USB Keyboard capture speed problem when using BarcodeScanner
Hi everybody
I bought new low price barcode scanner to connect it to NanoPi M1 with Armbian Debian jessie (Desktop edition).
I have a catastrophic problem with this new scanner. Scanner is working with my laptop properly but after connecting to NanoPi I found that it remove some digits from barcode text in scanning.
I tried so many Scanner configuration but problem is go on!
I tried this scanner on Cubieboard2 with Armbian too.
I tested barcodes with another branded (higher price) scanner it have no problem. It scanned all 13 digits of goods bardcode.
Scenario of problem:
  • when no near duplicated digits apear (e.g. 1234567890123) in barcode string SCANNING IS OK
  • when duplication of digits is together (e.g. 1230000012345) SCANNING IS OK too.
  • when duplication of digits are 1 or 2 digits inside as splitter (e.g. 6260000012345 OR 6226000012345) it remove duplicated digit (digit 6 is examples) and SCANNING NOT OK
I tried to fine kbdrate but problem is go on!
Some Scanning result here:
Original:6260432080238
Scanned: 6204320838
Original:6260432080221
Scanned: 6204320821
Original:6260465900220
Scanned: 62045900220
Original:6262032503513
Scanned: 6203250313
Original:2003603000017
Scanned: 2003600017
Original:2003370000029
Scanned: 2003370000029
Original:6260637400909
Scanned: 620374009
I think there is something like InfraRed Keyboard Service caused this problem. because it may received duplicated data from IR by reflecting from walls or etc.
Excuse me for weak english!
I made a solution :P
I programmed the scanner to role as Virtual COM (rs232 to USB)
Then I can connect /dev/ttyACM0 to capture what barcode scanned.
Now I get softwedge (https://github.com/ynezz/softwedge) and compiled it.
Softwedge is a serial keyboard emulator. It capture serial port and send it to X when ending string with LF or other terminator.
Now I have all 13 digits read by Armbian!
But still some problem to compatibility and working on it...
