Thorsten Posted February 15, 2021 Posted February 15, 2021 Orange Pi Plus 2E, Armbian 21.02.1 Buster I can use Ethernet OR WLAN but not both connections at the same time. To use WLAN I have to disconnect the ethernet cable. Do you have any idea to solve this issue? Thanks
hal8k Posted March 13, 2021 Posted March 13, 2021 You cant use two different network connections at the same time as packets can only be routed to one gateway (usually your router or whatever device is acting as your default gateway). If you have both WLAN and Ethernet connected simultaneously then the metric with lowest value will be used: Quote /sbin/route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default _gateway 0.0.0.0 UG 100 0 0 eth0 link-local 0.0.0.0 255.255.0.0 U 1000 0 0 eth0 192.168.254.0 0.0.0.0 255.255.255.0 U 100 0 0 eth0 Expand The Metric field indicates the cost of a route. If multiple routes exist to a given destination network ID, the metric is used to decide which route is to be taken. The route with the lowest metric is the preferred route.
