I'm trying to get an MCP2515 working with an Orange Pi Zero LTS H2+.  Everything seems to go well until I try to bring up the can0 interface using the command
ip link set can0 up type can bitrate 500000
Once the command is entered, it never returns.  Control+C doesn't do help.  New SSH sessions fail to start, but pinging the IP address works fine.  Trying
ifconfig
from the serial terminal will also fail to return.
Trying to shutdown after the "ip link set..." command, the shutdown procedure takes a long time, and eventually sends
[ 4320.026984] systemd-shutdown[1]: Waiting for process: ifdown, wpa_supplicant, NetworkManager, ip
The image was built using the git clone and config commands, per https://docs.armbian.com/Developer-Guide_Build-Preparation/, using a Lubuntu VM.  Image is "Current", "Ubuntu Focal".
The overlay was based on https://github.com/armbian/sunxi-DT-overlays/blob/master/examples/spi-mcp251x.dts, with
target = <&spi0>;
changed to
target = <&spi1>;
In dmesg, the MCP2515 appears to be working
mcp251x spi1.0 can0: MCP2515 successfully initialized.
Any tips on how to debug?
I have same issue.
cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=spi-add-cs1 spi-spidev usbhost2 usbhost3
param_spidev_spi_bus=1
param_spidev_spi_cs=1
rootdev=UUID=442e3394-ebc5-4a14-82f8-235d74d6b2e5
rootfstype=ext4
user_overlays=spi-mcp251x
cat spi-mcp251x.dts
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5";
	fragment@0 {
		target-path = "/clocks";
		__overlay__ {
			#address-cells = <1>;
			#size-cells = <1>;
			can0_osc_fixed: can0_osc_fixed {
				compatible = "fixed-clock";
				#clock-cells = <0>;
				clock-frequency  = <8000000>;
	fragment@1 {
		target = <&pio>;
		__overlay__ {
			can0_pin_irq: can0_pin_irq {
				pins = "PA7";
				function = "irq";
				bias-pull-up;
	fragment@2 {
		target = <&spi1>;
		__overlay__ {
			#size-cells = <0>;
			status = "okay";
			mcp2515 {
				reg = <0>;
				compatible = "microchip,mcp2515";
				pinctrl-names = "default";
				pinctrl-0 = <&can0_pin_irq>;
				spi-max-frequency = <10000000>;
				interrupt-parent = <&pio>;
				interrupts = <0 7 2>; /* PA7 IRQ_TYPE_EDGE_FALLING */
				clocks = <&can0_osc_fixed>;
				status = "okay";
Pins:
https://forum.mysensors.org/uploads/files/1483990620622-orange-pi-zero-description.jpg
cat /etc/armbian-release
BOARD=orangepizero
BOARD_NAME="Orange Pi Zero"
BOARDFAMILY=sun8i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=e6fa811d-dirty
DISTRIBUTION_CODENAME=buster
DISTRIBUTION_STATUS=supported
VERSION=20.08.1
LINUXFAMILY=sunxi
BRANCH=current
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
ip -s -d link show can0
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
    link/can  promiscuity 0 minmtu 0 maxmtu 0
    can state STOPPED restart-ms 0
	  mcp251x: tseg1 3..16 tseg2 2..8 sjw 1..4 brp 1..64 brp-inc 1
	  clock 4000000
	  re-started bus-errors arbit-lost error-warn error-pass bus-off
	  0          0          0          0          0          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    RX: bytes  packets  errors  dropped overrun mcast
    0          0        0       0       0       0
    TX: bytes  packets  errors  dropped carrier collsns
    0          0        0       0       0       0
After command sudo ip link set can0 up type can bitrate 125000:
new conn to ssh - no
sudo -s  - no
netstat - no
but new windows in tmux - working
Edited by mav
I have the same issue with latest Armbian Focal and Nanopi Neo.
I can add that if I have many ssh sessions I can use all commands exept those regarding networking.
