nand-sata-install : SPI u-boot image not found!
Is it just me or something has changed lately regarding the installation of u-boot on SPI?
I have a Rock64 v2 and I am quite sure one year ago or more I used to update the SPI using the nand-sata-install script. Today I wanted to flash it again, but whenever I run the script (either via armbian-config) the error message in the title is shown and nothing occurs.
Running Armbian 20.21 with legacy (4.4) kernel. Oh, the relevant u-boot package according to apt is installed.
Thanks!
Edit: The reason behind is to check if a newer code would finally support booting from the SSD plugged on the USB3 port, which never worked, while it has always worked if plugged on a USB2 port.
