percu Posted September 16, 2020 Posted September 16, 2020 Armbianmonitor: http://ix.io/2xLj Hi all! I have Orange Pi One with Armbian Debian 5.8.9-sunxi on board. The problem is that when I catch 2 kHz square wave with OPi gpio, I have very big delta between signals. If I use "interrupt both endges" parameter for gpio, time between signals must be 250 microsecs. But now it floats between 200 - 290 microsecs. And I have achive this result after some suggestions from other forum topics: using isolcpu=3, run c program on this cpu, use max priority, disable powersaving for CPU. I try to read with wiringOP lib, and directly from sysfs, but still have jittering about 90 us. Also I think, that I have not very bad results for cyclictest: # cyclictest -a -t -n -p80 # /dev/cpu_dma_latency set to 0us policy: fifo: loadavg: 0.00 0.00 0.00 1/127 2335 T: 0 ( 2332) P:80 I:1000 C: 32762 Min: 8 Act: 11 Avg: 12 Max: 98 T: 1 ( 2333) P:80 I:1500 C: 21841 Min: 8 Act: 19 Avg: 11 Max: 48 T: 2 ( 2334) P:80 I:2000 C: 16381 Min: 8 Act: 9 Avg: 12 Max: 113 T: 3 ( 2335) P:80 I:2500 C: 13104 Min: 10 Act: 10 Avg: 10 Max: 16 The main quieston is - does direct programming /dev/mem gpio registers helps me to decrease floating between receiving signals? May be other suggestions? Please, help! Thank you!
