Starting a new thread after this one solved my question: https://forum.armbian.com/topic/15044-how-to-re-format-and-remount-and-redo-lvm-volume-on-ssd/?tab=comments#comment-107672
but taking care of those things wasn't the root cause. it turns out the drive wasn't unmounted cleanly after accidentally unplugging the power cable from the board.
I had a drive setup using:
pvcreate /dev/nvme0n1
vgcreate rockpro64 /dev/nvme0n1
lvcreate -n <name> -L 500g rockpro64
then i formatted like this:
mkfs.ext4 /dev/rockpro64/name
but then i accidentally unplugged the power source while i got my system up and running
it wasn't cleanly unmounted and now when i try to run the system again i get errors relating to what i created and it's mount point, so i'm wondering what to do to revert back to default settings. I tried reflashing the OS image again, but the same errors still applied so there is something still going on with the drive from when I accidentally unplugged it.
Any tips or help would be greatly appreciated!
