rc rc0: IR0 event FIF0 is full! Cubietruck Allwinner A20 with Armbian 20.11
Hi!,
i got some issue with armbian version 20.11. The problem is similar to https://forum.armbian.com/topic/2076-a20-cubieboard-2/ . I tried to blacklist the ir, too.
But it do not fix my problem, because there were changes at the commands to blacklist the ir.
But also i am not 100% sure that it is the ir, because the prompt shows me the stacks and pointed at the smbd PID (at the appendix  -  fotos).
(Sorry for the bad foto quality!)
I appreciate your help! Thank you ! :)
Armbian version:
# PLEASE DO NOT EDIT THIS FILE
BOARD=cubietruck
BOARD_NAME="Cubietruck"
BOARDFAMILY=sun7i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=b0760915-dirty
DISTRIBUTION_CODENAME=bionic
DISTRIBUTION_STATUS=supported
VERSION=20.11
LINUXFAMILY=sunxi
BRANCH=current
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
lsmod:
Module                  Size  Used by
overlay                86016  0
joydev                 24576  0
mousedev               20480  0
input_leds             16384  0
uas                    24576  0
sun4i_gpadc_iio        16384  0
snd_soc_spdif_tx       16384  1
hci_uart               61440  0
brcmfmac              180224  0
btrtl                  20480  1 hci_uart
brcmutil               16384  1 brcmfmac
axp20x_usb_power       16384  0
axp20x_battery         16384  0
btbcm                  16384  1 hci_uart
axp20x_adc             16384  0
evdev                  20480  4
industrialio           53248  4 axp20x_usb_power,axp20x_battery,sun4i_gpadc_iio,axp20x_adc
lima                   45056  0
bluetooth             401408  4 btrtl,hci_uart,btbcm
ecdh_generic           16384  1 bluetooth
cfg80211              471040  1 brcmfmac
ecc                    28672  1 ecdh_generic
gpu_sched              28672  1 lima
sun4i_ts               16384  0
sunxi_cir              20480  0
sun4i_gpadc            16384  0
rfkill                 20480  4 bluetooth,cfg80211
pwm_sun4i              16384  0
sunxi_cedrus           32768  0
sun4i_ss               28672  0
sun4i_drm_hdmi         24576  2
display_connector      20480  0
uio_pdrv_genirq        16384  0
uio                    16384  1 uio_pdrv_genirq
cpufreq_dt             20480  0
zram                   24576  2
sch_fq_codel           20480  3
ip_tables              24576  0
x_tables               24576  1 ip_tables
autofs4                36864  2
pinctrl_axp209         16384  0
sunxi                  20480  0
phy_generic            20480  2 sunxi
pwrseq_simple          16384  1
realtek                20480  1
At the kern.log i the error prompt also listed:
Mar 27 23:14:59 localhost kernel: [ 2692.632143] [<c0135b07>] (kthread) from [<c0100159>] (ret_from_fork+0x11/0x38)
Mar 27 23:14:59 localhost kernel: [ 2692.632148] Exception stack(0xed185fb0 to 0xed185ff8)
Mar 27 23:14:59 localhost kernel: [ 2692.632156] 5fa0:                                     00000000 00000000 00000000$
Mar 27 23:14:59 localhost kernel: [ 2692.632165] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000$
Mar 27 23:14:59 localhost kernel: [ 2692.632173] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Mar 27 23:14:59 localhost kernel: [ 2692.632209] sun4i-hdmi 1c16000.hdmi: Cannot create DMA dma:audio-tx symlink
Mar 27 23:14:59 localhost kernel: [ 2692.633582] sun4i-hdmi 1c16000.hdmi: 1c16000.hdmi <-> 1c16000.hdmi mapping ok
Mar 28 08:59:17 localhost kernel: [34149.967812] ieee80211 phy0: brcmf_psm_watchdog_notify: PSM's watchdog has fired!
