Home Assistant doens´t start after upgrade to 2011 and reboot
Hello togehter,
I did a fresh os install on the Rock64, but even though it installs correctly and initially works, it stops after a reboot. Already tried different kernels and even the nightly version.
docker ps -a
CONTAINER ID   IMAGE                                                 COMMAND                  CREATED             STATUS                           PORTS                  NAMES
6dc24654d9f9   homeassistant/raspberrypi4-64-homeassistant:0.118.5   "/init"                  About an hour ago   Exited (255) About an hour ago                          homeassistant
f8aac0ec7775   homeassistant/aarch64-hassio-multicast:3              "/init"                  About an hour ago   Exited (255) About an hour ago                          hassio_multicast
b7751d91ddfd   homeassistant/aarch64-hassio-observer:2020.10.1       "/init"                  About an hour ago   Up 2 minutes                     0.0.0.0:4357->80/tcp   hassio_observer
b4425d86051c   homeassistant/aarch64-hassio-cli:2020.11.1            "/init /bin/bash -c …"   About an hour ago   Exited (255) About an hour ago                          hassio_cli
764edea09d68   homeassistant/aarch64-hassio-audio:17                 "/init"                  About an hour ago   Exited (255) About an hour ago                          hassio_audio
7b8d7aa79b28   homeassistant/aarch64-hassio-dns:2020.11.0            "/init"                  About an hour ago   Exited (255) About an hour ago                          hassio_dns
d99989112f79   homeassistant/aarch64-hassio-supervisor               "/init"                  About an hour ago   Exited (255) About an hour ago                          hassio_supervisor
also if a open up ip:4357 it only says
Home Assistant observer
Supervisor: Disconnected
Does anybody know how to fix this?
Thank you in advance.
Best Regards,
Vin
