in Create System Users being skipped. [ 11.553531] systemd[1]: Starting Create Static Device Nodes in /dev... [ 11.583442] g_serial gadget: Gadget Serial v2.4 [ 11.588174] g_serial gadget: g_serial ready [ 11.610410] systemd[1]: Finished Load Kernel Modules. [ 11.626029] systemd[1]: Finished Load/Save Random Seed. [ 11.650175] systemd[1]: Mounting FUSE Control File System... [ 11.671958] systemd[1]: Mounting Kernel Configuration File System... [ 11.694089] systemd[1]: Starting Apply Kernel Variables... [ 11.724736] systemd[1]: Mounted FUSE Control File System. [ 11.741343] systemd[1]: Finished Create Static Device Nodes in /dev. [ 11.751604] systemd[1]: Mounted Kernel Configuration File System. [ 11.776484] systemd[1]: Starting udev Kernel Device Manager... [ 12.843290] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22 **Usually here after a couple of seconds I'm asked to provide the username and password** After that the system hangs for a very long time. I stopped and disabled NetworkManager-wait-online.service but nothing changed. Is there something else that prevents the boot phase to finish before having established the connection? Thanks a lot Mattia
MattCostamagna Posted August 13, 2020 Author Posted August 13, 2020 I found out that the networking.service has a param called TimeoutStartSec that defaults to 5min in /lib/systemd/system/networking.service. I lowered that value to 15 seconds and the problem is gone. Here's a useful command: sed -i -r 's/TimeoutStartSec=.*/TimeoutStartSec=15/' /lib/systemd/system/networking.service
