dolphs Posted September 27, 2020 Share Posted September 27, 2020 In this tutorial we build a custom .config for OrangePiOnePlus board, eg: to remove blutooth, WiFi and or USB3.x support since the hardware is not onboard, alternatively you can adjust settings to your needs which is not in the default .config. The section mentions, if file " userpatches/linux-$KERNELFAMILY-$KERNELBRANCH.config " exists, it will be used instead of default one from " config ". This means for the OPiOnePlus : " linux-sunxi64-dev.config " should be created, but please note "dev" is just one of the three options available, which are: " current ", " legacy " and " dev " The default config files are located in : " /armbian/config/kernel " and thus also holds a "linux-sunxi64-dev.config " config file. # #If user-provided kernel .config file IS NOT present yet # cd ~ git clone --depth 1 https://github.com/armbian/build armbian cd armbian ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=yes EXTRAWIFI=no BOARD=orangepioneplus Yet rename ".config" and Save to " ~/userpatches/linux-sunxi64-dev.config " , find attached a screenshot # #If user-provided kernel .config file IS present # <script> cp -p ~/armbian/userpatches/linux-sunxi64-dev.config ~/ sudo rm -rf armbian git clone --depth 1 https://github.com/armbian/build armbian mkdir ~/armbian/userpatches cp -p ~/linux-sunxi64-dev.config ~/armbian/userpatches/ </script> Above can be scripted so you do not need to worry if for some reason you need to remove and rebuild your " armbian " directory from scratch Rest would be ( assuming your kernel has been customised to your needs ): cd armbian ./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no EXTRAWIFI=no BOARD=orangepioneplus Hope this addition to user-provided-kernel-config explains the idea " in depth " . Happy configuring :-) 1 Link to comment Share on other sites More sharing options...
