Nanopi R2S - USB Serial Gadget not working after boot
I have previously successfully been using the USB serial gadget as terminal on the Nanopi R2S.
The last working release I have tried was:
Linux 5.4.45-rockchip64 #20.05.3 SMP PREEMPT Wed Jun 10 11:47:27 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux
Now I am running the following version (Also tried 20.08.08) and the gadget mode does not work after boot.
Linux 5.8.14-rockchip64 #20.08.10 SMP PREEMPT Tue Oct 13 16:58:01 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux
I have seen no warnings or error messages when running dmesg.
After boot on the failing versions the log contains the following section, which I assume means that the driver loads OK.
[    7.831558] g_serial gadget: Gadget Serial v2.4
[    7.831573] g_serial gadget: g_serial ready
[    7.831594] dwc2 ff580000.usb: bound driver g_serial
The device node exists
ls -l /dev/ttyGS0
crw--w---- 1 root tty 241, 0 Oct 16 12:32 /dev/ttyGS0
The service seems to be working
 systemctl status serial-getty@ttyGS0.service
● serial-getty@ttyGS0.service - Serial Getty on ttyGS0
     Loaded: loaded (/lib/systemd/system/serial-getty@.service; enabled; vendor preset: enabled)
    Drop-In: /usr/lib/systemd/system/serial-getty@.service.d
             └─10-term.conf
     Active: active (running) since Fri 2020-10-16 12:32:22 CEST; 2min 52s ago
       Docs: man:agetty(8)
             man:systemd-getty-generator(8)
             http://0pointer.de/blog/projects/serial-console.html
   Main PID: 973 (agetty)
      Tasks: 1 (limit: 998)
     Memory: 304.0K
     CGroup: /system.slice/system-serial\x2dgetty.slice/serial-getty@ttyGS0.service
             └─973 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyGS0 linux
Only restarting the service has not effect, but by running the following sequence I have been able to restore functionality (until next reboot).
sudo modprobe -r g_serial
sudo modprobe g_serial
sudo systemctl restart serial-getty@ttyGS0.service
Any idea on how to fix this permanently?
The quickest, hackest workaround is adding the modprobe and systemctl restart command to /etc/rc.local, but first let's see the kernel logs
What does dmesg show after removing the g_serial module, and also after re-adding the module? Also be good to see the systemctl status for the working state
This is dmesg after removing g_serial
[  645.489033] printk: console [ttyGS0] disabled
After re-adding the module
[  729.112172] g_serial gadget: Gadget Serial v2.4
[  729.112181] g_serial gadget: g_serial ready
[  729.112191] dwc2 ff580000.usb: bound driver g_serial
[  729.233924] dwc2 ff580000.usb: new device is high-speed
[  729.269376] dwc2 ff580000.usb: new address 42
The status when working
             └─10-term.conf
     Active: active (running) since Tue 2020-10-20 10:11:39 CEST; 9s ago
       Docs: man:agetty(8)
   Main PID: 1898 (agetty)
     Memory: 232.0K
             └─1898 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyGS0 linux
That's a big difference for the dwc2 driver messages.  Perhaps gwc2 or g_serial depend on something that's not yet loaded. Comparing lsmod from the working and non-working states might help. It's a bit surprising that ttyGS0 exists when dwc2 didn't log that it found a device. Also that the getty could work with it.  How about posting more dmesg info: dmesg | egrep -i 'serial|tty|dwc|usb|console'
This is the output from dmesg
[    0.000000] Kernel command line: root=UUID=50b7bf20-3a17-4ad2-be5d-1c3b48cc6ab8 rootwait rootfstype=ext4 console=ttyS2,1500000  consoleblank=0 loglevel=1 ubootpart=b554da78-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.001105] Console: colour dummy device 80x25
[    0.203340] Serial: AMBA PL011 UART driver
[    1.380801] usbcore: registered new interface driver usbfs
[    1.380899] usbcore: registered new interface driver hub
[    1.381042] usbcore: registered new device driver usb
[    3.386585] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned
[    3.389390] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[    3.407732] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.412937] printk: console [ttyS2] disabled
[    3.413080] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 12, base_baud = 1500000) is a 16550A
[    3.413235] printk: console [ttyS2] enabled
[    3.414857] Serial: AMBA driver
[    3.455134] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[    3.455172] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[    3.458142] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    3.458343] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    3.585600] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    3.586293] dwc2 ff580000.usb: DWC OTG Controller