Mar 28 08:59:26 localhost kernel: [34159.450446] ieee80211 phy0: brcmf_escan_timeout: timer expired
Mar 31 19:57:37 localhost kernel: [332851.909786] sysfs: cannot create duplicate filename '/devices/platform/soc/1c16$
Mar 31 19:57:37 localhost kernel: [332851.909806] CPU: 0 PID: 22187 Comm: kworker/0:2 Tainted: G         C  E     5.8$
Mar 31 19:57:37 localhost kernel: [332851.909810] Hardware name: Allwinner sun7i (A20) Family
Mar 31 19:57:37 localhost kernel: [332851.909835] Workqueue: events output_poll_execute
Mar 31 19:57:37 localhost kernel: [332851.909865] [<c010d6cd>] (unwind_backtrace) from [<c0109a7d>] (show_stack+0x11/$
Mar 31 19:57:37 localhost kernel: [332851.909881] [<c0109a7d>] (show_stack) from [<c056e1c9>] (dump_stack+0x75/0x84)
Mar 31 19:57:37 localhost kernel: [332851.909898] [<c056e1c9>] (dump_stack) from [<c02e63f5>] (sysfs_warn_dup+0x49/0x$
Mar 31 19:57:37 localhost kernel: [332851.909911] [<c02e63f5>] (sysfs_warn_dup) from [<c02e664b>] (sysfs_do_create_li$
Mar 31 19:57:37 localhost kernel: [332851.909923] [<c02e664b>] (sysfs_do_create_link_sd) from [<c05b2d37>] (dma_reque$
Mar 31 19:57:37 localhost kernel: [332851.909939] [<c05b2d37>] (dma_request_chan) from [<c07f09d1>] (snd_dmaengine_pc$
Mar 31 19:57:37 localhost kernel: [332851.909966] [<c07f09d1>] (snd_dmaengine_pcm_register) from [<bf94b3fd>] (sun4i_$
Mar 31 19:57:37 localhost kernel: [332851.909985] [<bf94b3fd>] (sun4i_hdmi_audio_create [sun4i_drm_hdmi]) from [<bf94$
Mar 31 19:57:37 localhost kernel: [332851.910004] [<bf94bc2d>] (sun4i_hdmi_enable [sun4i_drm_hdmi]) from [<c05f8777>]$
Mar 31 19:57:37 localhost kernel: [332851.910019] [<c05f8777>] (drm_atomic_helper_commit_modeset_enables) from [<c05f$
Mar 31 19:57:37 localhost kernel: [332851.910032] [<c05f9bbd>] (drm_atomic_helper_commit_tail_rpm) from [<c05f9e6d>] $
Mar 31 19:57:37 localhost kernel: [332851.910044] [<c05f9e6d>] (commit_tail) from [<c05fa985>] (drm_atomic_helper_com$
Mar 31 19:57:37 localhost kernel: [332851.910059] [<c05fa985>] (drm_atomic_helper_commit) from [<c061c63d>] (drm_clie$
Mar 31 19:57:37 localhost kernel: [332851.910072] [<c061c63d>] (drm_client_modeset_commit_atomic) from [<c061c6e7>] ($
Mar 31 19:57:37 localhost kernel: [332851.910084] [<c061c6e7>] (drm_client_modeset_commit_locked) from [<c061c7c7>] ($
Mar 31 19:57:37 localhost kernel: [332851.910098] [<c061c7c7>] (drm_client_modeset_commit) from [<c05fdfeb>] (__drm_f$
Mar 31 19:57:37 localhost kernel: [332851.910110] [<c05fdfeb>] (__drm_fb_helper_restore_fbdev_mode_unlocked) from [<c$
Mar 31 19:57:37 localhost kernel: [332851.910121] [<c05fe065>] (drm_fb_helper_set_par) from [<c05fe0f1>] (drm_fb_help$
Mar 31 19:57:37 localhost kernel: [332851.910133] [<c05fe0f1>] (drm_fb_helper_hotplug_event.part.0) from [<c061c197>]$
Mar 31 19:57:37 localhost kernel: [332851.910145] [<c061c197>] (drm_client_dev_hotplug) from [<c05f1597>] (output_pol$
Mar 31 19:57:37 localhost kernel: [332851.910158] [<c05f1597>] (output_poll_execute) from [<c01309fb>] (process_one_w$
Mar 31 19:57:37 localhost kernel: [332851.910169] [<c01309fb>] (process_one_work) from [<c0130d47>] (worker_thread+0x$
Mar 31 19:57:37 localhost kernel: [332851.910181] [<c0130d47>] (worker_thread) from [<c0135b07>] (kthread+0xeb/0x10c)
Mar 31 19:57:37 localhost kernel: [332851.910194] [<c0135b07>] (kthread) from [<c0100159>] (ret_from_fork+0x11/0x38)
At reboot:
Apr  6 15:16:27 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0
Apr  6 15:16:27 localhost kernel: [    0.000000] Linux version 5.8.16-sunxi (root@xeon) (arm-none-linux-gnueabihf-gcc$
Apr  6 15:16:27 localhost kernel: [    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
Apr  6 15:16:27 localhost kernel: [    0.000000] CPU: div instructions available: patching division code
Apr  6 15:16:27 localhost kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction c$
Apr  6 15:16:27 localhost kernel: [    0.000000] OF: fdt: Machine model: Cubietech Cubietruck
Apr  6 15:16:27 localhost kernel: [    0.000000] Memory policy: Data cache writealloc
Apr  6 15:16:27 localhost kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
Apr  6 15:16:27 localhost kernel: [    0.000000] OF: reserved mem: initialized node default-pool, compatible id share$
Apr  6 15:16:27 localhost kernel: [    0.000000] Zone ranges:
Apr  6 15:16:27 localhost kernel: [    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
Apr  6 15:16:27 localhost kernel: [    0.000000]   HighMem  [mem 0x0000000070000000-0x00000000be05bfff]
Apr  6 15:16:27 localhost kernel: [    0.000000] Movable zone start for each node
Apr  6 15:16:27 localhost kernel: [    0.000000] Early memory node ranges
Apr  6 15:16:27 localhost kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000be05bfff]
Apr  6 15:16:27 localhost kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000be05bfff]
Apr  6 15:16:27 localhost kernel: [    0.000000] On node 0 totalpages: 516188
Apr  6 15:16:27 localhost kernel: [    0.000000]   Normal zone: 1728 pages used for memmap
Apr  6 15:16:27 localhost kernel: [    0.000000]   Normal zone: 0 pages reserved
Apr  6 15:16:27 localhost kernel: [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
Apr  6 15:16:27 localhost kernel: [    0.000000]   HighMem zone: 319580 pages, LIFO batch:63
Apr  6 15:16:27 localhost kernel: [    0.000000] psci: probing for conduit method from DT.
