Genna Posted February 6, 2021 Posted February 6, 2021 So as we know, the Hardkernel kernel did support powering the device on and off via a GPIO pin. This does not seem to work on Armbian with the mainline kernel. What does work is powering the device on and off with the remote control. So I wonder, what has to be done to enable power on and off vie the GPIO? My approach till now makes it possible to shutdown the device via GPIO interrupt. But then it will not come up again except if I reconnect the power cord or use the remote. I use this user device three overlay btw: /dts-v1/; /plugin/; /{ fragment@0 { target = <&ao_pinctrl>; __overlay__ { power_btn_port:power_btn_port { mux { groups = "GPIOAO_10"; function = "gpio_periphs"; bias-pull-up; output-high; }; }; }; }; fragment@1 { target-path = "/"; __overlay__ { gpio_keys:gpio_keys { compatible = "gpio-keys"; power_btn:power_btn { label = "POWER BUTTON"; linux,code = <116>; gpios = <&gpio_ao 10 0>; //GPIOAO_10 interrupt-parent = <&gpio_intc>; interrupts = <10 3>; wakeup-source; }; }; }; }; }; I've tried with the default pin as well (GPIOX_4) but with the same result. The hope was that the AO domain would do some magic like with the remote but no dice. Also the 'wakeup-source' seems to be ignored by the system as 'cat /sys/kernel/irq/*/wakeup' prints 'disabled' for all IRQ's. So, any ideas besides dissembling the remote and some solider works from the power button on the chassis to the IR IC to make it part of the final device? This would be very Frankenstein'ish just have a power button.
