No access after reboot odroid [hc1] FDE
Go to solution Solved by rosbeef,
Hi !as title say i can not fully boot after reboot for electric failure.
I have the boot partition on my sdcard then normaly boot on the encrypted ssd system debian buster with 5,4 system.(Linux gre 5.4.102-odroidxu4 #21.02.3 SMP PREEMPT Mon Mar 8 07:55:51 UTC 2021 armv7l GNU/Linux)
I can access to initramfs run cryptroot-unlock script ,unlock the encrypted drive, then initramfs disconnect me and ... nothing, i can not view my HC1 on the network
So I tried to boot on the sdcard system and could unlock the SSD and chroot on the ssd. i see logs but nothing helps me to resolve my problem.
I share you my log if you can help me : messagesmessages, syslogsyslog, armbian-hardware-monitor.logarmbian-hardware-monitor.log and armbian-ramlog.logarmbian-ramlog.log
My last intent to start the server was the 22th of march.
Thanks
I set verbosity to 7 and view that :
There is some problem with the network but i don't understand what.
Someone have any idea about that  ?
Mar 29 20:17:11 gre kernel: Booting Linux on physical CPU 0x100
Mar 29 20:17:11 gre kernel: Linux version 5.4.102-odroidxu4 (root@hirsute) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #21.02.3 SMP PREE
Mar 29 20:17:11 gre kernel: CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
Mar 29 20:17:11 gre kernel: CPU: div instructions available: patching division code
Mar 29 20:17:11 gre kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Mar 29 20:17:11 gre kernel: OF: fdt: Machine model: Hardkernel Odroid HC1
Mar 29 20:17:11 gre kernel: Memory policy: Data cache writealloc
Mar 29 20:17:11 gre kernel: cma: Reserved 128 MiB at 0xb6800000
Mar 29 20:17:11 gre kernel: Samsung CPU ID: 0xe5422001
Mar 29 20:17:11 gre kernel: On node 0 totalpages: 518656
Mar 29 20:17:11 gre kernel:   Normal zone: 1728 pages used for memmap
Mar 29 20:17:11 gre kernel:   Normal zone: 0 pages reserved
Mar 29 20:17:11 gre kernel:   Normal zone: 196608 pages, LIFO batch:63
Mar 29 20:17:11 gre kernel:   HighMem zone: 322048 pages, LIFO batch:63
Mar 29 20:17:11 gre kernel: Running under secure firmware.
Mar 29 20:17:11 gre kernel: percpu: Embedded 20 pages/cpu s51852 r8192 d21876 u81920
Mar 29 20:17:11 gre kernel: pcpu-alloc: s51852 r8192 d21876 u81920 alloc=20*4096
Mar 29 20:17:11 gre kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
Mar 29 20:17:11 gre kernel: Built 1 zonelists, mobility grouping on.  Total pages: 516928
Mar 29 20:17:11 gre kernel: Kernel command line: console=ttySAC2,115200n8 console=tty1 consoleblank=0 loglevel=7 root=UUID=f2a34244-77b7-4a01-9127-93fe62f84508 rootfstype=ext4 rootwait r
Mar 29 20:17:11 gre kernel: hdmi: using HDMI mode
Mar 29 20:17:11 gre kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Mar 29 20:17:11 gre kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mar 29 20:17:11 gre kernel: mem auto-init: stack:off, heap alloc:on, heap free:off
Mar 29 20:17:11 gre kernel: Memory: 1893744K/2074624K available (11264K kernel code, 724K rwdata, 3124K rodata, 1024K init, 301K bss, 49808K reserved, 131072K cma-reserved, 1157120K high
Mar 29 20:17:11 gre kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Mar 29 20:17:11 gre kernel: rcu: Preemptible hierarchical RCU implementation.
Mar 29 20:17:11 gre kernel:         Tasks RCU enabled.
Mar 29 20:17:11 gre kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Mar 29 20:17:11 gre kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Mar 29 20:17:11 gre kernel: GIC: Using split EOI/Deactivate mode
Mar 29 20:17:11 gre kernel: random: get_random_bytes called from start_kernel+0x36c/0x540 with crng_init=0
Mar 29 20:17:11 gre kernel: Switching to timer-based delay loop, resolution 41ns
Mar 29 20:17:11 gre kernel: clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Mar 29 20:17:11 gre kernel: sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
Mar 29 20:17:11 gre kernel: genirq: irq_chip COMBINER did not update eff. affinity mask of irq 49
Mar 29 20:17:11 gre kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Mar 29 20:17:11 gre kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Mar 29 20:17:11 gre kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Mar 29 20:17:11 gre kernel: Ignoring duplicate/late registration of read_current_timer delay
Mar 29 20:17:11 gre kernel: Console: colour dummy device 80x30
Mar 29 20:17:11 gre kernel: printk: console [tty1] enabled
Mar 29 20:17:11 gre kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
Mar 29 20:17:11 gre kernel: pid_max: default: 32768 minimum: 301
Mar 29 20:17:11 gre kernel: LSM: Security Framework initializing
Mar 29 20:17:11 gre kernel: Yama: becoming mindful.