[    3.586342] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    3.586445] dwc2 ff580000.usb: irq 29, io mem 0xff580000
[    3.586801] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.586813] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.586829] usb usb1: Product: DWC OTG Controller
[    3.586839] usb usb1: Manufacturer: Linux 5.8.14-rockchip64 dwc2_hsotg
[    3.586852] usb usb1: SerialNumber: ff580000.usb
[    3.588094] hub 1-0:1.0: USB hub found
[    3.590785] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.593610] ehci-platform ff5c0000.usb: EHCI Host Controller
[    3.593657] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[    3.593927] ehci-platform ff5c0000.usb: irq 30, io mem 0xff5c0000
[    3.609535] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    3.609974] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.609987] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.610003] usb usb2: Product: EHCI Host Controller
[    3.610013] usb usb2: Manufacturer: Linux 5.8.14-rockchip64 ehci_hcd
[    3.610026] usb usb2: SerialNumber: ff5c0000.usb
[    3.611030] hub 2-0:1.0: USB hub found
[    3.611961] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.612827] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    3.612867] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    3.613103] ohci-platform ff5d0000.usb: irq 31, io mem 0xff5d0000
[    3.673884] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[    3.673897] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.673914] usb usb3: Product: Generic Platform OHCI controller
[    3.673924] usb usb3: Manufacturer: Linux 5.8.14-rockchip64 ohci_hcd
[    3.673936] usb usb3: SerialNumber: ff5d0000.usb
[    3.674957] hub 3-0:1.0: USB hub found
[    3.677001] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    3.678300] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.678314] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.678330] usb usb4: Product: xHCI Host Controller
[    3.678340] usb usb4: Manufacturer: Linux 5.8.14-rockchip64 xhci-hcd
[    3.678355] usb usb4: SerialNumber: xhci-hcd.0.auto
[    3.679345] hub 4-0:1.0: USB hub found
[    3.680079] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    3.680114] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.680246] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.680503] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[    3.680515] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.680532] usb usb5: Product: xHCI Host Controller
[    3.680542] usb usb5: Manufacturer: Linux 5.8.14-rockchip64 xhci-hcd
[    3.680557] usb usb5: SerialNumber: xhci-hcd.0.auto
[    3.681617] hub 5-0:1.0: USB hub found
[    3.682671] usbcore: registered new interface driver usb-storage
[    3.783323] usbcore: registered new interface driver usbhid
[    3.783330] usbhid: USB HID core driver
[    3.948041] friendlyelec-board board: Serial         : bd82a41207725d80
[    3.960286] dw-apb-uart ff130000.serial: forbid DMA for kernel console
[    4.017740] usb 5-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    4.038916] usb 5-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[    4.038937] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    4.038951] usb 5-1: Product: USB 10/100/1000 LAN
[    4.038961] usb 5-1: Manufacturer: Realtek
[    4.038979] usb 5-1: SerialNumber: 000000000000
[    7.441048] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.453938] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    7.712709] systemd[1]: Starting Set the console keyboard layout...
[    7.982073] g_serial gadget: Gadget Serial v2.4
[    7.982088] g_serial gadget: g_serial ready
[    7.982108] dwc2 ff580000.usb: bound driver g_serial
[    8.104286] dwc2 ff580000.usb: new device is high-speed
[    8.140862] dwc2 ff580000.usb: new address 40
[    8.424866] systemd[1]: Finished Set the console keyboard layout.
[    8.609200] systemd[1]: Starting Set console font and keymap...
[    8.666789] systemd[1]: Finished Set console font and keymap.
[    8.883878] systemd[1]: Found device /dev/ttyGS0.
[    9.721050] systemd[1]: Found device /dev/ttyS2.
[    9.968289] dwc2 ff580000.usb: new device is high-speed
[   10.004894] dwc2 ff580000.usb: new address 41
[   10.336469] usb 5-1: reset SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[   10.423366] usbcore: registered new interface driver r8152
