When was "lvextend" command run last, logs that give these details?
Hello Friends,
There is a requirement from Client to not run lvextend command if it was run in last 24 hrs.
I have tried the following and still havent figured out how to do it, any help will be highly appreciated:
1.] Have tried checking /var/log/messages, dmesg command logs. There are no kern.logs in the server so cannot check that as well.
2.] There is no /var/log/syslog so cannot check that. Also cannot activate logging by modifying lvm2.conf file as there are many servers.
3.] 'history' command only displays 10 commands and that too from current tty.
If there are any files which gets added with any volume group changes information please suggest.
Please suggest how I can capture when a particular command especially "lvextend" was run last?
Thanking You,
Karthik R
