Downloaded the image file Armbian_20.08_Rockpro64_buster_current_5.7.15_desktop.img.
Using the Etcher utility, I burned the image to the SD Card.
Installed SD Card in RockPro64.
The system does not start.
The exact same problem is observed with Armbian_20.08_Rockpro64_focal_current_5.7.15_desktop.img.
If I write the Armbian_20.05.2_Rockpro64_buster_current_5.4.43_desktop.img image to the SD Card, then the system starts and installs normally.
Then I use apt update and apt upgrade, as a result, the system is updated to version 5.7.15.
I am trying to transfer the system to a connected SSD, after which the system stops booting.
PS Sorry for my English.
Edited by AlexVS
The problem was in the Marwell 9230 controller. If you replace this controller with a Marwell 9235, then everything works fine.
