Hi, I've been trying to get the next IMU sensor to work:  Fusion_IMU_BNO055, on my OPi zero with Armbian Bionic 20.08.10 with the linux kernel 5.8.14-sunxi. I have installed everything from the official Adafruit guide but I still get the same error.
I have followed all the steps of this guide for beginners: OPi_r1_guide, executing all the commands successfully.  However, I still have the same error in Python that is related to the "board" module.
root@orangepizero:/home/Test# python
Python 3.6.9 (default, Oct  8 2020, 12:12:24)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import board
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python3.6/dist-packages/board.py", line 82, in <module>
    from adafruit_blinka.board.orangepi.orangepizero import *
  File "/usr/local/lib/python3.6/dist-packages/adafruit_blinka/board/orangepi/orangepizero.py", line 5, in <module>
    from adafruit_blinka.microcontroller.allwinner.h3 import pin
  File "/usr/local/lib/python3.6/dist-packages/adafruit_blinka/microcontroller/allwinner/h3/pin.py", line 4, in <module>
    PA0 = Pin(0)
  File "/usr/local/lib/python3.6/dist-packages/adafruit_blinka/microcontroller/generic_linux/libgpiod_pin.py", line 34, in __init__
    self._chip = gpiod.Chip("gpiochip0", gpiod.Chip.OPEN_BY_NAME)
AttributeError: module 'gpiod' has no attribute 'Chip'
>>> exit()
The python code that I try to execute is the following:
import board
import digitalio
import busio
print("Hello blinka!")
# Try to great a Digital input
pin = digitalio.DigitalInOut(board.PA6)
print("Digital IO ok!")
# Try to create an I2C device
i2c = busio.I2C(board.SCL, board.SDA)
print("I2C ok!")
# Try to create an SPI device
spi = busio.SPI(board.SCLK, board.MOSI, board.MISO)
print("SPI ok!")
print("done!")
If you need more details I will gladly give them to you. Thank you.
