hi guys,
i'm using NanoPi neo core using a battery and a volt booster.
and I want to control the voltage booster to turn off all peripherals to conserve power and prevent battery drainage.
I figured there's a PWR-LED pin connected to GPIOL10, which turns off when the system shut down.
is there a way to map another GPIO in the same way so i could know when the system has shut down - so it will be safe to cut power off?
thank you so much.
You can use "gpio-poweroff"  https://www.kernel.org/doc/Documentation/devicetree/bindings/power/reset/gpio-poweroff.txt
PA2 will be High when shutdown complete:
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun8i-h3";
    fragment@0 {
	target = <&pio>;
	__overlay__ {
	    poweroff_pins:poweroff_pins {
    	    allwinner,pins = "PA2";
    	    allwinner,function = "gpio_out";
    fragment@1 {
	target-path = "/";
    	__overlay__ {
    	    poweroff: poweroff {
            	compatible = "gpio-poweroff";
            	gpios = <&pio 0 2 0>;
