vatech Posted November 29, 2020 Posted November 29, 2020 Hello, i had installed Raspbian OS on bpi M2 zero and the power button was working fine. After switching to Armbian (Focal - Buster , etc), i have problem with the power button that does not work anymore. The images were released for the specific board, but although the power button doesnt work. Additional, the installed SPI LCD, when powered off using raspbian, the backlight was deactivated (so power on GPIO was also off) Now with Armbian, even if i shutdown via command, the backlight remains on. Any suggestions?