Mar 29 20:17:11 gre kernel: AppArmor: AppArmor initialized
Mar 29 20:17:11 gre kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Mar 29 20:17:11 gre kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Mar 29 20:17:11 gre kernel: *** VALIDATE tmpfs ***
Mar 29 20:17:11 gre kernel: *** VALIDATE proc ***
Mar 29 20:17:11 gre kernel: *** VALIDATE cgroup1 ***
Mar 29 20:17:11 gre kernel: *** VALIDATE cgroup2 ***
Mar 29 20:17:11 gre kernel: CPU: Testing write buffer coherency: ok
Mar 29 20:17:11 gre kernel: CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
Mar 29 20:17:11 gre kernel: Setting up static identity map for 0x40100000 - 0x40100060
Mar 29 20:17:11 gre kernel: ARM CCI driver probed
Mar 29 20:17:11 gre kernel: Exynos MCPM support installed
Mar 29 20:17:11 gre kernel: rcu: Hierarchical SRCU implementation.
Mar 29 20:17:11 gre kernel: soc soc0: Exynos: CPU[EXYNOS5800] PRO_ID[0xe5422001] REV[0x1] Detected
Mar 29 20:17:11 gre kernel: smp: Bringing up secondary CPUs ...
Mar 29 20:17:11 gre kernel: CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
Mar 29 20:17:11 gre kernel: CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
Mar 29 20:17:11 gre kernel: CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
Mar 29 20:17:11 gre kernel: CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
Mar 29 20:17:11 gre kernel: CPU4: detected I-Cache line size mismatch, workaround enabled
Mar 29 20:17:11 gre kernel: CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Mar 29 20:17:11 gre kernel: CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
Mar 29 20:17:11 gre kernel: CPU5: detected I-Cache line size mismatch, workaround enabled
Mar 29 20:17:11 gre kernel: CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Mar 29 20:17:11 gre kernel: CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
Mar 29 20:17:11 gre kernel: CPU6: detected I-Cache line size mismatch, workaround enabled
Mar 29 20:17:11 gre kernel: CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Mar 29 20:17:11 gre kernel: CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
Mar 29 20:17:11 gre kernel: CPU7: detected I-Cache line size mismatch, workaround enabled
Mar 29 20:17:11 gre kernel: CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
Mar 29 20:17:11 gre kernel: smp: Brought up 1 node, 8 CPUs
Mar 29 20:17:11 gre kernel: SMP: Total of 8 processors activated (384.00 BogoMIPS).
Mar 29 20:17:11 gre kernel: CPU: All CPU(s) started in HYP mode.
Mar 29 20:17:11 gre kernel: CPU: Virtualization extensions available.
Mar 29 20:17:11 gre kernel: devtmpfs: initialized
Mar 29 20:17:11 gre kernel: VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
Mar 29 20:17:11 gre kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 29 20:17:11 gre kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Mar 29 20:17:11 gre kernel: xor: measuring software checksum speed
Mar 29 20:17:11 gre kernel:    arm4regs  :  1516.800 MB/sec
Mar 29 20:17:11 gre kernel:    8regs     :  1238.000 MB/sec
Mar 29 20:17:11 gre kernel:    32regs    :  1232.400 MB/sec
Mar 29 20:17:11 gre kernel:    neon      :  2218.000 MB/sec
Mar 29 20:17:11 gre kernel: xor: using function: neon (2218.000 MB/sec)
Mar 29 20:17:11 gre kernel: pinctrl core: initialized pinctrl subsystem
Mar 29 20:17:11 gre kernel: NET: Registered protocol family 16
Mar 29 20:17:11 gre kernel: DMA: preallocated 2048 KiB pool for atomic coherent allocations
Mar 29 20:17:11 gre kernel: audit: initializing netlink subsys (disabled)
Mar 29 20:17:11 gre kernel: audit: type=2000 audit(0.440:1): state=initialized audit_enabled=0 res=1
Mar 29 20:17:11 gre kernel: cpuidle: using governor menu
Mar 29 20:17:11 gre kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Mar 29 20:17:11 gre kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
Mar 29 20:17:11 gre kernel: EXYNOS5420 PMU initialized
Mar 29 20:17:11 gre kernel: random: fast init done
Mar 29 20:17:11 gre kernel: cryptd: max_cpu_qlen set to 1000
Mar 29 20:17:11 gre kernel: raid6: neonx8   gen()  1467 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx8   xor()  1191 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx4   gen()   582 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx4   xor()  1164 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx2   gen()  1060 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx2   xor()  1355 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx1   gen()   721 MB/s
Mar 29 20:17:11 gre kernel: raid6: neonx1   xor()   806 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x8  gen()   378 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x8  xor()   269 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x4  gen()   369 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x4  xor()   280 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x2  gen()   264 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x2  xor()   264 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x1  gen()   181 MB/s
Mar 29 20:17:11 gre kernel: raid6: int32x1  xor()   204 MB/s
Mar 29 20:17:11 gre kernel: raid6: using algorithm neonx8 gen() 1467 MB/s
Mar 29 20:17:11 gre kernel: raid6: .... xor() 1191 MB/s, rmw enabled
Mar 29 20:17:11 gre kernel: raid6: using neon recovery algorithm
Mar 29 20:17:11 gre kernel: iommu: Default domain type: Translated
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver usbfs
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver hub
Mar 29 20:17:11 gre kernel: usbcore: registered new device driver usb
Mar 29 20:17:11 gre kernel: mc: Linux media interface: v0.10
Mar 29 20:17:11 gre kernel: videodev: Linux video capture interface: v2.00
Mar 29 20:17:11 gre kernel: Advanced Linux Sound Architecture Driver Initialized.