These are the processes and interrups I can see:
1477 ?        I      0:00 [kworker/0:0-events]
 1496 ?        I      0:00 [kworker/0:2-events]
 1497 ?        I      0:00 [kworker/3:1-events]
 1508 pts/0    D+     0:00 ifconfig can0 up
 1509 ?        D      0:00 [irq/67-spi1.0]
 1510 ?        I<     0:00 [mcp251x_wq]
 1511 ttyS0    D+     0:00 ip -s -d link show can0
 1512 ?        I      0:00 [kworker/1:0-mm_percpu_wq]
 1513 ?        I      0:00 [kworker/2:0-events]
 1516 ?        I      0:00 [kworker/0:3-events]
 1517 ?        I      0:00 [kworker/3:0-events_power_efficient]
 1522 pts/1    R+     0:00 ps -ax
root@nanopineo:~# cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
 17:          0          0          0          0     GICv2  50 Level     timer@1c20c00
 18:          0          0          0          0     GICv2  29 Level     arch_timer
 19:      10173       5154       5328      13484     GICv2  30 Level     arch_timer
 22:          0          0          0          0     GICv2  82 Level     1c02000.dma-controller
 24:       7436          0          0          0     GICv2  92 Level     sunxi-mmc
 25:        819          0          0          0     GICv2  94 Level     sunxi-mmc
 27:          1          0          0          0     GICv2 103 Level     musb-hdrc.2.auto
 28:          0          0          0          0     GICv2 104 Level     ehci_hcd:usb1
 29:          0          0          0          0     GICv2 105 Level     ohci_hcd:usb2
 30:          0          0          0          0     GICv2 106 Level     ehci_hcd:usb3
 31:          0          0          0          0     GICv2 107 Level     ohci_hcd:usb6
 32:          0          0          0          0     GICv2 108 Level     ehci_hcd:usb4
 33:          0          0          0          0     GICv2 109 Level     ohci_hcd:usb7
 34:        167          0          0          0     GICv2 110 Level     ehci_hcd:usb5
 35:          0          0          0          0     GICv2 111 Level     ohci_hcd:usb8
 39:        494          0          0          0     GICv2 114 Level     eth0
 40:         13          0          0          0     GICv2  98 Level     sun6i-spi
 42:       2288          0          0          0     GICv2  32 Level     ttyS0
 43:          0          0          0          0  sun6i-r-intc   8 Level     1f00000.rtc
 46:          0          0          0          0     GICv2 125 Level     1400000.deinterlace
 47:          0          0          0          0     GICv2  90 Level     1c0e000.video-codec
 48:          0          0          0          0     GICv2 126 Level     sun8i-ce-ns
 56:       4245          0          0          0     GICv2  63 Level     ths
 57:          0          0          0          0     GICv2 152 Level     arm-pmu
 58:          0          0          0          0     GICv2 153 Level     arm-pmu
 59:          0          0          0          0     GICv2 154 Level     arm-pmu
 60:          0          0          0          0     GICv2 155 Level     arm-pmu
 67:          1          0          0          0  sunxi_pio_edge   6 Edge      spi1.0
105:          1          0          0          0  sunxi_pio_edge  44 Edge      usb0-id-det
128:          1          0          0          0  sunxi_pio_edge   3 Edge      k1
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       2044       4286       3803       3567  Rescheduling interrupts
IPI3:        650        719        542        718  Function call interrupts
IPI4:          0          0          0          0  CPU stop interrupts
IPI5:       3193        113        233       1245  IRQ work interrupts
IPI6:          0          0          0          0  completion interrupts
Err:          0
Any help?
Thanks.
Edited by Werner
Add code
Update:
if I use a previous kernel version everything works:
root@nanopineo:~# hostnamectl
   Static hostname: nanopineo
         Icon name: computer
        Machine ID: 6f25fe73523b462c903f2c486e612f38
           Boot ID: a687cc17d9d6443c9c091c01fbabece0
  Operating System: Ubuntu 20.04 LTS
            Kernel: Linux 5.4.45-sunxi
      Architecture: arm
root@nanopineo:~# ip link set can0 type can bitrate 12500
root@nanopineo:~# ip link set can0 up
root@nanopineo:~# candump can0 &
[1] 1839
root@nanopineo:~# cansend can0 AAA#11223344
root@nanopineo:~# cat /proc/net/can/stats
        3 transmitted frames (TXF)
        0 received frames (RXF)
        0 matched frames (RXMF)
        0 % total match ratio (RXMR)
        0 frames/s total tx rate (TXR)
        0 frames/s total rx rate (RXR)
        0 % current match ratio (CRXMR)
        0 frames/s current tx rate (CTXR)
        0 frames/s current rx rate (CRXR)
        0 % max match ratio (MRXMR)
        1 frames/s max tx rate (MTXR)
        0 frames/s max rx rate (MRXR)
        1 current receive list entries (CRCV)
        1 maximum receive list entries (MRCV)
        1 statistic resets (STR)
Any updates?
Observe same issue with the Kernel 5.9.14 and the OrangePI Zero. With the Kernel 5.4.45 the interface works fine.
Is this bug in 5 kernel versions or was the configuration for the can interface changed in the Version 5.5.x?
At this point, about everything broke for sunxi H3
https://github.com/torvalds/linux/commit/50ec88120ea16cf8b9aabf8422c364166ce3ee17#diff-55b4d8281f6fd3fe6b7b66da9ae5e9ce818e02b8ac9b23260593fd551c22fdc1
5.4.100  mcp2515 can -   work
5.5.rc1   mcp2515 can -   not work
If you copy the source codes of the mcp2515 driver from linux 5.4.100 to the sources on 5.10.19 and build them in Buildroot, everything will work. checked.
Edited by Aleksey
Platform under test NanoPi NEO with MCP2515 8Mhz module spi 0,0
linux 5.4.100 mcp2515 work
Сhanges made to the MCP2515 driver led to the fact that when calling commands
Цитата
Цитата
can: mcp251x: get rid of legacy platform data
Instead of using legacy platform data, switch to use device properties. For clock frequency we are using well established clock-frequency property. Users, two for now, are also converted here.
or
ifconfig can0 up
to hang the system in a terminal window
see foto terminal.
