tiagogb Posted February 20, 2021 Posted February 20, 2021 Im trying to boot from network with ORPI-One-Plus, but seems to be no support for boot direct from u-boot. is possible to boot (kernel, uboot) from sdcard, and leave only / (root) on NFS? When i try to compile/boot only u-boot-sunxi-with-spl.bin Quote U-Boot SPL 2020.04-gc1ab7274 (Feb 14 2021 - 22:26:03 -0300) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.4(debug):v2.4-358-gd3e145b4c NOTICE: BL31: Built : 21:02:09, Feb 14 2021 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc083fb8, model: OrangePi One Plus INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP805 on RSB INFO: PMIC: aldo1 voltage: 3.300V INFO: PMIC: aldo3 voltage: 3.300V INFO: PMIC: bldo1 voltage: 1.800V INFO: PMIC: bldo2 voltage: 1.800V INFO: PMIC: bldo3 voltage: 1.800V INFO: PMIC: cldo1 voltage: 3.300V INFO: PMIC: dcdcd voltage: 0.960V INFO: PMIC: dcdce voltage: 1.200V INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: cortex_a53: CPU workaround for 1530924 was applied NOTICE: PSCI: System suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2020.04-gc1ab7274 (Feb 14 2021 - 22:26:03 -0300) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi One Plus DRAM: 1 GiB MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to use mmc 0:0... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... Bus usb@5101000: USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5311000: USB EHCI 1.00 Bus usb@5311400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found scanning bus usb@5311000 for devices... 1 USB Device(s) found scanning bus usb@5311400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 2 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device ** No partition table - mmc 0 ** Device 0: unknown device No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-sunxi No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found. No ethernet found.
tparys Posted February 22, 2021 Posted February 22, 2021 I'm not aware of any direct NFS support in u-boot. Though that support may exist in recent versions. However, initramfs-tools does support NFS, and you may consider using that instead. So, you may want to make a local boot partition, even if your root is NFS. And all you'd need is u-boot, your kernel, initramfs, and DTB. You might start looking into the "nfsroot" and "ip" options of initramfs-tools: http://manpages.ubuntu.com/manpages/trusty/man8/initramfs-tools.8.html