Mar 29 20:17:11 gre kernel: NetLabel: Initializing
Mar 29 20:17:11 gre kernel: NetLabel:  domain hash size = 128
Mar 29 20:17:11 gre kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Mar 29 20:17:11 gre kernel: NetLabel:  unlabeled traffic allowed by default
Mar 29 20:17:11 gre kernel: clocksource: Switched to clocksource mct-frc
Mar 29 20:17:11 gre kernel: *** VALIDATE bpf ***
Mar 29 20:17:11 gre kernel: VFS: Disk quotas dquot_6.6.0
Mar 29 20:17:11 gre kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Mar 29 20:17:11 gre kernel: *** VALIDATE ramfs ***
Mar 29 20:17:11 gre kernel: AppArmor: AppArmor Filesystem Enabled
Mar 29 20:17:11 gre kernel: thermal_sys: Registered thermal governor 'step_wise'
Mar 29 20:17:11 gre kernel: NET: Registered protocol family 2
Mar 29 20:17:11 gre kernel: tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Mar 29 20:17:11 gre kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
Mar 29 20:17:11 gre kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mar 29 20:17:11 gre kernel: TCP: Hash tables configured (established 8192 bind 8192)
Mar 29 20:17:11 gre kernel: UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Mar 29 20:17:11 gre kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Mar 29 20:17:11 gre kernel: Trying to unpack rootfs image as initramfs...
Mar 29 20:17:11 gre kernel: Freeing initrd memory: 12400K
Mar 29 20:17:11 gre kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
Mar 29 20:17:11 gre kernel: hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
Mar 29 20:17:11 gre kernel: Initialise system trusted keyrings
Mar 29 20:17:11 gre kernel: Key type blacklist registered
Mar 29 20:17:11 gre kernel: workingset: timestamp_bits=14 max_order=19 bucket_order=5
Mar 29 20:17:11 gre kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mar 29 20:17:11 gre kernel: fuse: init (API version 7.31)
Mar 29 20:17:11 gre kernel: *** VALIDATE fuse ***
Mar 29 20:17:11 gre kernel: Platform Keyring initialized
Mar 29 20:17:11 gre kernel: Key type asymmetric registered
Mar 29 20:17:11 gre kernel: Asymmetric key parser 'x509' registered
Mar 29 20:17:11 gre kernel: bounce: pool size: 64 pages
Mar 29 20:17:11 gre kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Mar 29 20:17:11 gre kernel: io scheduler mq-deadline registered
Mar 29 20:17:11 gre kernel: io scheduler kyber registered
Mar 29 20:17:11 gre kernel: io scheduler bfq registered
Mar 29 20:17:11 gre kernel: samsung-usb2-phy 12130000.phy: 12130000.phy supply vbus not found, using dummy regulator
Mar 29 20:17:11 gre kernel: exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus not found, using dummy regulator
Mar 29 20:17:11 gre kernel: exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus-boost not found, using dummy regulator
Mar 29 20:17:11 gre kernel: exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus not found, using dummy regulator
Mar 29 20:17:11 gre kernel: exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus-boost not found, using dummy regulator
Mar 29 20:17:11 gre kernel: dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
Mar 29 20:17:11 gre kernel: dma-pl330 121a0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
Mar 29 20:17:11 gre kernel: dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
Mar 29 20:17:11 gre kernel: dma-pl330 121b0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
Mar 29 20:17:11 gre kernel: dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
Mar 29 20:17:11 gre kernel: dma-pl330 10800000.mdma:         DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
Mar 29 20:17:11 gre kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Mar 29 20:17:11 gre kernel: 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 62, base_baud = 0) is a S3C6400/10
Mar 29 20:17:11 gre kernel: 12c10000.serial: ttySAC1 at MMIO 0x12c10000 (irq = 63, base_baud = 0) is a S3C6400/10
Mar 29 20:17:11 gre kernel: 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 64, base_baud = 0) is a S3C6400/10
Mar 29 20:17:11 gre kernel: printk: console [ttySAC2] enabled
Mar 29 20:17:11 gre kernel: 12c30000.serial: ttySAC3 at MMIO 0x12c30000 (irq = 65, base_baud = 0) is a S3C6400/10
Mar 29 20:17:11 gre kernel: exynos-trng 10830600.rng: Exynos True Random Number Generator.