Цитата
INIT_WORK(&priv->tx_work, mcp251x_tx_work_handler);
    INIT_WORK(&priv->restart_work, mcp251x_restart_work_handler);
    /*mcp251x_gpio_restore;*/
    ret = mcp251x_hw_reset(spi);
     * ret = mcp251x_hw_wake(spi);
     * problem sunxi H3
A temporary solution to the problem
Calling
ret = mcp251x_hw_wake (spi);
this subroutine leads to a hang in the terminal on sunxi H3 boards when entering the command
or
ifconfig can0 up
return to call
ret = mcp251x_hw_reset (spi);
fixes this problem Linux 5.5 - 5.11.2   for sunxi H3  (example Nano Pi NEO,modul MCP2515 8mhz)
mcp251x.c
Причина зависания терминала на этих платах (на примере Nanopi NEO) кроется в этой функции
при попытке отключить прерывания disable_irq (spi-> irq);
Если закомментировать данный вызов, зависаний не произойдет.
The reason for the terminal freezing on these boards (as an example of Nanopi NEO) occurs in this function
when trying to disable interrupts disable_irq(spi->irq);
If you comment out this given call, the hangs do not occur.
static int mcp251x_hw_wake(struct spi_device *spi)
u8 value;
int ret;
/* Force wakeup interrupt to wake device, but don't execute IST */
mcp251x_write_2regs(spi, CANINTE, CANINTE_WAKIE, CANINTF_WAKIF);
/* Wait for oscillator startup timer after wake up */
mdelay(MCP251X_OST_DELAY_MS);
/* Put device into config mode */
mcp251x_write_reg(spi, CANCTRL, CANCTRL_REQOP_CONF);
/* Wait for the device to enter config mode */
ret = mcp251x_read_stat_poll_timeout(spi, value, value == CANCTRL_REQOP_CONF,
    MCP251X_OST_DELAY_MS * 1000,
    USEC_PER_SEC);
if (ret) {
dev_err(&spi->dev, "MCP251x didn't enter in config mode\n");
return ret;
/* Disable and clear pending interrupts */
mcp251x_write_2regs(spi, CANINTE, 0x00, 0x00);
enable_irq(spi->irq);
return 0;
Настройка платы NanoPI NEO Devicetree
Setting up the NanoPI NEO board Devicetree
clocks {
            #size-cells = <1>;
            ranges;
                            #clock-cells = <0>;
pio: pinctrl@1c20800 {
/* compatible is in per SoC .dtsi file */
          reg = <0x01c20800 0x400>;
          interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>,
          <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
          clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&rtc 0>;
          clock-names = "apb", "hosc", "losc";
          gpio-controller;
          #gpio-cells = <3>;
         interrupt-controller;
          #interrupt-cells = <3>;
                pins = "PG8";
                function = "irq";
                bias-pull-up;
spi0: spi@1c68000 {
compatible = "allwinner,sun8i-h3-spi";
reg = <0x01c68000 0x1000>;
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
clock-names = "ahb", "mod";
dmas = <&dma 23>, <&dma 23>;
dma-names = "rx", "tx";
pinctrl-0 = <&spi0_pins>;
resets = <&ccu RST_BUS_SPI0>;
status = "okay";
#size-cells = <0>;
can0: can@0 {
            reg = <0>;
            interrupts = <6 8 IRQ_TYPE_EDGE_FALLING>;
            gpio-controller;
           #gpio-cells = <2>;
           status = "okay";
Экспериментальный модуль MCP2515 с частотой 8 МГц
Experimental module MCP2515 with a frequency of 8 MHz
TJA1050 replaced by SN65HVD230
TJA1050 заменен на SN65HVD230 на 3,3 В
10 часов назад, Marc Kleine-Budde сказал:
Вы включили CONFIG_PM в своем .config?
It seems that in my experiments I got lost in the wrong place)
I was led astray mainly by this information.
With the default driver and with the correct parameters, everything works and the terminal does not freeze,
here are the correct DT settings as an example for Nano PI NEO
clocks {
                            #clock-cells = <0>;
          gpio-controller;
          #gpio-cells = <3>;
                pins = "PG8";
                function = "irq";
                bias-pull-up;
spi0: spi@1c68000 {
status = "okay";
#size-cells = <0>;
can0: can@0 {
            reg = <0>;
            interrupts = <6 8 IRQ_TYPE_LEVEL_LOW>; /*  This is the correct meaning */
            gpio-controller;
           #gpio-cells = <2>;
           status = "okay";
If someone was confused by my search for a solution to the problem, I am sorry.
If you set IRQ_TYPE_EDGE_FALLING, the terminal will hang.
This parameter leads to the terminal freezing when calling functions ret = mcp251x_hw_wake(spi);
, and in it functions  to disable interrupts disable_irq(spi->irq)
