Dennboy Posted February 11, 2021 Posted February 11, 2021 Dear all, I'm frequently losing GPIO interrupts on various boards, which seem to be caused by bursty processes. When I shield the cores that have those interrupts according to /proc/interrupts with e..g. "cset shield --cpu=0,1" , way less interrupts are lost (e.g. for 4kHz interrupts one in hours instead of once per minute). Most of these (ADC) interrupts are handled by my own kernel module, but couldn't find how to restrict them to e.g. CPU0, and they are not movable using /proc/irq/*/smp_affinity. HomeCT1:~:% grep ads /proc/interrupts 66: 166559 0 0 0 sunxi_pio_edge 1 Edge ads131a04 162: 273 152692648 13858531 17 ads131a04-dev0 Edge ads131a04_consumer0 HomeCT1:~:% cat /proc/irq/162/smp_affinity f I noticed that on allwinner (opi0, nanopi neo+2), the ADC interrupts are on different CPU cores. On the neo3 they always seem to go to the 1st CPU core. Is there any way to force the interrupts to 1st core on the allwinner as well (e.g. in kernel module c-code or via devicetree)? This would make it easier to shield the first core and reduce the lost interrupts. Or is there another way to give more priority to the GPIO interrupts? Making the kernel thread realtime with chrt is apparently not enough. PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2407 root rt 0 0 0 0 S 4.6 0.0 116:06.38 [irq/162-ads131a] Kind regards, Dennis
Dennboy Posted February 12, 2021 Author Posted February 12, 2021 Hi, I experimented some further and set /proc/irq/default_smp_affinity to 1 for the first core, and it looks good on paper, but in practice most interrupts still go to the second core. echo 1 > /proc/irq/default_smp_affinity # dynamically load ADC kernel driver HomeCT2:~:% cat /proc/irq/162/smp_affinity 1 HomeCT2:~:% cat /proc/irq/162/effective_affinity 0 HomeCT2:~:% grep ads /proc/interrupts 66: 1397 0 0 0 sunxi_pio_edge 1 Edge ads131a04 162: 557 1394461 27 0 ads131a04-dev0 Edge ads131a04_consumer0
Dennboy Posted February 12, 2021 Author Posted February 12, 2021 I tried to override the interrupt affinity using a devicetree overlay, but also this seems to be ignored on sunxi. Anybody knows why? Is the affinity simply not implemented by sunxi? Below is the overlay to change the interrupt affinity. Devicetree before modification shows interrupt-affinity=<&cpu0>,<&cpu1>,<&cpu2>,<&cpu3>; /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3","allwinner,sun50i-h5","friendlyarm,nanopi-neo2"; fragment@1 { target-path = "/pmu"; __overlay__ { interrupt-affinity = <&cpu0>; }; }; }; After boot only using cpu0 is reflected in the runtime devicetree on opi0: $ /lib/modules/5.10.12-sunxi/build/scripts/dtc/dtc -I fs /sys/firmware/devicetree/base|less pmu { compatible = "arm,cortex-a7-pmu"; interrupts = <0x00 0x78 0x04 0x00 0x79 0x04 0x00 0x7a 0x04 0x00 0x7b 0x04>; interrupt-affinity = <0x30>; }; cpus { cpu@0 { compatible = "arm,cortex-a7"; phandle = <0x30>; ... }; ... }; Here is the /proc/interrupt table again: HomeCT2:~:% grep ads /proc/interrupts 66: 1043 0 0 0 sunxi_pio_edge 1 Edge ads131a04 162: 68 255 1040571 1 ads131a04-dev0 Edge ads131a04_consumer0 So the affinity has been changed but seems to be ignored. p.s. Sorry for talking to myself;-)