Mar 29 20:17:11 gre kernel: dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
Mar 29 20:17:11 gre kernel: dma-pl330 3880000.adma:         DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
Mar 29 20:17:11 gre kernel: mali 11800000.gpu: Failed to get regulator
Mar 29 20:17:11 gre kernel: mali 11800000.gpu: Power control initialization failed
Mar 29 20:17:11 gre kernel: brd: module loaded
Mar 29 20:17:11 gre kernel: libphy: Fixed MDIO Bus: probed
Mar 29 20:17:11 gre kernel: dma-pl330 3880000.adma: PM domain MAU will not be powered off
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver r8152
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver cdc_ether
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver cdc_subset
Mar 29 20:17:11 gre kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mar 29 20:17:11 gre kernel: ehci-exynos: EHCI EXYNOS driver
Mar 29 20:17:11 gre kernel: exynos-ehci 12110000.usb: EHCI Host Controller
Mar 29 20:17:11 gre kernel: exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1
Mar 29 20:17:11 gre kernel: exynos-ehci 12110000.usb: irq 81, io mem 0x12110000
Mar 29 20:17:11 gre kernel: exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
Mar 29 20:17:11 gre kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Mar 29 20:17:11 gre kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 20:17:11 gre kernel: usb usb1: Product: EHCI Host Controller
Mar 29 20:17:11 gre kernel: usb usb1: Manufacturer: Linux 5.4.102-odroidxu4 ehci_hcd
Mar 29 20:17:11 gre kernel: usb usb1: SerialNumber: 12110000.usb
Mar 29 20:17:11 gre kernel: hub 1-0:1.0: USB hub found
Mar 29 20:17:11 gre kernel: hub 1-0:1.0: 3 ports detected
Mar 29 20:17:11 gre kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Mar 29 20:17:11 gre kernel: ohci-exynos: OHCI EXYNOS driver
Mar 29 20:17:11 gre kernel: exynos-ohci 12120000.usb: USB Host Controller
Mar 29 20:17:11 gre kernel: exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
Mar 29 20:17:11 gre kernel: exynos-ohci 12120000.usb: irq 81, io mem 0x12120000
Mar 29 20:17:11 gre kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
Mar 29 20:17:11 gre kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 20:17:11 gre kernel: usb usb2: Product: USB Host Controller
Mar 29 20:17:11 gre kernel: usb usb2: Manufacturer: Linux 5.4.102-odroidxu4 ohci_hcd
Mar 29 20:17:11 gre kernel: usb usb2: SerialNumber: 12120000.usb
Mar 29 20:17:11 gre kernel: hub 2-0:1.0: USB hub found
Mar 29 20:17:11 gre kernel: hub 2-0:1.0: 3 ports detected
Mar 29 20:17:11 gre kernel: mousedev: PS/2 mouse device common for all mice
Mar 29 20:17:11 gre kernel: i2c /dev entries driver
Mar 29 20:17:11 gre kernel: vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV
Mar 29 20:17:11 gre kernel: vddq_mmc2: Bringing 3300000uV into 2800000-2800000uV
Mar 29 20:17:11 gre kernel: vdd_sd: Bringing 3300000uV into 2800000-2800000uV
Mar 29 20:17:11 gre kernel: s5m-rtc s2mps14-rtc: registered as rtc0
Mar 29 20:17:11 gre kernel: s2mps11-clk s2mps11-clk: DMA mask not set
Mar 29 20:17:11 gre kernel: s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled
Mar 29 20:17:11 gre kernel: device-mapper: uevent: version 1.0.3
Mar 29 20:17:11 gre kernel: device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
Mar 29 20:17:11 gre kernel: sdhci: Secure Digital Host Controller Interface driver
Mar 29 20:17:11 gre kernel: sdhci: Copyright(c) Pierre Ossman
Mar 29 20:17:11 gre kernel: Synopsys Designware Multimedia Card Interface Driver
Mar 29 20:17:11 gre kernel: dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode.
