ODroid HC4 mounts mmc but does not boot Armbian_20.08.22_Odroidhc4_buster_current_5.9.6
Is there something more I need to do?  The sd card seems to be mounted when I probe it from the resulting shell.
Suspicious log entry here: "Detected platform type: powerpc"
Dump of log and udevadm info for the mmc follow:
Thanks in advance.
/tmp # cat /var/log/petitboot/pb-discover.log
--- pb-discover ---
platform: no IPMI parameter support
lang: C
Running command:
 exe:  nvram
 argv: 'nvram' '--print-config' '--partition' 'common'
configuration:
 autoboot: enabled, 10 sec
  boot device 0: uuid: 38134ed4-1dfc-4c75-8c88-3907a06ce55c
  IPMI boot device 0x00
  Modifications allowed to disks: yes
  Default UI to boot on: ttyS0,115200n8
    (Manually set)
  HTTP Proxy:
  HTTPS Proxy:
 language:
Interface eth0 ready
Running command:
 exe:  /sbin/ip
 argv: '/sbin/ip' 'link' 'set' 'eth0' 'up'
network: bringing up interface eth0
SKIP: mmcblk0: no ID_FS_TYPE property
Error executing dm-task
Error creating snapshot
Error creating snapshot devices for mmcblk0p1
mounting device /dev/mmcblk0p1 read-only
trying parsers for mmcblk0p1
Running command:
 exe:  /usr/sbin/pb-plugin
 argv: '/usr/sbin/pb-plugin' 'scan' '/usr/var/petitboot/mnt/dev/mmcblk0p1'
Scanning device /usr/var/petitboot/mnt/dev/mmcblk0p1
No plugins found
SKIP: mtdblock0: no ID_FS_TYPE property
SKIP: mtdblock1: no ID_FS_TYPE property
SKIP: mtdblock2: no ID_FS_TYPE property
SKIP: mtdblock3: no ID_FS_TYPE property
SKIP: loop0: no ID_FS_TYPE property
SKIP: loop1: no ID_FS_TYPE property
SKIP: loop2: no ID_FS_TYPE property
SKIP: loop3: no ID_FS_TYPE property
SKIP: loop4: no ID_FS_TYPE property
SKIP: loop5: no ID_FS_TYPE property
SKIP: loop6: no ID_FS_TYPE property
SKIP: loop7: no ID_FS_TYPE property
Running command:
 exe:  /sbin/ip
 argv: '/sbin/ip' 'link' 'set' 'lo' 'up'
Running command:
 exe:  /sbin/ip
SKIP: dm-0: no ID_FS_TYPE property
SKIP: dm-2: no ID_FS_TYPE property
SKIP: dm-1: no ID_FS_TYPE property
network: configuring interface eth0
Running command:
 exe:  /sbin/udhcpc
 argv: '/sbin/udhcpc' '-R' '-f' '-O' 'pxeconffile' '-O' 'pxepathprefix' '-p' '/usr/var/petitboot//udhcpc-eth0.pid' '-i' 'eth0' '-x' '0x5d:000e'
udhcpc: started, v1.26.2
udhcpc: sending discover
udhcpc: sending select for 192.168.11.124
udhcpc: lease of 192.168.11.124 obtained, lease time 86400
deleting routers
adding dns 192.168.11.1
trying parsers for eth0
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-V'
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-UORgEU' '-r' '/pxelinux.cfg/01-00-1e-06-49-03-1b' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-zMh6Zz' '-r' '/pxelinux.cfg/C0A80B7C' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-7JO4da' '-r' '/pxelinux.cfg/C0A80B7' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-UaAklF' '-r' '/pxelinux.cfg/C0A80B' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-69Hvk5' '-r' '/pxelinux.cfg/C0A80' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-pC0kaq' '-r' '/pxelinux.cfg/C0A8' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-JUezTF' '-r' '/pxelinux.cfg/C0A' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-6NqmvQ' '-r' '/pxelinux.cfg/C0' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-mrxJYV' '-r' '/pxelinux.cfg/C' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-HKVWkW' '-r' '/pxelinux.cfg/default' '192.168.11.1' '69'
tftp: timeout
