Benoît Clouet Posted October 21, 2020 Posted October 21, 2020 Hi all, I'm trying to port a driver built for Raspberry Zero to Banana Pi M2 Zero. The original driver is here : https://github.com/pguyot/tagtagtag-ears (it's supposed to drive the ears of a Nabaztag, which recently got resurected thanks to an Ulule campaign). My understanding is that at least half of the problem is to adapt the device tree overlay for the BPI M2 Zero. If it"s not half of the work, it's definitely required. So far I've been unsuccessful. The original DTS overlay is like this : /dts-v1/; /plugin/; / { compatible = "brcm,bcm2708"; fragment@0 { target = <&gpio>; __overlay__ { gpio_encoder_left_pin: gpio_encoder_left_pin@24 { brcm,pins = <24>; brcm,function = <0>; // in }; gpio_encoder_right_pin: gpio_encoder_right_pin@23 { brcm,pins = <23>; brcm,function = <0>; // in }; // left: when looking at the rabbit (matching hardware spec) // forward: for the rabbit's left ear (right), counter-clock-wise // for the rabbit's right ear (left below), clock-wise gpio_motor_left_forward_pin: gpio_motor_left_forward_pin@12 { brcm,pins = <12>; brcm,function = <1>; // out }; gpio_motor_left_backward_pin: gpio_motor_left_backward_pin@11 { brcm,pins = <11>; brcm,function = <1>; // out }; gpio_motor_right_forward_pin: gpio_motor_right_forward_pin@10 { brcm,pins = <10>; brcm,function = <1>; // out }; gpio_motor_right_backward_pin: gpio_motor_right_backward_pin@9 { brcm,pins = <9>; brcm,function = <1>; // out }; }; }; fragment@1 { target-path="/"; __overlay__ { tagtagtag_ears: tagtagtag-ears { compatible = "linux,tagtagtag-ears"; left-encoder-gpio = <&gpio 24 0>; left-motor-gpios = <&gpio 12 0 &gpio 11 0>; right-encoder-gpio = <&gpio 23 0>; right-motor-gpios = <&gpio 10 0 &gpio 9 0>; // Declare a single pinctrl state (referencing the one declared above) and name it // default, so it is activated automatically. pinctrl-names = "default"; pinctrl-0 = <&gpio_encoder_left_pin &gpio_motor_left_forward_pin &gpio_motor_left_backward_pin &gpio_encoder_right_pin &gpio_motor_right_forward_pin &gpio_motor_right_backward_pin>; }; }; }; }; I tried to adapt it following what I understand from the schematics of the device and the documentation of the BPI M2 Zero board. It resulted in the version below : /dts-v1/; /plugin/; / { compatible = "sinovoip,bpi-m2-zero\0allwinner,sun8i-h2-plus"; fragment@0 { target = <&pio>; __overlay__ { gpio_encoder_left_pin: gpio_encoder_left_pin@24 { //pins = <24>; pins = "PC4"; function = <0>; // in }; gpio_encoder_right_pin: gpio_encoder_right_pin@23 { //pins = <23>; pins = "PA15"; function = <0>; // in }; // left: when looking at the rabbit (matching hardware spec) // forward: for the rabbit's left ear (right), counter-clock-wise // for the rabbit's right ear (left below), clock-wise gpio_motor_left_forward_pin: gpio_motor_left_forward_pin@12 { //pins = <12>; pins = "PA2"; function = <1>; // out }; gpio_motor_left_backward_pin: gpio_motor_left_backward_pin@11 { //pins = <11>; pins = "PC2"; function = <1>; // out }; gpio_motor_right_forward_pin: gpio_motor_right_forward_pin@10 { //pins = <10>; pins = "PC0"; function = <1>; // out }; gpio_motor_right_backward_pin: gpio_motor_right_backward_pin@9 { //pins = <9>; pins = "PC1"; function = <1>; // out }; }; }; fragment@1 { target-path="/"; __overlay__ { tagtagtag_ears: tagtagtag-ears { compatible = "linux,tagtagtag-ears"; //left-encoder-gpio = <&gpio 24 0>; left-encoder-gpio = <&gpio 24 0>; left-motor-gpios = <&gpio 12 0 &gpio 11 0>; right-encoder-gpio = <&gpio 23 0>; right-motor-gpios = <&gpio 10 0 &gpio 9 0>; // Declare a single pinctrl state (referencing the one declared above) and name it // default, so it is activated automatically. pinctrl-names = "default"; pinctrl-0 = <&gpio_encoder_left_pin &gpio_motor_left_forward_pin &gpio_motor_left_backward_pin &gpio_encoder_right_pin &gpio_motor_right_forward_pin &gpio_motor_right_backward_pin>; }; }; }; }; I just changed the compatible clause and the pins definition trying to follow the indications in the documentation here https://docs.armbian.com/User-Guide_Allwinner_overlays/#using-custom-overlays without much success. Would someone have an idea or more useful, an example of such portage ? I already looked at the Device Tree for dummies but I think I need some more directions to look at. Thanks in advance for your help, Benoît