Mar 29 20:17:11 gre kernel: dwmmc_exynos 12220000.mmc: Using internal DMA controller.
Mar 29 20:17:11 gre kernel: dwmmc_exynos 12220000.mmc: Version ID is 250a
Mar 29 20:17:11 gre kernel: dwmmc_exynos 12220000.mmc: DW MMC controller at irq 83,64 bit host data width,64 deep fifo
Mar 29 20:17:11 gre kernel: mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
Mar 29 20:17:11 gre kernel: s5p-secss 10830000.sss: s5p-sss driver registered
Mar 29 20:17:11 gre kernel: hidraw: raw HID events driver (C) Jiri Kosina
Mar 29 20:17:11 gre kernel: exynos-nocp: new NoC Probe device registered: 10ca1000.nocp
Mar 29 20:17:11 gre kernel: exynos-nocp: new NoC Probe device registered: 10ca1400.nocp
Mar 29 20:17:11 gre kernel: mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
Mar 29 20:17:11 gre kernel: exynos-nocp: new NoC Probe device registered: 10ca1800.nocp
Mar 29 20:17:11 gre kernel: mmc0: new high speed SD card at address 1234
Mar 29 20:17:11 gre kernel: exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp
Mar 29 20:17:11 gre kernel: mmcblk0: mmc0:1234 SA02G 1.83 GiB
Mar 29 20:17:11 gre kernel: exynos-ppmu: new PPMU device registered 10d00000.ppmu (ppmu-event3-dmc0_0)
Mar 29 20:17:11 gre kernel:  mmcblk0: p1
Mar 29 20:17:11 gre kernel: exynos-ppmu: new PPMU device registered 10d10000.ppmu (ppmu-event3-dmc0_1)
Mar 29 20:17:11 gre kernel: exynos-ppmu: new PPMU device registered 10d60000.ppmu (ppmu-event3-dmc1_0)
Mar 29 20:17:11 gre kernel: exynos-ppmu: new PPMU device registered 10d70000.ppmu (ppmu-event3-dmc1_1)
Mar 29 20:17:11 gre kernel: exynos5-dmc 10c20000.memory-controller: DMC initialized, in irq mode: 0
Mar 29 20:17:11 gre kernel: exynos-adc 12d10000.adc: IRQ index 1 not found
Mar 29 20:17:11 gre kernel: NET: Registered protocol family 17
Mar 29 20:17:11 gre kernel: NET: Registered protocol family 15
Mar 29 20:17:11 gre kernel: Key type dns_resolver registered
Mar 29 20:17:11 gre kernel: Registering SWP/SWPB emulation handler
Mar 29 20:17:11 gre kernel: registered taskstats version 1
Mar 29 20:17:11 gre kernel: Loading compiled-in X.509 certificates
Mar 29 20:17:11 gre kernel: Loaded X.509 cert 'Build time autogenerated kernel key: b78a5236499b47e5b10fce6ac9e33b4b8ed0a45d'
Mar 29 20:17:11 gre kernel: Key type ._fscrypt registered
Mar 29 20:17:11 gre kernel: Key type .fscrypt registered
Mar 29 20:17:11 gre kernel: Btrfs loaded, crc32c=crc32c-generic
Mar 29 20:17:11 gre kernel: Key type big_key registered
Mar 29 20:17:11 gre kernel: Key type encrypted registered
Mar 29 20:17:11 gre kernel: AppArmor: AppArmor sha1 policy hashing enabled
Mar 29 20:17:11 gre kernel: exynos-asv 10000000.chipid: cpu0 opp0, freq: 1500 missing
Mar 29 20:17:11 gre kernel: exynos-asv 10000000.chipid: cpu4 opp0, freq: 2100 missing
Mar 29 20:17:11 gre kernel: mali 11800000.gpu: GPU identified as 0x0620 r0p1 status 0
Mar 29 20:17:11 gre kernel: mali 11800000.gpu: Protected mode not available
Mar 29 20:17:11 gre kernel: mali 11800000.gpu: Probed as mali0
Mar 29 20:17:11 gre kernel: dwc3 12000000.dwc3: Failed to get clk 'ref': -2
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.7.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.7.auto: irq 156, io mem 0x12000000
Mar 29 20:17:11 gre kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Mar 29 20:17:11 gre kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 20:17:11 gre kernel: usb usb3: Product: xHCI Host Controller
Mar 29 20:17:11 gre kernel: usb usb3: Manufacturer: Linux 5.4.102-odroidxu4 xhci-hcd
Mar 29 20:17:11 gre kernel: usb usb3: SerialNumber: xhci-hcd.7.auto
Mar 29 20:17:11 gre kernel: hub 3-0:1.0: USB hub found
Mar 29 20:17:11 gre kernel: hub 3-0:1.0: 1 port detected
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
Mar 29 20:17:11 gre kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Mar 29 20:17:11 gre kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
Mar 29 20:17:11 gre kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 20:17:11 gre kernel: usb usb4: Product: xHCI Host Controller
Mar 29 20:17:11 gre kernel: usb usb4: Manufacturer: Linux 5.4.102-odroidxu4 xhci-hcd
Mar 29 20:17:11 gre kernel: devfreq 11800000.gpu: Couldn't update frequency transition information.
