wintifrosch Posted November 3, 2020 Posted November 3, 2020 Armbianmonitor: http://ix.io/2CRI I successfully installed Armbian Focal¹ on my Neo Core 2 with MiniShield² and SSD. I find no issues after booting boot from SD-card. But I fail to boot from eMMC with System on SATA using nand-sata-install: In the serial console i see the boot process to stick after «Started udev Kernel Device Manager». Any hints how I can unblock from here? [...] U-Boot 2020.04-armbian (Sep 02 2020 - 09:50:54 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO Core 2 DRAM: 512 MiB MMC: mmc@1c0f000: 0, mmc@1c11000: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial Out: serial Err: serial Net: No ethernet found. MMC: no card present MMC: no card present starting USB... Bus usb@1c1b000: USB EHCI 1.00 scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found [...] Boot script loaded from mmc [...] Starting kernel ... [...] Welcome to Armbian 20.08.1 Focal! [...] [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... Starting udev Kernel Device Manager... [ OK ] Mounted /tmp. [ OK ] Started udev Kernel Device Manager. [ OK ] Found device /dev/ttyGS0. ¹ Armbian_20.08.1_Nanopineocore2_focal_current_5.8.5_minimal.img ² Armbian forum about Neo Core 2 with MiniShield
