garinus Posted December 3, 2020 Posted December 3, 2020 Hi, we are trying to make our Orange PI zero with custom shield working with an MCP2518FD on board with SN65HVD23 tranceiver. We started from the normal kernel already built, but according to this thread we found that it must be activated at compile time. So we downloaded the repo and built the Armbian image with this CAN configuration: CONFIG_CAN=y CONFIG_CAN_RAW=y CONFIG_CAN_BCM=y CONFIG_CAN_GW=y CONFIG_CAN_J1939=y # # CAN Device Drivers # CONFIG_CAN_VCAN=y CONFIG_CAN_VXCAN=y CONFIG_CAN_SLCAN=y CONFIG_CAN_DEV=y CONFIG_CAN_CALC_BITTIMING=y CONFIG_CAN_FLEXCAN=y CONFIG_CAN_GRCAN=y CONFIG_CAN_SUN4I=y CONFIG_CAN_TI_HECC=y CONFIG_CAN_C_CAN=y CONFIG_CAN_C_CAN_PLATFORM=m CONFIG_CAN_CC770=y CONFIG_CAN_CC770_ISA=m CONFIG_CAN_CC770_PLATFORM=m CONFIG_CAN_IFI_CANFD=y CONFIG_CAN_M_CAN=y CONFIG_CAN_M_CAN_PLATFORM=y CONFIG_CAN_M_CAN_TCAN4X5X=y CONFIG_CAN_RCAR=y CONFIG_CAN_RCAR_CANFD=y CONFIG_CAN_SJA1000=y CONFIG_CAN_SJA1000_ISA=m CONFIG_CAN_SJA1000_PLATFORM=m CONFIG_CAN_SOFTING=y # # CAN SPI interfaces # CONFIG_CAN_HI311X=y CONFIG_CAN_MCP251X=y # end of CAN SPI interfaces # # CAN USB interfaces # CONFIG_CAN_8DEV_USB=y CONFIG_CAN_EMS_USB=y CONFIG_CAN_ESD_USB2=y CONFIG_CAN_GS_USB=y CONFIG_CAN_KVASER_USB=y CONFIG_CAN_MCBA_USB=y CONFIG_CAN_PEAK_USB=y CONFIG_CAN_UCAN=y # end of CAN USB interfaces CONFIG_CAN_DEBUG_DEVICES=y # end of CAN Device Drivers we currently have two problems: 1. At the physical interface level, the driver in this kernel version works only with MCP2515, but not with our MCP2518FD. After reading the following tread we found the original repository from which we copied the folder with the MCP2518FD drivers, but we can't compile them and include them in our kernel (because we don't know how to do it). 2. We cannot activate the CanBus interface with these commands (we get Cannot find device "can0"): ip link set can0 type can bitrate 2000000 fd off ip link can0 set can0 up Is there a guide on how to build and include the drivers we need? Once the driver has been loaded we could test the .dtbo and see if the MCP initializes correctly.
Solution garinus Posted January 8, 2021 Author Solution Posted January 8, 2021 Hi, after having performed some tests I managed to have the mcp2518fd working with Armbian and Orange PI zero. In attachment there is a patch that works with the current version. The driver is the same as in the main kernel version: https://github.com/torvalds/linux/tree/master/drivers/net/can/spi/mcp251xfd after compiling the kernel it is necessary to add the following custom overlay in /boot/overlay-user /dts-v1/; /plugin/; / { compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target-path = "/clocks"; overlay { #address-cells = <1>; #size-cells = <1>; can0_osc_fixed: can0_osc_fixed { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <20000000>; }; }; }; fragment@1 { target = <&pio>; overlay { can0_pin_irq: can0_pin_irq { pins = "PA10"; function = "irq"; bias-pull-up; }; }; }; fragment@2 { target = <&spi1>; overlay { #address-cells = <1>; #size-cells = <0>; status = "okay"; mcp2515 { reg = <0>; compatible = "microchip,mcp2518fd"; pinctrl-names = "default"; pinctrl-0 = <&can0_pin_irq>; spi-max-frequency = <10000000>; interrupt-parent = <&pio>; interrupts = <0 10 2>; /* PA10 IRQ_TYPE_EDGE_FALLING */ clocks = <&can0_osc_fixed>; status = "okay"; }; }; }; }; In my case the interrupt pin is on PA10 and the crystal on mcp is 20MHz, change them if necessary. copile it with armbian-add-overlay, then after the reboot launch the following commands: ip link set can0 type can bitrate 500000 ip link up can0 where 500000 is the bitrate of your canBus. It is possible to test the connection with: cansend can0 123#1122334455667788 or candump can0 mcp2518fd.patch 1