Mar 29 20:17:11 gre kernel: usb usb4: SerialNumber: xhci-hcd.7.auto
Mar 29 20:17:11 gre kernel: hub 4-0:1.0: USB hub found
Mar 29 20:17:11 gre kernel: hub 4-0:1.0: 1 port detected
Mar 29 20:17:11 gre kernel: dwc3 12400000.dwc3: Failed to get clk 'ref': -2
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 5
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.8.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.8.auto: irq 157, io mem 0x12400000
Mar 29 20:17:11 gre kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
Mar 29 20:17:11 gre kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 20:17:11 gre kernel: usb usb5: Product: xHCI Host Controller
Mar 29 20:17:11 gre kernel: usb usb5: Manufacturer: Linux 5.4.102-odroidxu4 xhci-hcd
Mar 29 20:17:11 gre kernel: usb usb5: SerialNumber: xhci-hcd.8.auto
Mar 29 20:17:11 gre kernel: hub 5-0:1.0: USB hub found
Mar 29 20:17:11 gre kernel: hub 5-0:1.0: 1 port detected
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 6
Mar 29 20:17:11 gre kernel: xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed
Mar 29 20:17:11 gre kernel: usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
Mar 29 20:17:11 gre kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
Mar 29 20:17:11 gre kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 20:17:11 gre kernel: usb usb6: Product: xHCI Host Controller
Mar 29 20:17:11 gre kernel: usb usb6: Manufacturer: Linux 5.4.102-odroidxu4 xhci-hcd
Mar 29 20:17:11 gre kernel: usb usb6: SerialNumber: xhci-hcd.8.auto
Mar 29 20:17:11 gre kernel: hub 6-0:1.0: USB hub found
Mar 29 20:17:11 gre kernel: hub 6-0:1.0: 1 port detected
Mar 29 20:17:11 gre kernel: s3c-rtc 101e0000.rtc: rtc disabled, re-enabling
Mar 29 20:17:11 gre kernel: rtc rtc1: invalid alarm value: 1900-01-01T00:00:00
Mar 29 20:17:11 gre kernel: s3c-rtc 101e0000.rtc: registered as rtc1
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_wcore ( 84000 KHz ~ 400000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_noc ( 67000 KHz ~ 100000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_fsys_apb (100000 KHz ~ 200000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_fsys (100000 KHz ~ 200000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_fsys2 ( 75000 KHz ~ 150000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_mfc ( 96000 KHz ~ 333000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_gen ( 89000 KHz ~ 267000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_peri ( 67000 KHz ~  67000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_g2d ( 84000 KHz ~ 333000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_g2d_acp ( 67000 KHz ~ 267000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_jpeg ( 75000 KHz ~ 300000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_jpeg_apb ( 84000 KHz ~ 167000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_disp1_fimd (120000 KHz ~ 200000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_disp1 (120000 KHz ~ 300000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_gscl_scaler (150000 KHz ~ 300000 KHz)
Mar 29 20:17:11 gre kernel: exynos-bus: new bus device registered: soc:bus_mscl ( 84000 KHz ~ 400000 KHz)
Mar 29 20:17:11 gre kernel: s5m-rtc s2mps14-rtc: setting system clock to 2000-01-01T00:00:16 UTC (946684816)
Mar 29 20:17:11 gre kernel: ALSA device list:
Mar 29 20:17:11 gre kernel:   No soundcards found.