new configuration data received
configuration:
    (Manually set)
 language:
lang: C
Running command:
 exe:  nvram
 argv: 'nvram' '--update-config' 'petitboot,write?=' '--partition' 'common'
Running command:
 exe:  nvram
 argv: 'nvram' '--flush-config'
unmounting device /dev/mmcblk0p1
udhcpc: received SIGTERM
udhcpc: unicasting a release of 192.168.11.124 to 192.168.11.1
udhcpc: sending release
udhcpc: entering released state
Running command:
 exe:  /sbin/ip
 argv: '/sbin/ip' 'address' 'flush' 'dev' 'eth0'
Running command:
 exe:  /sbin/ip
 argv: '/sbin/ip' 'link' 'set' 'eth0' 'down'
udev: reinit requested, starting enumeration
Running command:
 exe:  /sbin/ip
Running command:
No plugins found
Running command:
 exe:  /sbin/ip
Running command:
 exe:  /sbin/ip
Running command:
 exe:  /sbin/udhcpc
deleting routers
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-KFhbz0' '-r' '/pxelinux.cfg/01-00-1e-06-49-03-1b' '192.168.11.1' '69'
Running command:
 exe:  /sbin/ip
Running command:
 exe:  /sbin/ip
Running command:
 exe:  /sbin/ip
Running command:
No plugins found
Running command:
 exe:  /sbin/ip
Running command:
 exe:  /sbin/ip
Running command:
 exe:  /sbin/udhcpc
deleting routers
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-gf9pW3' '-r' '/pxelinux.cfg/01-00-1e-06-49-03-1b' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-s4mhEb' '-r' '/pxelinux.cfg/C0A80B7C' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-bMzt3d' '-r' '/pxelinux.cfg/C0A80B7' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-BpOV9a' '-r' '/pxelinux.cfg/C0A80B' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-GNNaY2' '-r' '/pxelinux.cfg/C0A80' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-S2LztP' '-r' '/pxelinux.cfg/C0A8' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-5Hcozw' '-r' '/pxelinux.cfg/C0A' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-xeumn8' '-r' '/pxelinux.cfg/C0' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-isYVSE' '-r' '/pxelinux.cfg/C' '192.168.11.1' '69'
tftp: timeout
Running command:
 exe:  /usr/bin/tftp
 argv: '/usr/bin/tftp' '-g' '-l' '/tmp/pb-cCLW55' '-r' '/pxelinux.cfg/default' '192.168.11.1' '69'
tftp: timeout
/usr/bin # udevadm info  /dev/mmcblk0p1
P: /devices/platform/ffe05000.sd/mmc_host/sd/sd:59b4/block/mmcblk0/mmcblk0p1
N: mmcblk0p1
S: disk/by-id/mmc-SDU1_0x00335492-part1
S: disk/by-partuuid/690b40ba-01
S: disk/by-path/platform-ffe05000.sd-part1
S: disk/by-uuid/38134ed4-1dfc-4c75-8c88-3907a06ce55c
E: DEVLINKS=/dev/disk/by-id/mmc-SDU1_0x00335492-part1 /dev/disk/by-path/platform-ffe05000.sd-part1 /dev/disk/by-partuuid/690b40ba-01 /dev/disk/by-uuid/38134ed4-1dfc-4c75-8c88-3907a06ce55c
E: DEVNAME=/dev/mmcblk0p1
E: DEVPATH=/devices/platform/ffe05000.sd/mmc_host/sd/sd:59b4/block/mmcblk0/mmcblk0p1
E: DEVTYPE=partition
E: ID_FS_TYPE=ext4
E: ID_FS_USAGE=filesystem
E: ID_FS_UUID=38134ed4-1dfc-4c75-8c88-3907a06ce55c
E: ID_FS_UUID_ENC=38134ed4-1dfc-4c75-8c88-3907a06ce55c
E: ID_FS_VERSION=1.0
E: ID_NAME=SDU1
E: ID_PART_ENTRY_DISK=179:0
E: ID_PART_ENTRY_NUMBER=1
E: ID_PART_ENTRY_OFFSET=8192
E: ID_PART_ENTRY_SCHEME=dos
E: ID_PART_ENTRY_SIZE=3514368
E: ID_PART_ENTRY_TYPE=0x83
E: ID_PART_ENTRY_UUID=690b40ba-01
E: ID_PART_TABLE_TYPE=dos
E: ID_PART_TABLE_UUID=690b40ba
E: ID_PATH=platform-ffe05000.sd
E: ID_PATH_TAG=platform-ffe05000_sd
E: ID_SERIAL=0x00335492
E: MAJOR=179
E: MINOR=1
E: PARTN=1
E: SUBSYSTEM=block
E: TAGS=:systemd:
