marco Posted August 10, 2015 Posted August 10, 2015 Hi, I installed Debian wheezy I tried to connect via ssh with ethernet connection and it works well , but if I try to connect with the wifi connection is blocked after entering the password , it is a bug cubox? . If you can serve the ouptu ssh -vvv it is : marco@kali:~$ ssh -vvv 192.168.x.x OpenSSH_6.0p1 Debian-4+deb7u2, OpenSSL 1.0.1e 11 Feb 2013 debug1: Reading configuration data /etc/ssh/ssh_config debug1: /etc/ssh/ssh_config line 19: Applying options for * debug2: ssh_connect: needpriv 0 debug1: Connecting to 192.168.x.x [192.168.x.x] port 22. debug1: Connection established. debug1: identity file /home/marco/.ssh/id_rsa type -1 debug1: identity file /home/marco/.ssh/id_rsa-cert type -1 debug1: identity file /home/marco/.ssh/id_dsa type -1 debug1: identity file /home/marco/.ssh/id_dsa-cert type -1 debug1: identity file /home/marco/.ssh/id_ecdsa type -1 debug1: identity file /home/marco/.ssh/id_ecdsa-cert type -1 debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-4+deb7u2 debug1: match: OpenSSH_6.0p1 Debian-4+deb7u2 pat OpenSSH* debug1: Enabling compatibility mode for protocol 2.0 debug1: Local version string SSH-2.0-OpenSSH_6.0p1 Debian-4+deb7u2 debug2: fd 3 setting O_NONBLOCK debug3: load_hostkeys: loading entries for host "192.168.x.x" from file "/home/marco/.ssh/known_hosts" debug3: load_hostkeys: found key type ECDSA in file /home/marco/.ssh/known_hosts:7 debug3: load_hostkeys: loaded 1 keys debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521 debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1 debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-sha2-256,hmac-sha2-256-96,hmac-sha2-512,hmac-sha2-512-96,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-sha2-256,hmac-sha2-256-96,hmac-sha2-512,hmac-sha2-512-96,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: first_kex_follows 0 debug2: kex_parse_kexinit: reserved 0 debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1 debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256 debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-sha2-256,hmac-sha2-256-96,hmac-sha2-512,hmac-sha2-512-96,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-sha2-256,hmac-sha2-256-96,hmac-sha2-512,hmac-sha2-512-96,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: none,zlib@openssh.com debug2: kex_parse_kexinit: none,zlib@openssh.com debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: first_kex_follows 0 debug2: kex_parse_kexinit: reserved 0 debug2: mac_setup: found hmac-md5 debug1: kex: server->client aes128-ctr hmac-md5 none debug2: mac_setup: found hmac-md5 debug1: kex: client->server aes128-ctr hmac-md5 none debug1: sending SSH2_MSG_KEX_ECDH_INIT debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ECDSA 70:45:92:18:ab:f2:3e:43:2a:a5:32:28:3f:1b:a4:b7 debug3: load_hostkeys: loading entries for host "192.168.x.x" from file "/home/marco/.ssh/known_hosts" debug3: load_hostkeys: found key type ECDSA in file /home/marco/.ssh/known_hosts:7 debug3: load_hostkeys: loaded 1 keys debug1: Host '192.168.x.x' is known and matches the ECDSA host key. debug1: Found key in /home/marco/.ssh/known_hosts:7 debug1: ssh_ecdsa_verify: signature correct debug2: kex_derive_keys debug2: set_newkeys: mode 1 debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug2: set_newkeys: mode 0 debug1: SSH2_MSG_NEWKEYS received debug1: Roaming not allowed by server debug1: SSH2_MSG_SERVICE_REQUEST sent debug2: service_accept: ssh-userauth debug1: SSH2_MSG_SERVICE_ACCEPT received debug2: key: /home/marco/.ssh/id_rsa ((nil)) debug2: key: /home/marco/.ssh/id_dsa ((nil)) debug2: key: /home/marco/.ssh/id_ecdsa ((nil)) debug1: Authentications that can continue: publickey,password debug3: start over, passed a different list publickey,password debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password debug3: authmethod_lookup publickey debug3: remaining preferred: keyboard-interactive,password debug3: authmethod_is_enabled publickey debug1: Next authentication method: publickey debug1: Trying private key: /home/marco/.ssh/id_rsa debug3: no such identity: /home/marco/.ssh/id_rsa debug1: Trying private key: /home/marco/.ssh/id_dsa debug3: no such identity: /home/marco/.ssh/id_dsa debug1: Trying private key: /home/marco/.ssh/id_ecdsa debug3: no such identity: /home/marco/.ssh/id_ecdsa debug2: we did not send a packet, disable method debug3: authmethod_lookup password debug3: remaining preferred: ,password debug3: authmethod_is_enabled password debug1: Next authentication method: password marco@192.168.x.x's password: debug3: packet_send2: adding 64 (len 55 padlen 9 extra_pad 64) debug2: we sent a password packet, wait for reply debug1: Authentication succeeded (password). Authenticated to 192.168.x.x ([192.168.x.x]:22). debug1: channel 0: new [client-session] debug3: ssh_session2_open: channel_new: 0 debug2: channel 0: send open debug1: Requesting no-more-sessions@openssh.com debug1: Entering interactive session. debug2: callback start debug2: client_session2_setup: id 0 debug2: fd 3 setting TCP_NODELAY debug3: packet_set_tos: set IP_TOS 0x10 debug2: channel 0: request pty-req confirm 1 debug1: Sending environment. debug3: Ignored env SSH_AGENT_PID debug3: Ignored env GPG_AGENT_INFO debug3: Ignored env SHELL debug3: Ignored env TERM debug3: Ignored env XDG_SESSION_COOKIE debug3: Ignored env WINDOWID debug3: Ignored env GNOME_KEYRING_CONTROL debug3: Ignored env USER debug3: Ignored env LS_COLORS debug3: Ignored env SSH_AUTH_SOCK debug3: Ignored env USERNAME debug3: Ignored env SESSION_MANAGER debug3: Ignored env PATH debug3: Ignored env DESKTOP_SESSION debug3: Ignored env PWD debug3: Ignored env GNOME_KEYRING_PID debug1: Sending env LANG = it_IT.utf8 debug2: channel 0: request env confirm 0 debug3: Ignored env GDM_LANG debug3: Ignored env GDMSESSION debug3: Ignored env SHLVL debug3: Ignored env HOME debug3: Ignored env GNOME_DESKTOP_SESSION_ID debug3: Ignored env LOGNAME debug3: Ignored env XDG_DATA_DIRS debug3: Ignored env DBUS_SESSION_BUS_ADDRESS debug3: Ignored env WINDOWPATH debug3: Ignored env DISPLAY debug3: Ignored env XAUTHORITY debug3: Ignored env COLORTERM debug3: Ignored env _ debug2: channel 0: request shell confirm 1 debug2: callback done debug2: channel 0: open confirm rwindow 0 rmax 32768 Write failed: Broken pipe thanks.