Mar 29 20:17:11 gre kernel: Freeing unused kernel memory: 1024K
Mar 29 20:17:11 gre kernel: Run /init as init process
Mar 29 20:17:11 gre kernel: usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Mar 29 20:17:11 gre kernel: usb 6-1: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
Mar 29 20:17:11 gre kernel: usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
Mar 29 20:17:11 gre kernel: usb 6-1: Product: USB 10/100/1000 LAN
Mar 29 20:17:11 gre kernel: usb 6-1: Manufacturer: Realtek
Mar 29 20:17:11 gre kernel: usb 6-1: SerialNumber: 000001000000
Mar 29 20:17:11 gre kernel: usb 6-1: reset SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Mar 29 20:17:11 gre kernel: r8152 6-1:1.0 eth0: v1.10.11
Mar 29 20:17:11 gre kernel: r8152 6-1:1.0 enx001e063686ad: renamed from eth0
Mar 29 20:17:11 gre kernel: usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Mar 29 20:17:11 gre kernel: usb 4-1: New USB device found, idVendor=152d, idProduct=0579, bcdDevice=31.01
Mar 29 20:17:11 gre kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 29 20:17:11 gre kernel: usb 4-1: Product: JMS579
Mar 29 20:17:11 gre kernel: usb 4-1: Manufacturer: JMICRON
Mar 29 20:17:11 gre kernel: usb 4-1: SerialNumber: 203954232624
Mar 29 20:17:11 gre kernel: SCSI subsystem initialized
Mar 29 20:17:11 gre kernel: usb-storage 4-1:1.0: USB Mass Storage device detected
Mar 29 20:17:11 gre kernel: scsi host0: usb-storage 4-1:1.0
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver usb-storage
Mar 29 20:17:11 gre kernel: usbcore: registered new interface driver uas
Mar 29 20:17:11 gre kernel: scsi 0:0:0:0: Direct-Access     CT1000MX 500SSD1          3101 PQ: 0 ANSI: 6
Mar 29 20:17:11 gre kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Mar 29 20:17:11 gre kernel: sd 0:0:0:0: [sda] Write Protect is off
Mar 29 20:17:11 gre kernel: sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
Mar 29 20:17:11 gre kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 29 20:17:11 gre kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Mar 29 20:17:11 gre kernel: r8152 6-1:1.0 enx001e063686ad: carrier on
Mar 29 20:17:11 gre kernel: random: cryptsetup: uninitialized urandom read (4 bytes read)
Mar 29 20:17:11 gre kernel: random: dropbear: uninitialized urandom read (32 bytes read)
Mar 29 20:17:11 gre kernel: NET: Registered protocol family 10
Mar 29 20:17:11 gre kernel: Segment Routing with IPv6
Mar 29 20:17:11 gre kernel: random: crng init done
Mar 29 20:17:11 gre kernel: vddq_mmc0: disabling
Mar 29 20:17:11 gre kernel: vdd_ldo12: disabling
Mar 29 20:17:11 gre kernel: NET: Registered protocol family 38
Mar 29 20:17:11 gre kernel: EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
Mar 29 20:17:11 gre systemd[1]: System time before build time, advancing clock.
Mar 29 20:17:11 gre systemd[1]: Inserted module 'autofs4'
Mar 29 20:17:11 gre systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLK
Mar 29 20:17:11 gre systemd[1]: Detected architecture arm.
Mar 29 20:17:11 gre systemd[1]: Set hostname to <gre>.
Mar 29 20:17:11 gre systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based
Mar 29 20:17:11 gre systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
Mar 29 20:17:11 gre systemd[1]: Listening on Journal Socket (/dev/log).
Mar 29 20:17:11 gre systemd[1]: Reached target System Time Synchronized.
Mar 29 20:17:11 gre systemd[1]: Listening on fsck to fsckd communication Socket.
Mar 29 20:17:11 gre systemd[1]: Created slice system-serial\x2dgetty.slice.
Mar 29 20:17:11 gre systemd[1]: Created slice system-getty.slice.
Mar 29 20:17:11 gre kernel: EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
Mar 29 20:17:11 gre kernel: zram: Added device: zram0
Mar 29 20:17:11 gre kernel: zram: Added device: zram1
Mar 29 20:17:11 gre kernel: zram: Added device: zram2
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f50000.jpeg: Adding to iommu group 0
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f50000.jpeg: encoder device registered as /dev/video20
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f50000.jpeg: decoder device registered as /dev/video21
Mar 29 20:17:11 gre kernel: exynos-gsc 13e00000.video-scaler: Adding to iommu group 1
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f50000.jpeg: Samsung S5P JPEG codec
Mar 29 20:17:11 gre kernel: exynos-gsc 13e10000.video-scaler: Adding to iommu group 2
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f60000.jpeg: Adding to iommu group 3
Mar 29 20:17:11 gre kernel: s5p-mfc 11000000.codec: Adding to iommu group 4
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f60000.jpeg: encoder device registered as /dev/video22
Mar 29 20:17:11 gre kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f60000.jpeg: decoder device registered as /dev/video23
Mar 29 20:17:11 gre kernel: s5p-jpeg 11f60000.jpeg: Samsung S5P JPEG codec
Mar 29 20:17:11 gre kernel: s5p-mfc 11000000.codec: preallocated 8 MiB buffer for the firmware and context buffers
Mar 29 20:17:11 gre kernel: s5p-mfc 11000000.codec: decoder registered as /dev/video10
Mar 29 20:17:11 gre kernel: s5p-mfc 11000000.codec: encoder registered as /dev/video11
Mar 29 20:17:11 gre kernel: zram0: detected capacity change from 0 to 1043578880
Mar 29 20:17:11 gre kernel: Adding 1019116k swap on /dev/zram0.  Priority:5 extents:1 across:1019116k SS
Mar 29 20:17:11 gre kernel: zram1: detected capacity change from 0 to 52428800
Mar 29 20:17:11 gre systemd[1]: Created slice system-lvm2\x2dpvscan.slice.