Apr  6 15:16:27 localhost kernel: [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
Apr  6 15:16:27 localhost kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920
Apr  6 15:16:27 localhost kernel: [    0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096
Apr  6 15:16:27 localhost kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1
Apr  6 15:16:27 localhost kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 514460
Apr  6 15:16:27 localhost kernel: [    0.000000] Kernel command line: root=UUID=2d347ac0-8d78-445b-a1fd-bce4268363dd $
Apr  6 15:16:27 localhost kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, lin$
Apr  6 15:16:27 localhost kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linea$
Apr  6 15:16:27 localhost kernel: [    0.000000] allocated 2068848 bytes of page_ext
Apr  6 15:16:27 localhost kernel: [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
Apr  6 15:16:27 localhost kernel: [    0.000000] Memory: 1918324K/2064752K available (9216K kernel code, 1028K rwdata$
Apr  6 15:16:27 localhost kernel: [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2f/0x368 wi$
Apr  6 15:16:27 localhost kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Apr  6 15:16:27 localhost kernel: [    0.000000] ftrace: allocating 39966 entries in 79 pages
Apr  6 15:16:27 localhost kernel: [    0.000000] ftrace: allocated 79 pages with 5 groups
Apr  6 15:16:27 localhost kernel: [    0.000000] rcu: Hierarchical RCU implementation.
Apr  6 15:16:27 localhost kernel: [    0.000000] rcu:*RED MARKED AREA* RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
Apr  6 15:16:27 localhost kernel: [    0.000000]  *RED MARKED AREA* Rude variant of Tasks RCU enabled.
Apr  6 15:16:27 localhost kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffie$
Apr  6 15:16:27 localhost kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Apr  6 15:16:27 localhost kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Apr  6 15:16:27 localhost kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
Apr  6 15:16:27 localhost kernel: [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Apr  6 15:16:27 localhost kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x$
Apr  6 15:16:27 localhost kernel: [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980465$
Apr  6 15:16:27 localhost kernel: [    0.000017] Switching to timer-based delay loop, resolution 41ns
Apr  6 15:16:27 localhost kernel: [    0.000548] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idl$
Apr  6 15:16:27 localhost kernel: [    0.000887] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_i$
Apr  6 15:16:27 localhost kernel: [    0.001245] Console: colour dummy device 80x30
Apr  6 15:16:27 localhost kernel: [    0.001262] printk: console [tty1] enabled
Apr  6 15:16:27 localhost kernel: [    0.001329] Calibrating delay loop (skipped), value calculated using timer frequ$
Apr  6 15:16:27 localhost kernel: [    0.001340] pid_max: default: 32768 minimum: 301
Apr  6 15:16:27 localhost kernel: [    0.001581] LSM: Security Framework initializing
Apr  6 15:16:27 localhost kernel: [    0.001646] Yama: becoming mindful.
Apr  6 15:16:27 localhost kernel: [    0.001846] AppArmor: AppArmor initialized
Apr  6 15:16:27 localhost kernel: [    0.001935] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Apr  6 15:16:27 localhost kernel: [    0.001949] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, lin$
Apr  6 15:16:27 localhost kernel: [    0.003140] CPU: Testing write buffer coherency: ok
Apr  6 15:16:27 localhost kernel: [    0.003578] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Apr  6 15:16:27 localhost kernel: [    0.004415] Setting up static identity map for 0x40100000 - 0x40100054
Apr  6 15:16:27 localhost kernel: [    0.004577] rcu: Hierarchical SRCU implementation.
Apr  6 15:16:27 localhost kernel: [    0.008337] smp: Bringing up secondary CPUs ...
Apr  6 15:16:27 localhost kernel: [    0.019241] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Apr  6 15:16:27 localhost kernel: [    0.019414] smp: Brought up 1 node, 2 CPUs
Apr  6 15:16:27 localhost kernel: [    0.019425] SMP: Total of 2 processors activated (96.00 BogoMIPS).
Apr  6 15:16:27 localhost kernel: [    0.019429] CPU: All CPU(s) started in HYP mode.
Apr  6 15:16:27 localhost kernel: [    0.019431] CPU: Virtualization extensions available.
Apr  6 15:16:27 localhost kernel: [    0.020720] devtmpfs: initialized
Apr  6 15:16:27 localhost kernel: [    0.030808] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 re$
Apr  6 15:16:27 localhost kernel: [    0.031374] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_i$
Apr  6 15:16:27 localhost kernel: [    0.031415] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
Apr  6 15:16:27 localhost kernel: [    0.035527] xor: measuring software checksum speed
Apr  6 15:16:27 localhost kernel: [    0.075266]    arm4regs  :  1136.000 MB/sec
Apr  6 15:16:27 localhost kernel: [    0.115325]    8regs     :   791.000 MB/sec
Apr  6 15:16:27 localhost kernel: [    0.155385]    32regs    :   747.000 MB/sec
Apr  6 15:16:27 localhost kernel: [    0.195453]    neon      :  1150.000 MB/sec
Apr  6 15:16:27 localhost kernel: [    0.195458] xor: using function: neon (1150.000 MB/sec)
Apr  6 15:16:27 localhost kernel: [    0.195565] pinctrl core: initialized pinctrl subsystem
Apr  6 15:16:27 localhost kernel: [    0.196208] thermal_sys: Registered thermal governor 'fair_share'
Apr  6 15:16:27 localhost kernel: [    0.196215] thermal_sys: Registered thermal governor 'bang_bang'
Apr  6 15:16:27 localhost kernel: [    0.196222] thermal_sys: Registered thermal governor 'step_wise'
Apr  6 15:16:27 localhost kernel: [    0.197222] NET: Registered protocol family 16
Apr  6 15:16:27 localhost kernel: [    0.199107] DMA: preallocated 256 KiB pool for atomic coherent allocations
Apr  6 15:16:27 localhost kernel: [    0.199811] audit: initializing netlink subsys (disabled)
Apr  6 15:16:27 localhost kernel: [    0.200138] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 r$
Apr  6 15:16:27 localhost kernel: [    0.200814] cpuidle: using governor ladder
Apr  6 15:16:27 localhost kernel: [    0.200840] cpuidle: using governor menu
Apr  6 15:16:27 localhost kernel: [    0.201394] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint reg$
Apr  6 15:16:27 localhost kernel: [    0.201399] hw-breakpoint: maximum watchpoint size is 8 bytes.
Apr  6 15:16:27 localhost kernel: [    0.228372] cryptd: max_cpu_qlen set to 1000
Apr  6 15:16:27 localhost kernel: [    0.299991] raid6: neonx8   gen()   699 MB/s
Apr  6 15:16:27 localhost kernel: [    0.368119] raid6: neonx8   xor()   524 MB/s
Apr  6 15:16:27 localhost kernel: [    0.436255] raid6: neonx4   gen()   752 MB/s
Apr  6 15:16:27 localhost kernel: [    0.504366] raid6: neonx4   xor()   567 MB/s
Apr  6 15:16:27 localhost kernel: [    0.572531] raid6: neonx2   gen()   828 MB/s
Apr  6 15:16:27 localhost kernel: [    0.640631] raid6: neonx2   xor()   590 MB/s
Apr  6 15:16:27 localhost kernel: [    0.708791] raid6: neonx1   gen()   738 MB/s
Apr  6 15:16:27 localhost kernel: [    0.776902] raid6: neonx1   xor()   511 MB/s
Apr  6 15:16:27 localhost kernel: [    0.845037] raid6: int32x8  gen()   273 MB/s
Apr  6 15:16:27 localhost kernel: [    0.913190] raid6: int32x8  xor()   160 MB/s
Apr  6 15:16:27 localhost kernel: [    0.981355] raid6: int32x4  gen()   323 MB/s
Apr  6 15:16:27 localhost kernel: [    1.049489] raid6: int32x4  xor()   186 MB/s
