Welcome screen only showing at local login, not over ssh
This is a minor issue, but I'm hoping to get it solved as I've enjoyed the welcome screen for so long. For whatever reason after running my installation script which I've been using for years, the welcome screen changes when logging in over ssh. This happened some months ago. Any ideas on how or where I should look?
  ___      _           _     _   _   _ ____
 / _ \  __| |_ __ ___ (_) __| | | \ | |___ \
| | | |/ _` | '__/ _ \| |/ _` | |  \| | __) |
| |_| | (_| | | | (_) | | (_| | | |\  |/ __/
 \___/ \__,_|_|  \___/|_|\__,_| |_| \_|_____|
Welcome to Armbian 20.08.17 Focal with Linux 5.8.16-meson64
System load:   2%           	Up time:       7 min
Memory usage:  4% of 3.55G  	IP:            192.168.0.28
CPU temp:      27°C           	Usage of /:    1% of 480G
[ General system configuration (beta): armbian-config ]
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
To:
Last login: Tue Oct 27 23:17:54 2020 from MYIP
USER@HOSTNAME:~$
  • Z11ntal33r changed the title to Welcome screen only showing at local login, not over ssh