Mar 29 20:17:11 gre systemd[1]: Starting LVM event activation on device 254:0...
Mar 29 20:17:11 gre systemd[1]: Starting Armbian memory supported logging...
Mar 29 20:17:11 gre systemd[1]: Starting Raise network interfaces...
Mar 29 20:17:11 gre kernel: EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
Mar 29 20:17:11 gre kernel: ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
Mar 29 20:17:11 gre systemd[1]: Started Raise network interfaces.
Mar 29 20:17:11 gre systemd[1]: Started LVM event activation on device 254:0.
Mar 29 20:17:11 gre systemd[1]: Started Armbian memory supported logging.
Mar 29 20:17:11 gre systemd[1]: Starting Journal Service...
Mar 29 20:17:11 gre systemd-journald[1031]: Journal started
Mar 29 20:17:11 gre systemd-journald[1031]: Runtime journal (/run/log/journal/c313b179453145f39861a2a98fea3a65) is 2.4M, max 19.9M, 17.4M free.
Mar 29 20:17:11 gre systemd-udevd[856]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Mar 29 20:17:11 gre systemd-udevd[856]: link_config: could not get ethtool features for enx001e063686ad
Mar 29 20:17:11 gre systemd-udevd[856]: Could not set offload features of enx001e063686ad: No such device
Mar 29 20:17:11 gre fake-hwclock[796]: Mon 29 Mar 2021 06:17:01 PM UTC
Mar 29 20:17:11 gre systemd[1]: Started Journal Service.
Mar 29 20:17:11 gre systemd-udevd[856]: enx001e063686ad: Failed to open ATTR{/sys/devices/platform/soc/soc:usb3-1/12400000.dwc3/xhci-hcd.8.auto/usb6/6-1/6-1:1.0/net/enx001e063686ad/queue
Mar 29 20:17:11 gre lvm[799]:   3 logical volume(s) in volume group "sdg" monitored
Mar 29 20:17:11 gre systemd-udevd[857]: Using default interface naming scheme 'v240'.
Mar 29 20:17:11 gre systemd-udevd[857]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Mar 29 20:17:11 gre systemd[1]: Starting Flush Journal to Persistent Storage...
Mar 29 20:17:11 gre resolvconf[819]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
Mar 29 20:17:11 gre armbian-zram-config[840]: /usr/lib/armbian/armbian-zram-config: line 63: /sys/module/zswap/parameters/enabled: No such file or directory
Mar 29 20:17:11 gre armbian-zram-config[840]: Setting up swapspace version 1, size = 995.2 MiB (1043574784 bytes)
Mar 29 20:17:11 gre armbian-zram-config[840]: no label, UUID=1bd022ac-f404-473e-91c5-86dc4aaa0396
Mar 29 20:17:11 gre armbian-zram-config[840]: mke2fs 1.44.5 (15-Dec-2018)
Mar 29 20:17:11 gre armbian-zram-config[840]: [74B blob data]
Mar 29 20:17:11 gre armbian-zram-config[840]: Creating filesystem with 12800 4k blocks and 12800 inodes
Mar 29 20:17:11 gre armbian-zram-config[840]: [41B blob data]
Mar 29 20:17:11 gre armbian-zram-config[840]: [38B blob data]
Hello
Just adding more informations in case someone could help.
I tried to rsync my sdcard to my ssd and the problem is the same.
booting on sdcard ( specifying root="root=UUID=sdcard uuid" in the boot.ini )  open initramfs then ask for cryptrootunlock pass then switch well on sdcard file system. from there ssd is uncrypted and is accessible.
booting on ssd ( specifying root=/dev/sdg/root cryptopts=source=/dev/sda,target=sdc,lvm=sdg in the boot.ini) open initramfs then ask for cryptrootunlock pass then close the ssh connection and ... nothing.
Regarding your question if it is the same problem as
 It appears to be a different issue. Your drive does appear in the dmesg. Just to be sure, does it help if you shut the hc1 completely (e.g. systemctl poweroff), and then disconnect and reconnect power? In case of my issue it helps.
  • Solution
damn i lost my thread.
I changed all fstab disk entry name by UUID= then
I go back to the legacy kernel and that works 4.14.222.
but now 5.4 seems stable maybe i will try upgrade to it
:unsure:
